Coil failure again?
Discussion in 'UK Motorcycles' started by Doesnotcompute, Sep 11, 2005.
  1. Having let the immobiliser flatten the ZZR battery - my own fault for
    not riding it in 3 weeks, I optimated and re-installed the battery.
    Started first click of the button - lovely.
    Warmed it up good and proper, then took it out gently at first.
    For 20 seconds.
    Then I caned the **** out of it.
    For 20 seconds.
    It usually helps to turn the fuel back to 'on' after replacing the fuel
    tank.
    Having made this simple but obvious road side 'repair', I then continued
    to thrash **** out of it until I got to the motorway. Then I thrashed it
    a little more. For 20 seconds. Zzzzzzzzzzzzzzzpft. The cunting thing died.
    Fuel: check.
    Power: check.
    imobiliser off: check.
    kill switch: check.
    foibles tested: check.
    wait 5 mins: check.
    hit starter: Vroom.
    Coninued the caning. About 7 miles later, zzzzzzzzzzzzzzzzpft again.
    And then again just as I hit the hotel called 'home'.
    Now - given this was exactly the fault that was eventually traced to an
    iffy coil - replaced and resolved, it would appear that the newly
    acquired coil is also fucked. So - is there anything the bike or it's
    rider could be doing to fubar the coils, or, is it 'one of those things'?
    <sigh>
    Dnc
    B1200 - +30bhp ~|~ ZZR1100 - faster when upright
    V2300 - flat cap and rug ~|~ VS800 - borked
  2. Doesnotcompute
    Guy Fawkes Guest
    don't determine if a coil is fucked by "elimination" eg "well I checked
    everything else so it must be the coils" and don't be fooled by
    "fixing" the problem temporarily by fitting new coils.
    I don't know you bike so I can't give you the numbers, but coils should
    be checked for impedance with an (accurate) ohmmeter, this is the only
    reliable way to diagnose them. Obviously you need to know for a fact
    what they should read.
    Have a read of http://www.xs11.com/faq/faqcoil.shtml
    Ok not your make or model but should help.
    Guy Fawkes, Sep 11, 2005
  3. Doesnotcompute
    Four cylinders = 2 coils, unless it's got a distributor, which I doubt
    (it's not a 250 or something is it?)
    I've only once ever had to replace a coil.
    I did hear a theory that the old points ignition systems could
    overheat a coil if the ignition was left on with the engine stopped,
    but TBH it sounds far fetched and certainly shouldn't apply to a
    modern electronic system.
    Pip Luscher, Sep 11, 2005
  4. Doesnotcompute
    mups Guest
    Doesnotcompute says...
    Have you checked the tank breather isn't blocked?
    mups, Sep 11, 2005
  5. Doesnotcompute
    Guy Fawkes Guest
    it's true, but associated with cars with the single coil and dizzy,
    bikes were hardly ever prone to it, basically it was possible for the
    coil to stay energised with the ignition on and the engine not running,
    hence the in between position (off / auxiliaries / run / start) betwee
    off and run in cars for running the radio etc... if you had a bad coil
    it could cook itself to death, of you had a good coil it could flatten
    the battery PDQ.
  6. Using the patented Mavis Beacon "Hunt&Peck" Technique, Doesnotcompute
    Oh gawd...
    There's something wrong with these symptoms and the explanation the
    dealer gave you. I discussed this with (IIRC) Pip a week or two back.
    One coil dying on the ZZR should *not* kill the bike dead. It should
    keep running on two. It'll run like shit, but it should run.
    Unless the engine management thingy can spot a dead coil and shut down?
    I've never heard of one doing that, but who knows?
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Sep 11, 2005
  7. Some people *always* suggest this and I've never heard of anyone who's
    ever broken down because of it.
    The Older Gentleman, Sep 11, 2005
  8. In uk.rec.motorcycles, Doesnotcompute amazed us all with this pearl of
    wisdom:
    I'm fucking glad I never bought it.
    Whinging Courier, Sep 11, 2005
  9. Silly question, but you haven't got one or more of the fuel lines kinked
    under the tank? Because your problem sounds like what you'd get if you
    had.....
