Cracked screen!
Discussion in 'UK Motorcycles' started by Harry Bloomfield, Aug 16, 2009.
  1. I had a cracked window on the caravan and as these are made from
    acrylic, the same as a bike screen - I thought some of you might be
    interested in what I used to repair my window...
    I did a little searching and found that chloroform is the stuff to use
    to weld acrylic, except you cannot get hold of it these days unless you
    have a very tame chemist. So then I did a bit of research on
    alternative sources of welding chemicals ( it needs to be welded,
    rather glued for close to original strength). I came up with a company
    called Bondrite http://bondrite.co.uk/ and asked them for their
    recommendations. They suggested their WC102 weld cement and a dosing
    tip to enable this to be done (£5 inc delivery).
    The double glazed window had cracked along the hinge, the point of
    highest stress, so I wasn't very hopeful of being able to repair it. In
    fact the solution worked fine. It just dissolve enough of the surface
    to form a good strong weld, then sets very quickly. It is a very thin
    solution, similar to super glue and tracks along the crack by capillary
    action. It will not fill in gaps, so the edges need to be a perfect
    match. The acrylic where the solution has touched it, ends up slightly
    opaque, but this can be polished out.
    I do have a slight crack in my bikes screen and that will be the next
    job.
  2. Harry Bloomfield
    Cane Guest
    Dichloromethane does the same thing and is easily available but I
    wouldn't recommend it for the job. Repairing cracked clear acrylic is
    not easy without a very visible join.
    This might offer some pointers for future work
    http://www.k2a.co.uk/downloads/workshop_handbook.pdf
    Cane, Aug 16, 2009
  3. Harry Bloomfield
    Nige Guest
    Cane wrote:
    Ayup matey, how big can you do the UKRM spangly stickers? I'm doing a
    trackday next week & the racebike looks a bit bland in black.
    Nige, Aug 16, 2009
  4. Harry Bloomfield
    Cane Guest
    610mm is the max width of the cutter but I'll need to check to see
    what material I've got. Is pink okay?
    Cane, Aug 16, 2009
  5. Harry Bloomfield
    Nige Guest
    Well, it wouldn't be my first choice if I'm honest. White could be good, but
    black is useless :)
    I was thinking around 150mm letter height & a few at around 50mm & some at
    30mm?
    I'll pay for the material etc. Spangly would be good, or some other mega
    gash colourscheme, like Lime green
    Nige, Aug 16, 2009
  6. Harry Bloomfield
    antonye Guest
    Send me your address (txt it or thru facebook) and I'll get you
    some stickers in the post.
    antonye, Aug 16, 2009
  7. Harry Bloomfield
    Nige Guest
    Cheers Ant, good luck with the venture btw.
    Nige, Aug 16, 2009
  8. Thanks, interesting read :)
  9. Harry Bloomfield
    Beav Guest
    You're all heart Nige:)
    But have crap taste.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 16, 2009
