Constructive criticism required
Discussion in 'UK Motorcycles' started by Cab, Aug 12, 2010.
  1. Cab
    Cab Guest
    Not sure if this should be OT or not, as it's vaguely on topic.
    I know we've got a few web savvy bods on the group so I'd like some
    feedback on the site I've set up for BRC. Both on the site and on the
    grammar/spelling.
    It's all been done in vi or windows write using a template, so no
    frontpage rubbish has been added.
    You can get to it here:
    http://www.lanoyeraierocamadour.com
    Ta.
    Cab, Aug 12, 2010
  2. Cab
    Buzby Guest
    Sir might like to have a look at using http://validator.w3.org/ to
    straighten out your code - having squeaky clean code will help you on
    many levels - including SEO.
    Pictures - good photos worth more than words in any language.
    Buzby, Aug 12, 2010
  3. Cab
    Salad Dodger Guest
    I appear to be have missed a memo or two.
    I know we don't "do" on/off topic, but in what way is it remotely
    "on"?
    Salad Dodger, Aug 12, 2010
  4. Cab
    Cab Guest
    Already done that and I've seen that I've got a couple of odds and
    sods to sort out. I'm more concerned about the site itself atm.
    There are some pics on there already. More to come, when BRC sends
    them to me.
    Cab, Aug 12, 2010
  5. Cab
    Cab Guest
    BRC is a UKRM lurker nowadays and her business does have a biker
    influence.
    Cab, Aug 12, 2010
  6. Cab
    prawn Guest
    I have a bit of a dislike of pull-down style menus. I know it's a
    bi-lingual site, but can't the menus be organized more accessibly?
    Other than that, jobs a goodun.
    prawn, Aug 12, 2010
  7. Cab
    Cab Guest
    I'll bear that one in mind, ta. One of the remarks I had by BRC was
    that the menus weren't obvious before (I just had the flags) so I had
    to add the word "menu" between the flags.
    Ta
    Cab, Aug 12, 2010
  8. Cab
    Hasse K Guest
    The pictures need to be more integrated in the pages. When describing a room
    I want to see a picture of it on that page.
    Like prawn I don't like the menus either. Can't you have buttons to select
    the language and then links in a column for the different sections instead
    of the pull-down menus.
    Hasse K, Aug 12, 2010
  9. Cab
    I found the para on the front page difficult to scan. Plus, if you use
    "the plan is" you don't need "in the future".[1] :eek:)
    As others have said, the menus are a bit hidden.
    I'm not sure of the Englaish *and* French menus being available. Most
    other sites you select the language and the site is the same whichever
    is chosen.
    On the Gite page "Independant" is spelled incorrectly.
    "Tarif" might be "tarif" in Frog, but it's definitely "tariff" in
    English.
    Some of it I found to be a bit "wordy", where list/bullet points might
    be better. One example is on the Cafe page where the opening times
    would be better separated out from the text, imo.
    [1] One of my current bugbears is people peppering their sentences with
    "going forward" - "Our plan going forward is...". Aaaaaarrrggghhh!
    Lose it.
    CT, Aug 12, 2010
  10. Cab
    Simon Wilson Guest
    I think it's pretty good - though it wasn't obvious to me that the
    'menu' pull down was where to go to get more information. It would be
    nice if there were photos next to the text, rather than all clumped
    together, especially for the room descriptions etc.
    Simon Wilson, Aug 12, 2010
  11. Cab
    Cab Guest
    Okay, I'll look at this.
    Oops/. :)
    Ta for this. The English text was done by BRC, so I've pretty much cut
    and pasted this into the site. I'll pass on your comments though, in
    case she's not reading this.
    Cab, Aug 12, 2010
  12. Cab
    Cab Guest
    Thanks.
    The "menu" thing seems to be a pretty common theme, so I'll need to
    work on this. Initially I'll put an explanation on the landing page
    whilst I figure out ways of modding it.
    Cab, Aug 12, 2010
  13. Cab
    Cab Guest
    A very good point. Thanks.
    Noted
    Cab, Aug 12, 2010
  14. Cab
    SaladDodger Guest
    So lurkers can now make commercial posts by proxy, then? Cool.
    If I'd wanted my screen filled with French "Biker" B&B opportunities,
    I'd have logged on to Facebook.
    SaladDodger, Aug 12, 2010
  15. Cab
    Derek Turner Guest
    Nice to see that the menus work in a text-only browser (and therefore a
    screen-reader) but an invisible (in graphics mode) 'skip over this menu'
    link would help a lot. Check it for yourself in lynx.
    'after all' (pets page) should be two words
    On bilingual page(s) suggest a <div lang="XX"> ... </div> or whatever the
    correct xhtml equivalent is (I only speak html 4). On the front page the
    two paragraphs in EN abd FR need definitely to be in separate <p> ... </
    p> even if you ignore the div advice.
    Otherwise seems to be fast, neat well-ordered site.
    Derek Turner, Aug 12, 2010
  16. Cab
    Derek Turner Guest
    When sitting at home with a 2 meg broadband connection, I agree. Spare a
    thought for those using dial-up in a hotel bedroom or a slow EPRS-only
    phone signal while on the road. If you must incorporate piccies make them
    clickable thumbnails. I might lose patience and look elsewhere if large
    graphics were forced on me.
  17. Cab
    Cab Guest
    Will do. I've noted as well that the menus don't work in Opera on the
    iPhone. :-/
    Ta
    Cab, Aug 12, 2010
  18. Cab
    Oh, in general yes, me too. "Going forward" seems to the current
    mgmt-speak du-jour though.
    Quite.
    CT, Aug 12, 2010
  19. Cab
    don't do the menu like that. Have an overall language selection (two
    flags, d'uh) on the top right of the screen, and then a seperate menu
    for each language sub-site.
    I don't actually like javascript/DIV style menus any more generally
    though - a bit 2003. Plus, you'd get a "fail" for accessibility.
    darsy, Aug 12, 2010
  20. Cab
    Derek Turner Guest
    As an afterthought, I just checked the source of a random Francais page:
    <html xmlns="http://www.w3.org/1999/xhtml" dir="ltr" lang="en-US"
    xml:lang="en">
    OOPS! That really is going to **** up a screen-reader! Probably sound
    like Ted Heath :) The divs with different language declarations will
    help screen-readers too, so perhaps not as optional as I'd first thought.
