Contaminated fuel
Discussion in 'UK Motorcycles' started by BGN, Sep 30, 2006.
  1. BGN
    BGN Guest
    I believe I've got contaminated fuel in the Bandit.
    I don't wish to disclose how I got contaminated fuel in the tank as I
    would be in the running for some shameless & wanton stupidity award.
    If I siphon the remaining fuel out of the tank as best I can and then
    fill it up with new stuff is that likely to help matters, or will I
    have to change the filter, clean the lines and get the carbs flushed
    out?
    BGN, Sep 30, 2006
  2. Depends on what you've contaminated with, how much and whether you've
    run the bike or not. IIRC you could be looking at a lot more than just
    carb flushing.
    Dnc
    B12, ZZR11
    A6 2.5TDi V6 Quattro Sport
    DoetNietComputeren, Sep 30, 2006
  3. BGN
    empty the tank. drain the bowls, hopefully they all have plugs. flush
    tank with a little clean fuel. refill, let carbs refill, shut off tap
    and drain bowls a second time. usually enough
    Hog, Sep 30, 2006
  4. BGN
    Hog, Sep 30, 2006
  5. BGN
    BGN Guest
    Done 100kms with it...
    <sigh>
    BGN, Sep 30, 2006
  6. BGN wrote
    It depends how much diesel you put in there in the first place really
    but if "notalot" then watering it down with petrol is just fine.
    steve auvache, Sep 30, 2006
  7. Yes, much comedy and drama with the silences, but, honestly, how do you
    expect people to help you if you won't fess up to being a fuckwit?
    Dnc
    B12, ZZR11
  8. BGN
    No it didn't need an answer!
    Hog, Sep 30, 2006
  9. Rope wrote
    Yebbut Rob, you are just as much of a prat as BGN, in your own little
    way, so your experiences are not really worth the electrons they are
    transmitted on.
  10. Rope wrote
    True, so very true.
  11. BGN
    catman Guest
    *BOGGLE*
    www.cuore-sportivo.co.uk
    catman, Sep 30, 2006
  12. BGN
    mb Guest
    You'll have to ask Rope what happens when you run your bike with diesel
    in it. 100kms FFS, didn't you know?
    mb, Sep 30, 2006
  13. BGN
    Tunku Guest
    Would diesel screw up a bike engine ? I always thought it was bad the
    other way round, some prawn putting petrol in a diesel engine, in large
    amounts. A mate once filled his Rover 213 with diesel, we drained it,
    filled it with proper stuff and it was OK.
    As an aside, how the hell does one manage to pick up the diesel tap when
    one has a bike to fill?
    Tunku, Oct 1, 2006
  14. In uk.rec.motorcycles, BGN belched forth and ejected the following:
    You filled it up with fucking diesel, didn't you?
    Whinging Courier, Oct 1, 2006
  15. BGN
    BGN Guest
    I did not.
    BGN, Oct 1, 2006
  16. Apparently not. Although I doubt his concerns of contamination are
    likely to cause the symptoms.
    Nick - did you try my suggestions of giving the filter a quick blow?
    (intended).
    Dnc
    B12, ZZR11
    DoetNietComputeren, Oct 1, 2006
  17. BGN
    BGN Guest
    I haven't yet. The bike has been parked up for about a week as I've
    been off around the cun'ree with work and I haven't had chance to give
    it much of a ride yet.
    BGN, Oct 1, 2006
