Chain & sprocket tips
Discussion in 'UK Motorcycles' started by Nige, Feb 27, 2010.
  1. Nige
    My first experience of doing a C&S kit was on a Honda Dommie with the 2
    bolts/plate arrangement. Quite an easy job with the bike balanced on a beer
    crate under the engine.
    After a while I needed to do my other bike. A VFR750FJ. I thought it would
    be an easy job too...
    wessie, Feb 27, 2010
  2. Nige
    crn Guest
    The rattle gun would have it sorted in a few seconds.
    crn, Feb 27, 2010
  3. Nige
    On Loz's ZZR1100, we had all sorts going on, to absolutely no avail.
    Once Big Nick the Man Mountain arrived, we sat Loz on the bike to lock
    both brakes on and provide balance and counterweight: I had the job of
    keeping the 1" drive socket on the nut, located in the breaker bar and
    on the axle stand under it as a pivot.
    We put Big Nick on the scaffold pole, the length of which placed him
    beyond the rear wheel. All in place, strain taken, BN straightened his
    legs - and the back of the bike came off the ground and it all moved
    forward. We moved the bike so that the front tyre abutted the dwarf
    wall on the end of the patio and did it again.
    The bike went up horizontally, and just as it got to the top of the
    dwarf wall - the nut finally let go with a resounding bang.
    We dunno how much torque we'd got on that - but to lift Loz+ZZR two
    feet into the air, quite a bloody lot, mate. They can get tight.
    Pip, Feb 27, 2010
  4. <fx: awaits massive sweary post>
    The Older Gentleman, Feb 27, 2010
  5. Holy crap. I wonder what sort of machine Kawasaki use to put the damn
    thing on?
  6. Nige
    Pete Fisher Guest
    I've had a heater on in the garage while summoning up the sinews.
    I might as well get some practice as the chances are I will be wanting
    to swap front sprocket sizes quite often. The problem is that this one
    has been rusting in place for a minimum of four years, and the previous
    owner obviously didn't follow Andy's tab washer advice. There are small
    projections of torn off washer on every flat of the nut.
    A quick cup of coffee and then I'm going in - I may be some time.
    | Pete Fisher at Home: |
    Pete Fisher, Feb 27, 2010
  7. Nige
    Pete Fisher Guest
    Well the fates were smiling on me this afternoon.
    Cleaned up the ragged tab washer bits as much as possible, put it in to
    5th and jammed a large bolt in to one of the lightening holes on the
    rear sprocket to nestle against the swinging arm.
    FFS - it needs a socket larger than anything I have got. In desperation
    I discovered that a FOAD 7/8 BS[1] ring spanner was a good fit. Worth a
    try anyway. One good heave and it was free!
    One slight problem is that a 15 tooth gearbox sprocket slightly fouls
    the swinging arm chain protection. Nothing that can't be easily sorted
    should I find such high gearing is needed. I'm putting the smallest
    available 47 alloy on the rear (standard is 49) as I can go right down
    to 12 on the front if required. Judging by how it felt on the 13/50 it
    has been on, I'm going to try 14/47 first. I'd rather be geared too high
    for the first practice than rev the nuts off it and blow it up. Just got
    to cut the chain to the optimum length now to allow the full range if
    possible.
    I wonder how Nige is getting on?
    [1] What's that going to be in metric - 32mm?
  8. Nige
    From your and Mr B's posts, must be Kwak thing.
    Pip Luscher, Feb 27, 2010
  9. Nige
    Nige Guest
    SNAP FFS!
    Nowt i had was big enough, so i changed the undertray, what a fucking job,
    everything is in there.
    The **** that had it before cut it down & made a **** of it.
    The lock for the rear seat is a proper bog huggng ringreamer of a bastards
    fuckjuice to do.
    Oil & filter tomorrow, need to find the size of the fucking nut too.
    Not a wasted afternoon.
