CG125 too slow!
Discussion in 'UK Motorcycles' started by ben, Aug 5, 2006.
  1. ben
    ben Guest
    Hello All
    I have had a couple of CG125's a 95 M now a 96 N post facelift model
    The 96 model is more comfortable to ride, the handlebars seem higher as
    does the seat, and it seems to run a lot smoother. However the
    performance seems worse than the older model. When I am going 60mph, in
    5th gear, a slight incline or wind affects me and brings the speed down
    to 45/50. This means changing back to 4th as the engine is obviously
    struggling staying in 5th.
    I have decided I want a bike with better performance, one that will do
    65/70mph without struggling! However I want to stay with a 125cc 4
    stroke for now. I also want it to be fairly comfortable as I sometimes
    am riding for 2/3 hours without stopping.
    Could anybody advise on possible bikes available that would fit this
    description? I have looked at other Honda's and the CBR125 looks
    suitable.... I would just like some advice from those in the know on
    whether this is a good bike to get or if there are any alternatives
    from different manufacturers? I am happy to spend up to £1500 but
    preferably less than that on a used bike.
    Thanks
    Ben
    ben, Aug 5, 2006
  2. ben
    BGN Guest
    What makes you think the CBR125 goes faster than 60mph?
    BGN, Aug 5, 2006
  3. ben
    ben Guest
    I assume its a faster bike as it has 6 gears, is watercooled and is a
    more sportier design than the basic CG??
    It would be nice to have better acceleration and a slightly higher top
    speed.
    ben, Aug 5, 2006
  4. ben
    porl Guest
    Historical imperative dicates that at least one of us should direct you
    to the Suzuki GSX-R1000.
    porl, Aug 5, 2006
  5. ben
    Eiron Guest
    Do you have some sort of restricted licence?
    You would be better off getting a larger single, or a 1970s 125 twin
    when they had sufficient power as standard.
    Eiron, Aug 5, 2006
  6. ben
    ben Guest
    That's interesting, I would definately consider an older bike. So a
    CB125 twin, I will have a look for one. I have looked at CB's before
    mostly on ebay, because they look bigger than the CG. I only found bad
    examples though at the time, doesn't seem to be many about now. I
    assumed they had the same kind of power as the CG, I guess the twin
    exhaust makes the difference then.
    I dont fancy doing my full test just yet and want to carry on with a
    125, I know you are all probably right that I will get fed up with a
    125, but am in no hurry to upgrade yet. Id like to try a slightly
    better 125 first before stepping up!
    ben, Aug 5, 2006
  7. ben
    Dr Zoidberg Guest
    Even if you don't want a significantly bigger bike now , just take your test
    and get it over and done with.
    Even if you do it on a 125 that you continue to ride afterwards you'll be
    able to lose the L-plates , take a passenger , get cheaper insurance and be
    ready for a bigger bike when you want one. The sooner you get the licence
    the sooner the 2 year restricted period ends.
    Dr Zoidberg, Aug 5, 2006
  8. ben
    Dan L Guest
    Get an NSR125.
    Proper bike, derestricted it'll nudge 100mph quite hapily.
    Dan L (Oldbloke)
    Space in shed where NSR125 used to be
    BOTAFOT #140 (KotL 2005/6), X-FOT#000, DIAABTCOD #26, BOMB#18 (slow), OMF#11
    Dan L, Aug 5, 2006
  9. ben
    DanTXD Guest
    <nods> Then get a 600 - they're great fun :D
    DanTXD, Aug 5, 2006
  10. ben
    Right up to the point it stuffs its rings down the exhaust port.
    ogden, Aug 5, 2006
  11. ben
    Dan L Guest
    Never experienced that.
    Sure you're not thinking about an RS125?
    Dan L (Oldbloke)
    Dan L, Aug 5, 2006
  12. No it doesn't.
    The Older Gentleman, Aug 5, 2006
  13. ben
    Any vaguely tuned two-stroke, really.
    ogden, Aug 5, 2006
  14. Some of us have bought lots of bikes on Ebay. Sold lots, too. What's
    your problem?
    The Older Gentleman, Aug 6, 2006
  15. ben
    deadmail Guest
    Inability to spot a lemon I'd guess.
    deadmail, Aug 6, 2006
  16. ben
    deadmail Guest
    Depends on the item. I've had some real bargains and in other cases
    I've paid too much.
  17. For some things, but not for others. My impression is that bike prices
    are on the weak side atm.
  18. ben
    ben Guest
    I have now found out the sprockets on my CG125 are the correct ones to
    enable the lowest gearing. the front sprocket has 14 teeth and the back
    one has 41. The only alternative sprockets are 15 for the front and 40
    for the back which would make the gearing higher!
    I have now replaced the exhaust which has made the bike quieter but it
    is still struggling for performance. In 4th it struggles to rev out and
    in 5th there is no chance!
    I am going to try changing spark plug, oil / filter and air filter
    today and see if that helps. I have already used carb cleaner in the
    air intake as well.
    anyone got an ideas? It's like the engine is just not producing the
    power for it to rev out. It revs out in 3rd gear at about 53mph. 4th
    will go close to 60 and 5th doesnt go any further unless down a hill!
    ben, Aug 22, 2006
  19. ben
    Sounds pretty normal to me. 60mph is about tops unless you're really
    light/lie flat on the tank/go downhill. Why did you expect more?
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Aug 22, 2006
  20. ben
    ben Guest
    My last CG125, older shape, possibly lighter bike, did 65 easily and 70
    at times.
    It would make the difference to long journeys, at the moment I have to
    keep alternating between 4th and 5th when i'm going 55/60. 5th
    struggles to maintain this speed, and drops to 50 if winds against me
    or a slight incline!
    ben, Aug 22, 2006
