CBR600F: Simple but annoying problem
Discussion in 'UK Motorcycles' started by dundonald, Sep 17, 2004.
  1. dundonald
    dundonald Guest
    Set out with everything prepared to do my first oil change. Hit an obstacle
    as soon as I started taking the fairing off. The screw at the front of and
    underneath the fairing screwed vertically up is a little cross threaded.
    None of the possy screw heads in my socket set fit. So I pull out the
    bike's tool kit, find the possy screw driver stem - great fits nicely - slot
    it into the handle [1] and crap too long, not enough ground clearance[2].
    So now I'm stuck, can't pull the fairing off due to this small screw.
    [1] also in the bike's tool kit
    [2] I'm wondering if my model [3] of CBR originally had a centre stand but
    may be a previous owner removed it. A quick look underneath showed where the
    centre stand could have been attached, and the haynes manual suggests there
    should be a centre stand. If there was a centre stand, the increased ground
    clearance may be enough to allow the screw driver just fit.
    [3] 1998 W model
  2. dundonald
    Simple: clamp the pozi bit in your Mole grips and push up whilst
    turning the bit with the grips. Or buy a decent socket/bit set that
    has the bit you need.
    Pip, Sep 17, 2004
  3. dundonald
    SP Guest
    Yep, the W model does indeed have a centrestand. You can have mine if
    you like, cos I can't use it because the bike has been lowered.
    Lesley
    CBR600FW
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    SP, Sep 17, 2004
  4. dundonald
    dundonald says...
    It should have had a centre stand. Yours is either an FW 1998 or a FY W
    plate. It won't be on a W plate if it's a 1998 reg though.
    It just so happens that I have a brand new centre stand for an FX/FY
    model with spring and spindle kicking around here. Do you want it?
    Lozzo, Sep 17, 2004
  5. Angle grinder
    The Older Gentleman, Sep 18, 2004
  6. dundonald
    dundonald Guest
    Am I a dumbass [1] for not knowing what mole grips are?
    Valid comment.
    [1] I'm new to all this DIY business
    dundonald, Sep 18, 2004
  7. dundonald
    dundonald Guest
    Thanks for the offer but no ta. :)
  8. dundonald
    dundonald Guest
    Aye that's the one, I was referring to the model rather than reg. It's an R
    reg.
    No thanks mate. I'm not too bothered about a centre stand, just bothered
    about getting something that will fit under the fairing so I can get that
    screw out. How much would a paddock stand raise the front end? I'll borrow
    my bro in laws.
  9. dundonald
    Oh, dear. Get a man in FFS, before you get into trouble. Or you
    might consider a motorcycle (or car, come to that; same stuff but
    bigger) maintenance course at your local College of FE.
    Meanwhile ... http://www.tool-up.co.uk/shop/diy/STA184902.html
    Learning how to use google:
    http://www.google.co.uk/search?hl=en&ie=UTF-8&q=Mole+Grips&btnG=Search&meta=
    is another life skill that comes in dead handy.
    Pip, Sep 18, 2004
  10. dundonald
    dundonald Guest
    Aye I know, may be next time. I will be taking French in the evenings this
    year.
    Ok I ballsed up on this one, I'm normally a self sufficient google user.
  11. dundonald
    I'm just poking fun atchoo, man.
    Always available to answer queries ( them wot I know the answer to, at
    least).
    Pip, Sep 18, 2004
  12. dundonald
    Wizard Guest
    Heh. Seen this?
    http://www.fuckinggoogleit.com
    You can refer people to it by building links eg
    http://www.fuckinggoogleit.com/search?hl=en&ie=UTF-8
    <8P Wizard
    Suzuki GS550 "I like that. Nicely shite" - TOG
    Golf GTi 16v
    ANORAK#17b BOMB#19 BOTAFOT#138 BREast#5 COFF#24
    COSOC#8 DFV#11 STG#1
    Wizard, Sep 18, 2004
  13. dundonald
    Wizard Guest
    MWHID.
    <8P Wizard
    Golf GTi 16v
  14. dundonald
    dundonald Guest
    I know, cheers!
    Btw I borrowed my bro in laws paddock stand [1]. Still not enough ground
    clearance. So when I borrow a set of mole grips I'll give that a try though
    I don't hold much hope. I used a set of pliars today, they got a pretty good
    grip on the possy bit but still couldn't move that screw.
    Talking about that screw, when I do eventually get it out, where does one
    get a replacement screw for ones fairing?
    [1] he'd never used it so I had to put the thing together
  15. dundonald
    STFO, but - Honda dealer?
    Pip, Sep 18, 2004
  16. dundonald
    dundonald Guest
    lol ok I'll stop
    dundonald, Sep 19, 2004
  17. dundonald
    You misinterpret - that wasn't a STF _U(p)_, that was a Stating The
    Fucking Obvious.
    Pip, Sep 19, 2004
  18. dundonald
    dundonald Guest
    I thought you were insinuating sign the f*** off! :)
