Chains part deux, revisited
Discussion in 'UK Motorcycles' started by Greybeard, Dec 28, 2009.
  1. Greybeard
    Greybeard Guest
    Looking to change the chain 530 X-ring and sprockets on a friends Harley.
    What is the best flavour of chain nowadays as endorsed by UKRM? Still DID?
    I have used recently on a Trumpet a 'Triple S' chain & it seems ok, no
    problems yet with about 25K on it?
    Also, where does the FOAK recommend for sprockets (for Harleys)?
    TIA.
    Greybeard
    FLHR -03 UK (95 cu-in Stg 2. Big Boy 2!)
    Garmin Zumo 550, To get me home!
    ukrm@foxtails[dot]co[dot]uk
  2. Greybeard
    Beav Guest
    Belt conversion?
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Dec 28, 2009
  3. Greybeard
    Greybeard Guest
    Would be good and easy, but the guy bought it because it had the chain
    conversion done! Why IHNI but he likes it.
    Greybeard
  4. Greybeard
    M.Badger Guest
    Try this lot if you can't source locally.
    http://www.wemoto.com/bikes/Harley_Davidson/XLH_1200_Sportster/88-90/
    As for chains, I got approx 30,000 miles from a DID X-ring. There was still
    life in the chain, but the front sprocket was fucked, and the rear looked
    iffy, so yes, DID X-ring went on.
    This lot:-
    http://www.shirebrookmotorcycles.co.uk/
    Used to claim to have the largest stocks of sprockets in the UK. Whether
    that was true or not, they did stock Chiaravelli sprockets, which seemed to
    last longer than JT or stock.
    M.Badger, Dec 28, 2009
  5. Greybeard
    Greybeard Guest
    Thanks I'll have a look around the sites recommended.
    It seems DID 530ZVM is the best choice.
    Greybeard
  6. Greybeard
    Beav Guest
    The last knobhead hasn't been born yet.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Dec 29, 2009
  7. Greybeard
    Greybeard Guest
    Can't argue with that :)
    Greybeard
    Greybeard, Dec 29, 2009
