I ride a '95 GSXR 750 My current problem is that my carbs are getting a build up of white paste in the jets. I just had them over hauled on Sunday, 8/31, and the number 4 carb's main jet was totally clogged with the stuff. Right after the carbs were cleaned and sync'd the bike was running great. This morning I took the bike for a long ride through the twisties, and over the course of the ride the bike went from accelerating smoothly to noticeable hesitation in the mid range. It's not an issue of altitude, because i don't live much above sea level, and it ran pretty crummy as I pulled into the driveway. When I acquired the bike a couple years ago it didn't have a gas tank. The tank I found for it had some visible rust inside it, so I cleaned the rust out with a mixture of sulphuric acid diluted with water, and wood screws, then I coated the inside with Kreem. I also installed in- line fuel filters below the tank to the fuel lines. Here's the thing I don't see any flaking of the coating inside the tank when I look into it, but I can't imagine what else would generate the white paste that clogged the number 1, and number 4 carbs. Oddly the number 2, and number 3 carbs were clean. Anyway, I now need to take the bike back, and pay to have the carbs cleaned again. Of course before I go to this expense I have to figure out what is causing the carbs to clog in the first place. The bike sat for about three months, and I dumped the gas before I turned it over, but the carbs were clogged anyway. I was able to get it to drive, but with really decreased power, and only on three cylinders. I ran it through 4 tanks of gas, and poured a full can of sea foam in each time. That didn't help, so I took it to a mechanic, who cleaned out the carbs. If I discover that it is the tank liner can I take the tank to a radiator shop, and have them clear out the liner? I recall that in class you mentioned this as one way to get rust out. You also mentioned that if I take the tank to a radiator shop I should wrap the tank completely to protect the paint. I have four questions: 1) Can a radiator shop remove tank liner and anything else that may flake off into the carbs? 2) Does anyone recommend a good radiator shop in Los Angeles? 3) What should I cover the outside of the tank with to protect the paint? 4) Do you think that using a liberal amount of sea foam in the tank may have caused some of the tank liner to lift off, blend with the fuel, and clog the carbs?
