Come on then, push and pull throttle cable question
Discussion in 'UK Motorcycles' started by Oldbloke, Aug 9, 2004.
  1. Oldbloke
    Oldbloke Guest
    Well, I am still none the wiser.
    Why, when the throttle works just fine with the pull cable, do I need a push
    one as well?
    Dan L (Oldbloke)
    M'boy's current bike 1990 Suzuki TS50X (Heavily fortified)
    M'boys NEW bike 2003 Honda NSR125R
    BOTAFOT #140, DIAABTCOD #26
  2. Oldbloke
    It's useful to have a cable to pull the throttle shut, as depending on a
    little breakable spring to shut the throttle is not always such a good
    idea.
    Muck, Aug 9, 2004
  3. If the 'pull to open' throttle cable is badly lubricated and/or the throttle
    grip is stiff, the spring pressure on the cable might not be enough to pull
    it back and close the throttle. Having the 'pull to close' cable means
    you're less likely to find yourself with the throttle stuck open.
    David Johnston, Aug 9, 2004
  4. Oldbloke
    Martian Guest
    To close the throttle should the spring return fail.
    Martian:
    VTR1000 Firestorm
    Martian, Aug 9, 2004
  5. Oldbloke
    TomTheKraut Guest
    Adjust the path and slack in the push cable until it doesn't interfere
    with the pull cable anymore.
    Carb sliders can get stuck (and occasionally will do so), no matter
    which type of carb that is (flat slide or round slide).
    Additionally you have a backup if the pull cable snaps - you just
    connect the push cable to the pull side of the carb mechanism and hey
    presto! at least you can get home.
    Tom :{)
    BOTAFOT#105 COFF#02/ OSOS#15 KwaSoH#2
    SR500(.de), SRX-4(.jp)
    Make it idiot-proof and someone invents a better idiot...
    Hiroshima pics: http://makeashorterlink.com/?C12E12B97
    TomTheKraut, Aug 10, 2004
  6. Oldbloke
    Oldbloke Guest
    Heh, great idea Tom, but it would involve taking the carbs off to do it.
    Dan L (Oldbloke)
    Oldbloke, Aug 10, 2004
  7. Oldbloke
    TomTheKraut Guest
    Don't tell me that you would have to take the carbs off in order to
    mount a new throttle cable?!
    That would be a really shitty designed bike, then...
    Tom :{)
  8. Oldbloke
    Oldbloke Guest
    Well, that's what I had to do to fit the new one last week. I can see no
    other way of doing it, but SWK different may be along.
    Dan L (Oldbloke)