    Nige,
    Land Rover 90
    Yamaha R1
    Range Rover Vogue
    Nige, Feb 27, 2010
  10. Nige
    Pete Fisher Guest
    It took me by surprise because for some reason I expected it to be a
    30mm.
    That fiddly eh?
    Fairly large (36 ?) at a guess. Hopefully you can google it.
    That's something.
  11. Nige
    Pete Fisher wrote:
    33.02mm according to the chart here:
    http://www.sat.dundee.ac.uk/~psc/spanner_jaw.html#Jaw_Size_Table
    It's good to see somebody keeping the old tools handy.
    I consigned all my big old spanners and sockets to a cardboard box,
    then found that I was forever in there, especially for larger sized
    stuff. They now reside in the bottom of toolbox#4 for ease of access.
    Pip, Feb 27, 2010
  12. Nige
    Nige Guest
    On 27/02/2010 14:05, Pip wrote:
    Sounds like the crank bolt i need to get off the 90 i am retro fitting
    power steering to :(
    Nige, Feb 27, 2010
  13. Nige
    Pete Fisher Guest
    What a useful site. It was a tad slack, so I'm guessing 32 should be
    snug, but I'll go shopping armed with the old nut (I acquired a new one
    just in case when ordering the tab washer to make the postage seem more
    reasonable). This on-line parts ordering lark is a boon compared to the
    old days. A J Sutton seem to stock everything for it, at a price.
    This is a Britool chromed double-ended (7/8 & 1 BS) ring spanner, so
    featuring built in breaker bar capability. I purchased it in the 31
    CSR/Monza outfit days and it has been pressed in to service for various
    bodges over the intervening thirty years. I also keep one or two
    imperial sockets handy that can sometimes help persuade slightly
    butchered metric hex stuff off if hammered on.
  14. Nige
    I'm pretty sure it's 34mm. If not it'll be 36mm but I really don't
    think it is because I've never bothered buying a 36mm socket and done
    plenty of C+S on R1s etc.
    Lozzo, Feb 27, 2010
  15. Nige
    Nige Guest
    I see it seems to be 36mm, but i'm gonna get a set of big sockets anyhow.
    Nige, Feb 27, 2010
  16. Nige
    SP Guest
    I'm wondering why they put the smallest, lightest guy on the bike in
    first place.
    Lesley
    Residing in the Capital of Culture 2008
    CBR600FW
    Peugeot 206 S
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    SP, Feb 28, 2010
  17. Nige
    Ben Guest
    Yes, it would. Which is why I said in another post I'll leave it to
    dealers in the future. Whilst I suffer from TAD[1] as much as the
    next WUN, I can't afford or justify a compressor and gun.
    [1] Tool Acquisition Disorder.
    Ben, Feb 28, 2010
  18. Nige
    Position of highest risk, innit. Expendable spic, see - if it had gone
    bang in a bad way he could have been flung ... feet.
    We didn't really expect the thing to go up in the air - shoving it
    forwards is one thing, but vertically up a wall, with the front wheel
    locked is something else entirely. He looked a little worried ;-)
    Pip, Feb 28, 2010
  19. Nige
    I tried using a nice big 1/2" drive air impact gun (1) on mine and it
    wasn't having any of it. No doubt it would have moved if I'd had a
    bigger compressor and a 1" drive gun on it but I haven't got either of
    those.
    The trouble really starts when you want to buy 'proper' tools rather
    than toys.
    (1) Calling them a rattle gun is like calling a hammer a bang bang. If
    I went to the stores at a power station and asked for a rattle gun
    they'd either not understand what I was asking for or start asking my
    employer if I knew what I was doing.
    Andy Bonwick, Feb 28, 2010
  20. Nige
    Andy Bonwick wrote:
    As much as I prefer to call things by their correct name, the majority
    of the mechanics/technicians in the motor trade call air impact drivers
    rattle guns.
    Lozzo, Feb 28, 2010
