Cheap VFR800 on ebay
Discussion in 'UK Motorcycles' started by Nigel, Jan 21, 2007.
  1. Nigel
    Nigel Guest
  2. Nigel
    SteveH Guest
    SteveH, Jan 21, 2007
  3. Nigel
    Nige Guest
    LOL!!!!
    'nothing up top but a bucket & a mop & an illustrated book about birds'
    Nige
    Subaru WRX (54)
    Land Rover 101 GS/Ambi (Morph)
    BMW 650 GS Dakar
    2000 Suzuki GSX1300R Y Hayabusa
    KTM 520 SX
    Nige, Jan 21, 2007
  4. Nigel
    SteveH says...
    Which part of "It has a stainless steel exhaust system with a Micron
    carbon fibre can," don't you understand? Read the fucking description.
    Anyway, it might be £600 for you to get an exhaust fitted, but some of
    us know our way round spanners and could do it cheaper.
    I'm not sticking up for the OP cos I think anyone who calls a bike cheap
    at the start of an auction is a ****, but it has a new exhaust fitted
    already. Someone like Mr Bonwick could probably fit helicoils with the
    engine still in the frame and the cylinder head still on the barrel.
    Lozzo, Jan 21, 2007
  5. <snip url>
    Why don't you say it's yours?
    The Older Gentleman, Jan 21, 2007
  6. Nigel
    SteveH Guest
    I did. Just because it's stainless doesn't mean it's in fine shape.
    They're supposedly stainless as standard, but they still manage to rot
    through.
    Well, yes. But that's the going rate to have a VFR exhaust system
    fitted.
    Possibly. VFR exhausts are notorious for being a complete PITA to remove
    and refit..... being cynical, you'd have to ask why the OP hasn't had
    the '50 quid' job done and a new MOT stuck on it. Reading between the
    lines, I'd suggest it's because it's a PITA of a job to do and he's
    found out it's likely to cost more than the difference between his
    current asking price and it's market value with MOT.
  7. Nigel
    SteveH says...
    Why don't you ever apply this kind of logic when you buy a POS Alfa?
    You'd save a fucking fortune and wouldn't have a driveway littered with
    piles of scrap.
    Lozzo, Jan 21, 2007
  8. We were discussing this sort of thing last night, at Ogden's bash. If
    it'll sail through an MoT, then why not do it yourself, and lift the
    value of the vehicle (whatever it is) by x%?
    I always treat any claim that "It will pass an MoT, easy" as meaning
    "It' won't".
  9. Nigel
    Nige Guest
    i thought it was obvious!
    Nige
    Subaru WRX (54)
    BMW 650 GS Dakar
    KTM 520 SX
    Nige, Jan 21, 2007
  10. Nigel
    Nigel Guest
    The header pipes and collector box are stainless steel from Motad, I fitted
    them in September 2005 (it cost me £446.05). The end can is a carbon fibre
    Micron which has been on the bike as long as I've owned it. The exhaust
    system as a whole is in very good condition. I've brought another bike
    (Buell XB12S) and really can't be arsed to fix it. But if I've still got it
    when the weather warms up I will fix and I guess it will sell for
    £1500/2000. I've also got a 1977 Jota that I could be persuaded to sell (
    and a 2000 YZ426 come to that)
    Nigel, Jan 21, 2007
  11. Nigel
    Nigel Guest
    message
    Hadn't really occurred to me that I should.... .... do you think I nicked it
    Nigel, Jan 21, 2007
  12. Nigel
    No it wasn't, especially if one didn't look at the auction.
    Timo Geusch, Jan 21, 2007
  13. Nigel
    Erm, Lozzo, I assume you've had a VFR apart far enough to say, *see*
    the studs on the rear head?
    Just like, wondering.
  14. Nigel
    Timo Geusch says...
    I've worked on a couple of VFRs. The front ones aren't so bad. If they
    were rear ones I'd run a mile. Mind, even taking the head off isn't a
    hugely major job with injection and gear driven cams. It's not something
    I'd shy away from, but if I was doing it for someone else I'd want top
    dollar for the work.
    Lozzo, Jan 21, 2007
  15. Nigel
    Nige Guest
    Good point
    Nige
    Subaru WRX (54)
    BMW 650 GS Dakar
    KTM 520 SX
    Nige, Jan 21, 2007
  16. No, but then I'm not that thick and I'd soon know if you had.
  17. Nigel
    I somehow assumed that the problem is a stud on the rear, as I can't
    quite see why SteveH would think that it was such a big job if a front
    stud was mullered...
    Indeed, hence the 600 quid bill...
  18. Nigel
    SteveH Guest
    I was making the assumption that the whole exhaust was likely to have to
    be worked loose, needing at least some bits replacing in the process.
  19. Nigel
    Timo Geusch says...
    Which is why I am trying to make the point, it's the front studs and
    once all the fairings are out of the way there's very little to restrict
    work. Rads are side mounted so shouldn't need to come off to gain
    access. Having looked at a photo of a stripped 800i, it all looks pretty
    easy to get to, with plenty of room to work in as there are no frame
    downtubes or other gubbins getting in the way.
    3 hours each way I reckon so not a huge amount of time. It'd definitely
    have the head off, repaired and back on in a day. Certainly not 600
    quid. I still maintain you could do it with the head still on the bike,
    but obviously Steve, being a top-flight retail executive and reknowned
    motorcycle repair expert, knows better.
    Lozzo, Jan 21, 2007
  20. Nigel
    SteveH says...
    Assume
    You must have heard the old adage about the word 'assume', Steve.
    Lozzo, Jan 21, 2007
