After 4 days over Crimble when not used, the CG is now cutting out on slow idle. No unusual roughness (as far as I can tell) or spluttering. Just an annoying need to keep the revs up when stopped. Doesn't make any noticable difference whether the engine is in neutral or in gear with clutch in, or whether lights/indicators are on or off. Background info: I replaced the spark plug (badly fouled with white deposits which Haynes said was to do with surplus oil getting into cylinder) and resistor cover (cracked) 3 weeks ago, running fine since. I had run the tank about 20 miles into the reserve on the 20th, after which the bike appeared to be running fine for the two days immediately before Christmas (when I covered around 50 miles). Wondering whether this could have resulted in some crud getting into the carb, but am guessing that this would have shown up fairly immediately, and wouldn't have just affected the slow idle. Weather seems reasonably mild, although the bike is somewhat harder to start. It's a mystery to me. Constructive suggestions from the cognoscenti would be most welcome.
