Chain & sprocket tips
Discussion in 'UK Motorcycles' started by Nige, Feb 27, 2010.
  1. Nige
    Case proven.
    Andy Bonwick, Feb 28, 2010
    #41
  2. Nige
    Beav Guest
    There should be a tabbed washer under the nut. Bend the tab back before you
    try fitting a socket and bend it back when you've fitted the new sprocket.
    No Loc-Tite.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Feb 28, 2010
    #42
  3. Nige
    Beav Guest
    How many fucking spanners don't you have Nige?
    I reckon a trip to Halfrauds or Machine Mart is a ust for you.
    The "trick" to a well maintained "anything" is having a decent set of tools
    for the jobs you'll likely come across[1]
    [1] Not in the usual Nige meaning.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Feb 28, 2010
    #43
  4. Nige
    Beav Guest
    And it depends on the rattler too. A cheap rattler typically has around 250
    torques[1], but a good (expensive) one is around 650 "undoing" torques.
    [1] Thank you Mr Clarkson
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Feb 28, 2010
    #44
  5. Nige
    crn Guest
    Indeed, one of those jobs where only SnapOn is good enough.
    And a decent compressor which can deliver 140 psi also helps.
    The combination of these two represents an almost irresisible force for
    any nut that you are likely to encounter in reality.
    crn, Mar 1, 2010
    #45
  6. Nige
    crn Guest
    Just jam a bar between the chain and the sprocket and put the bike
    in first gear. That should give you enough inertia for the rattle
    gun to do its job.
    It is not necessary to have the nut rigidly immobilised, you just
    need sufficient inertia for the impacts to work against.
    crn, Mar 1, 2010
    #46
  7. Nige
    Switters Guest
    Ah the old "measure twice, cut once".
    Switters, Mar 2, 2010
    #47
  8. Nige
    Although, as it turned out, twice wasn't enough.
    platypus, Mar 2, 2010
    #48
  9. Nige
    Pete Fisher Guest
    I always measure mine (as I usually just by a standard length of chain)
    by passing it round the sprockets after pushing the rear wheel as far
    forward as it will go, then seeing where the join will be. But then, on
    the hill climbers, I may be deviating from a standard pitch count as a
    result of very significant gearing changes. If you can start the cut by
    putting a pin extractor on the correct one with the chain in situ it's
    hard to go wrong. Angle grinder wielders would have to mark it somehow.
    | Pete Fisher at Home: |
    Pete Fisher, Mar 2, 2010
    #49
  10. Nige
    Nige Guest
    This DID chain was the right length for the R1, it even said so on the box
    Nige,
    Land Rover 90
    Yamaha R1
    Range Rover Vogue
    Nige, Mar 2, 2010
    #50
  11. Nige
    "This fucking chain fits an R1, you cuntflapping goatfelching arsewipe.
    If it doesn't it'll be your fucking fault, you useless puddle of
    mouldering gangbang cuntdribble".
    Pip, Mar 2, 2010
    #51
  12. Nige
    Gavin Guest
    Im up gearing the 600, with a 525-47 on the rear rather than a 45.
    Job for the weekend - I never get the 600 to top out in, well, top, so
    a little extra acceleration can only help.
    Gavin.
    GSXR600K1
    Twitter: http://twitter.com/gavin_wilby
    Blog: http://www.stoof.co.uk
    Gavin, Mar 2, 2010
    #52
  13. Nige
    Gavin Guest
    I hope it doesnt make it stupidly revvy, but I dont think so.
    Ill have to work out a way of mounting the tomtom so I can work out the
    speedo too.
    Gavin.
    GSXR600K1
    Gavin, Mar 2, 2010
    #53
  14. Nige
    Gavin Guest
    Gavin, Mar 2, 2010
    #54
  15. Nige
    Beav Guest
    They are if you stop the sprocket moving before the force reaches the cush
    drive, hence my saying a bar shoved into the bottom of the chain run and
    jammed directly up against the sprocket.
    They're properly tight when you have to use an AG to remove the things.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 2, 2010
    #55
  16. Nige
    Beav Guest
    Heh, very true Steve.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 4, 2010
    #56
  17. Nige
    Lady Nina Guest
    <pats on head>
    Lady Nina, Mar 9, 2010
    #57
