Clicking clutch
Discussion in 'Motorcycle Technical Discussion' started by Gizzmo, Dec 2, 2003.
  1. Gizzmo
    Gizzmo Guest
    Hi
    The bike is Suzuki GSX750FY (2000 model). The katana in the US I believe.
    After recently changing my chain and sprockets I now have a clicking noise
    from the clutch. It comes from the bottom end under the engine cover. Whilst
    I had the cover off to change the chain I gave the cover a really good
    cleaning. I put it in a parts washer at work, which removed all the grime
    and grease which collects under there.
    On reassembly the clutch clicks when I start to pull it in. It does not seem
    to affect the operation of the clutch. When it has clicked once it seems not
    to click as much till it has stood a while.
    Anyone had anything like this?
    Gizzmo
    Gizzmo, Dec 2, 2003
  2. Gizzmo
    Mark Olson Guest
    I think your bike has a cable operated clutch, correct?
    When you degreased the engine cover, you removed all the grease in the
    clutch actuator mechanism. This needs to be well lubricated. Be very
    careful if you take it apart as the little tiny ball bearings in the
    ball screw mechanism of the actuator are extremely easy to lose.
    Mark Olson, Dec 2, 2003
  3. Gizzmo
    Gizzmo Guest
    believe.
    That sounds very reasonable. I wondered if i had damaged the clutch drive
    thingy in the cover.
    Time for a grease.
    Many thanks
    Gizzmo
    Gizzmo, Dec 2, 2003