  10. Doesnotcompute
    Statto Guest
    ever broken down because of it.[/QUOTE]
    *waves*
    Had this on the ZRX a couple of years ago. A few unscheduled stops on
    the hard shoulder were eventually cured by cleaning the antispill
    stopper in the tank filler assembly.
    Statto, Sep 11, 2005
  11. Doesnotcompute
    Ratchet Guest
    Happened to me years ago at the TT. Tank bag blocked the breather hole in
    the filler cap of my BSA A65.
    Ratchet, Sep 11, 2005
  12. <waves>
    ShiteOldMZs do it if you put a tankbag on the filler cap.
    Grimly Curmudgeon, Sep 11, 2005
  13. Doesnotcompute
    *waves*
    stopper in the tank filler assembly.[/QUOTE]
    Supposed to be a culprit for the fuel starvation problems that 1200 Trophies
    are notorious for - my problems were actually down to inline filters full of
    crap.
    platypus, Sep 11, 2005
  14. Doesnotcompute
    Dan White Guest
    Well I was there when Porl overfilled his tank and blocked the breather.
    Simply would not start, until I suggested opening the fuel cap and trying
    again. The resultant backfire was impressive to behold.
    Dan White, Sep 12, 2005
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique,
    Are you saying that the engine spins, but doesn't fire, or that it
    doesn't spin at all?
    Wicked Uncle Nigel, Sep 12, 2005
  16. Doesnotcompute
    Guy Fawkes Guest
    sounds heat related........
    xs11s had a thing with not quite flexible enough wire on the vacuum
    advance unit, which was rare on a bike, lacking one of them I'd start
    to suspect things like the CDI unit, the xs11 problem would manifest as
    a misfire / losing a cylinder or two, you could cure it for a few miles
    by flicking the kill switch on an off, or permanently by replacing the
    wire in question with multimeter cable.
    if it was winter it would sound like icing
    depending where your CDI unit is, see if you can temporarily arrange
    better air flow to it by jacking the seat up or something, you could
    easily have developed a dry joint in there which would show as a heat
    related failure... dry joints usually happen on power tracks on a PCB,
    if you can remove the PCB and ever so gently flex it (this works on PC
    motherboards too) you can hear a slight ticking type sound when the dry
    joint gives.
    carry a spare plug, next time it dies stop quickly, use the spare plug
    and test your HT leads against the head, if you get healthy sparks it
    ain't CDI/coil/electrical, if you don't get sparks it is.
    Guy Fawkes, Sep 12, 2005
  17. Doesnotcompute
    mb Guest
    @localhost.talkaboutmotorcycles.com>,
    says...
    Has it got carbs or EFI? WUN mentioned an engine management unit?
    Have the coils got a common earth? Do you know if the fuel pump is
    running when the bike stops?
    If you didn't live in the grim norf, I could have a look at it. A fresh
    pair of eyes is sometimes a good idea.
    mb, Sep 12, 2005
  18. Doesnotcompute
    Champ says...
    Ummm....mb lives in south Dutchland
    Lozzo, Sep 12, 2005
  19. Doesnotcompute
    mb Guest
    Champ: Not the sharpest tool in the box.
    I have experience with EFI and carbs, that I know not what is on a ZZR
    makes little difference to my mechanical knowledge. Or perhaps you could
    explain why it should?
    You may also like to know that I know that DNC currently resides in
    Heerenveen, in Friesland, which is quite a long way north. Hence the
    grim norf comment. You can, of course, check my message headers.
    Now stop being such a chump, Champ (bet you haven't heard that before).
    mb, Sep 12, 2005
  20. Doesnotcompute
    I've had that but with a good coil. One of my banger Triumph's coil
    exploded - well the the end popped off and all the dalek/coil goo came
    out - because I'd stepped on the switch box (turning on the ignition)
    whilst getting out and then left it overnight with the battery attached.
    Major panic on race day when it wouldn't start to get it off the trailer.
    sweller, Sep 13, 2005
