Clutch problem with Ninja 250
Discussion in 'Motorcycle Racing' started by Sam, Nov 22, 2003.
  1. Sam
    Sam Guest
    Hello experts: can someone please tell me how I may be able to fix a
    clutch lever (on the left hand handle) that does not spring all the
    way back when i release it.?
    Sam, Nov 22, 2003
  2. Sam
    Richard Guest
    Does it actuate and disengage correctly?
    If not the cable tension is wrong. Try tightening up the cable.
    If that's OK, you should check for binding or interference between the lever
    and the inside of the housing.
    Good luck.
    Richard, Nov 25, 2003
