Coke didn't do it
Discussion in 'UK Motorcycles' started by The Older Gentleman, Mar 4, 2011.
  1. The Older Gentleman
    SIRPip Guest
    Divine, apparently.
    SIRPip, Mar 6, 2011
    #41
  2. The Older Gentleman
    Jim Guest
    It makes quite decent soldering flux in a pinch, if you don't mind
    cleaning off the sticky residue.
    Jim, Mar 7, 2011
    #42
  3. The Older Gentleman
    Beav Guest
    It's the only one I've used, so it must be:)
    Beav, Mar 7, 2011
    #43
  4. The Older Gentleman
    Malc Guest
    Phosphoric acid is An ingredient in Coke. But as others have pointed
    out, it's not concentrated enough. If it was strong enough then it
    would burn your mouth.
    Malc, Mar 7, 2011
    #44
  5. The Older Gentleman
    If you leave it on your mounth for a week or two, you'll find that
    most of your tooth enamel has been etched away.
    Ace, Mar 7, 2011
    #45
  6. The Older Gentleman
    SIRPip Guest
    Hallelujah!
    SIRPip, Mar 7, 2011
    #46
  7. The Older Gentleman
    geoff Guest
    As long as you avoid using the dictionary definition of "decent"
    geoff, Mar 7, 2011
    #47
  8. I used Por15 on my Strom. Worked a treat. Great stuff.
    Fraser
    Fraser Johnston, Mar 10, 2011
    #48
