creaking/ clicking from forks
Discussion in 'UK Motorcycles' started by mr p, Nov 4, 2008.
  1. mr p
    mr p Guest
    My Blackbird sometimes makes a clicking/ crasking noise from the forks
    when hard breaking. I guess that this could be the bolts on the yokes
    not tightened up enough ( have not checked yet ) Is this
    (potentially ) dangerous ? Could it be something else ?
    mr p, Nov 4, 2008
  2. mr p
    Check head bearings for play and floating discs for rotor wear at the
    mounting points
    Hog, Nov 4, 2008
  3. mr p
    If these bolts were causing the noise, you'd probably be dead by now.
    It's almost certainly the head bearings
    Champ, Nov 4, 2008
  4. .... Is the answer I was about to write out.
    Mungo \Two Sheds\ Toadfoot, Nov 4, 2008
  5. mr p
    My CBR brakes make rattling noises when not applied, but every time I
    check for wear or free play everything seems fine. I'll worry about it
    when I'm sitting in a gravel trap.
    Lozzo, Nov 4, 2008
  6. After I changed my head bearings the front brake made an awful noise when
    not being used. I thought I'd damaged something or not put the bearings in
    properly. Turns out that caliper bolts which are barely finger tight will
    not successfully prevent the caliper from flapping about.
  7. mr p
    mr p Guest
    .. It's always done it and has passed two MOT's since I've had it.. Oh
    and the previous owner replaced (upgraded ?) the head bearing ISTR
    him saying. So is it dangerous ? Easy to replace ? Wait until the fork
    seals need doing at same time ?
    mr p, Nov 5, 2008
  8. mr p
    My guess would be the bolts need greasing, not tightening. Strange
    clicking noises under stress aren't uncommon where you're got a bolt
    squeezing an open-ended clamp shut, i.e. clip-on handlebar & fork
    clamps. Greasing the bolts stops it.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Nov 5, 2008
  9. mr p
    JackH Guest
    They still need adjusting periodically... especially if you've managed to
    pop the odd minger on it.
    My Fazer 600 was particularly good at the latter, and shit at the former as
    a result.
    Do you like involuntary tank slappers?
    If so, leave it as it is and one should be along shortly to catch you out.
    Reasonably so, but they probably just need regreasing / adjusting assuming
    the previous owner did change them, and changed both the cups as well as the
    races themselves.
    Probably not - you'll have found a ditch way before then if said involuntary
    tankslapper catches you out properly.
    On a serious note: if you're mildly mechanically minded, then get a manual
    for whatever it is your bike is and use this as a guide on how to correctly
    adjust / replace the head races etc.
    If you're a bit of a retard when it comes to mechanical stuff, then find
    someone who isn't to check / adjust / regrease / replace the head races.
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    03 VW Passat TDI Sport
    89 Vauxhall Nova 1.3 Pearl
    JackH, Nov 5, 2008
  10. mr p
    mr p Guest
    sounds very plausible, I'm gonna have to get the torque wrench and
    Haynes book together with said grease before the next 'pre-flight
    check' I think ;-) Thanks every one
    mr p, Nov 5, 2008
  11. Using the patented Mavis Beacon "Hunt&Peck" Technique, mr p
    Torque values given will almost certainly be dry. If you grease the
    bolts, and shoot for the book values, you stand a pretty fair chance of
    stripping the threads.
    Wicked Uncle Nigel, Nov 5, 2008
