cbr600 help needed
Discussion in 'UK Motorcycles' started by pj002e3917, Oct 2, 2005.
  1. pj002e3917
    pj002e3917 Guest
    A mate of mine has just bought a cbr600, 1992 model.He's had it two
    weeks and says he does'nt know how to get the seat off.
    Can anyone advise?
    T.I.A.
    Lonnas
  2. Angle grinder. Owner's manual. Seat lock.
    The Older Gentleman, Oct 2, 2005
  3. pj002e3917
    pj002e3917 Guest
    I did suggest looking in the owners manual, but he didn't get one, and
    he can't find the seat lock.
    Problem with the angle grinder, he aint got a lighter socket on the
    bike to plug it into.
  4. pj002e3917
    Salad Dodger Guest
    It'll be under the seat.
    | ___ Salad Dodger
    _/_____\_ GL1500SE-V/CBR1100XX-X/CBX1000Z
    |_\_____/_| ..78875.../...19731.../..31242.
    (>|_|_|<) TPPFATUICG#7 DIAABTCOD#9 YTC#4
    |__|_|__| BOTAFOT #70 BOTAFOF #09 two#11
    \|^|/ ANORAK#17 IbB#4 PM#5 WG*
    '^' RBR 2005: Abandoned - Bronze Award.
    Salad Dodger, Oct 2, 2005
  5. look for a small key operated lock underneath the rear of the bike seat or
    a couple of small bolts under the fabric edge of the seat for starters .
    also have a look for any self tappers etc , on a bike that old the original
    lock could be knackered and the previous owners just screwed it down
    Steve Robinson, Oct 2, 2005
  6. pj002e3917
    Zanziba Guest
    Locate small key lock under seat (Probably rear lhs). Place key in lock and
    turn. Now the tricky part; secure the seat using over head cable or rope and
    slowly ease the bike away using lifting gear or a trolley system.
    Discard bike and you should be left with seat ready for overhaul.
    Zanziba, Oct 2, 2005
  7. pj002e3917
    pj002e3917 Guest
    cheers, thanks for the help
  8. pj002e3917
    BGN Guest
    <giggle>
    BGN, Oct 2, 2005
  9. pj002e3917
    emerged from their own little world to say
    IIRC Honda didn't get around to fitting a key operated seat lock on the
    CBR600 until the FX model came out in 1999. I owned one of these.
    My mate had an early 90s CBR6. To get the seat off you need a screwdriver
    to remove IIRC 2 retaining screws on the side-stand side of the bike. Also
    IIRC the seat is hinged on the other side and flips up. This is a tad
    inconvenient if you are out on the road as the toolkit lives under the
    seat.
    wessie, Oct 2, 2005
  10. Heh. Um, radical thought this, but has he considered asking a Honda
    dealer?
  11. pj002e3917
    B.G. Finlay Guest
    wessie () wrote:
    : emerged from their own little world to say
    : > A mate of mine has just bought a cbr600, 1992 model.He's had it two
    : > weeks and says he does'nt know how to get the seat off.
    : > Can anyone advise?
    : IIRC Honda didn't get around to fitting a key operated seat lock on the
    : CBR600 until the FX model came out in 1999. I owned one of these.
    : My mate had an early 90s CBR6. To get the seat off you need a screwdriver
    : to remove IIRC 2 retaining screws on the side-stand side of the bike. Also
    : IIRC the seat is hinged on the other side and flips up. This is a tad
    : inconvenient if you are out on the road as the toolkit lives under the
    : seat.
    On my '97 CBR you remove both side panels and undo the two bolts
    holding the seat on ... you'll need a 12mm spanner/socket.
    Blair
    '97 CBR600
    B.G. Finlay, Oct 2, 2005
  12. pj002e3917
    B.G. Finlay emerged from their own little world to say
    That might be it. Seemed daft anyway considering the position of the
    toolkit!
    wessie, Oct 2, 2005
  13. pj002e3917
    On Sun, 2 Oct 2005 14:11:22 +0100,
    For a socket to plug his angle grinder into? Bet they don't get asked
    for them very often.
    Pip, Oct 2, 2005
  14. pj002e3917
    serf Guest
    You tart!
    serf, Oct 2, 2005
  15. pj002e3917
    Intet Navn Guest
    I had a '93 CBR - and the procedure for removing the seat matched the
    above accurately.
    The toolkit is (supposedly!) accessible by removing one of the smaller
    panels; memory-fragments (from reading the Haynes manual, since my toolkit
    was missing) suggests 'starboard' side...
    /Claus
    Intet Navn, Oct 3, 2005
  16. pj002e3917
    SP Guest
    But certainly not on a '98 CBR6..you need to remove the two full
    sidepanels in order to remove the seat. Obviously, the removal of one
    sidepanel allows access to the toolkit, but it's a right pain in the
    arse.
    Lesley
    CBR600FW
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    SP, Oct 6, 2005
