Cross your fingers folks
Discussion in 'UK Motorcycles' started by Nigel Eaton, Dec 25, 2003.
  1. Nigel Eaton
    Nigel Eaton Guest
    Beagle 2 *should* touch down on Mars at 0254 GMT.
    Anyone still awake is cordially invited to cross everything.
  2. Thank **** they didn't call it Corgi2... might have got savaged by an
    interstellar bull terrier on the way.
    I'll bet someone at Mission Control (wherever that happens to be;
    probably a broom cupboard in Cambridge) just won't be able to resist
    saying, "Ladies and Gentlemen, the Beagle has landed."
    I know I wouldn't.
    Ditto.
    GS 850 x2 / SE 6a
    SbS#6 DIAABTCOD#16 APOSTLE#16? FUB#3
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Dec 25, 2003
  3. Nigel Eaton wrote
    Don't be such a fucking defeatist. That is Best British Engineering
    that we are crashing into that poor innocent planet.
    When do we get pictures and stuff?
    steve auvache, Dec 25, 2003
  4. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, steve auvache
    <G> Not a defeatist in the slightest, but even the team admit a large
    slice of luck is needed. First signal could be received around 06:60
    GMT.
    ****, I hope it makes it.
  5. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Nigel Eaton
    You see, that's the sort of ****-up that could bollix the whole thing.
    06:30, obviously...
  6. Nigel Eaton wrote:
    How much luck is required by now?
    I'll just cross my fingers and hope that the Martian
    gravitational field holds up for the next few hours.
    Old Fart at Play, Dec 25, 2003
  7. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Old Fart at Play
    *Lots* The bio shield has to separate cleanly. The aerodynamics have to
    work, the chutes have to deploy correctly. They need to avoid wind
    shear. The airbags have to inflate at *exactly* the right time. The
    whole shebang has to *not* hit a sharp rock. The airbags have to absorb
    the impact, then separate and roll clear. Then the lander *must* deploy
    its solar cells and get power, or <Rolf Harris Mode> it'll be too weak
    to make it through the night </RHM>.
    And that's just the stuff they're prepared to talk about...
    This is hugely cutting edge, the odds are *way* against it.
    But, hey, it's Christmas, right?
  8. Nigel Eaton wrote
    yeah, right
  9. Nigel Eaton
    Nigel Eaton Guest
    **** off Granddad.
    Oh, and Happy Xmas too...
  10. Nigel Eaton wrote
    I raise a glass in your general direction.
  11. Nigel Eaton
    Sean Doherty Guest
    Aye. I'm not sure if I can stay awake for another hour and a bit, but
    I'll cross things.
    Sean Doherty, Dec 25, 2003
  12. Nigel Eaton
    Sean Doherty Guest
    Bad form etc, but can I predict the headline: "The Beagle has
    landed"?.
    Ta.
  13. To a generation of engineers brought up feasting their eyes on Val
    Singleton's knockers, such a thing is child's play.
    Stickybacked plastic and washingup liquid bottles... to Mars.
    GS 850 x2 / SE 6a
  14. Nigel Eaton
    Cane Guest
    Which is why it's not working.
    Cane, Dec 25, 2003
  15. Nigel Eaton
    A.lee Guest
    No contact on the first pass of the orbiting satellite at 06:30ish, so, they are
    hoping the next pass at around 22:00 will give them a signal that it has
    arrived safely.
    Alan.
    A.lee, Dec 25, 2003
  16. Nigel didn't ask us to cross everything and hope that it arrives safely.
    Merely that it should hit the ground :)
    Anyway it is too much to hope for a signal to reach Earth.
    This is the silent planet, as Mr. Lewis said.
  17. Awww shit.
    Mars must be littered with fragments of spacecraft by now.
    Either that, or the Martians are enjoying their Christmas game of "Earth
    Invaders" and reckon they've got a high score.
    The Older Gentleman, Dec 25, 2003
  18. I'm sure he's a very clever chap, but it's a bit disconcerting to see a
    scientist that looks and sounds like a Wurzel.
    GS 850 x2 / SE 6a
  19. Nigel Eaton
    Naah. He be proper Mad Scientist material, he be. Leave his
    muttonchops alone.
    Pip, Dec 25, 2003
  20. First thing I checked yesterday, just after the champagine.
    Bugger. :-/
    William Grainger, Dec 26, 2003
