Crutch nut.
Discussion in 'UK Motorcycles' started by eric the brave, Nov 5, 2005.
  1. Bloody clutch nut won't come undone on the ZX9R. Pain in the butt...
  2. eric the brave
    Shep© Guest
    Don't know the particular bike but...
    Lather with WD40.Leave a while and then apply heat if possible without
    damage.I use a cheap Aerosol type Paint stripper torch/can/Butane type
    from a D.I.Y shop.
    HTH :)
    Shep©, Nov 5, 2005
  3. eric the brave
    deadmail Guest
    WD40 is bloody useless as a penetrating oil. Use plusgas instead
    deadmail, Nov 6, 2005
  4. What he said.
    And use *lots* of heat.
    The Older Gentleman, Nov 6, 2005
  5. I didn't bother in the end. The new gearbox has a clutch on it anyway.
    It's only do 11K. As I have split the crankcases I can now just drop the
    new stuff in. I can see one selector fork is worn on one side where the
    gear has rubbed away at it. I guess I bent the fork. I will have to be
    careful in future. Must remember the ZX9 doesn't have a slipper clutch.
    eric the brave, Nov 6, 2005
  6. eric the brave
    What he said.
    And use *lots* of heat.[/QUOTE]
    **** that. Just use a 1" drive 110v impact driver. Sometimes working
    in heavy engineering is useful.
    Andy Bonwick, Nov 6, 2005
  7. eric the brave
    Shep© Guest
    Good point.Forgot about ,"Plus-Gas".WD is pretty crappy but most
    people have some form of it to hand and it does work if you use a lot
    of it with heat.
    Shep©, Nov 6, 2005
  8. eric the brave
    MikeH Guest
    Waits for "fire damaged" 9R to come up for sale.
    MikeH, Nov 6, 2005
  9. eric the brave
    MikeH Guest
    He only connected one wire.
    MikeH, Nov 6, 2005
  10. eric the brave
    I've got a 240v - 110v transformer that's usually sitting in the back
    of my van waiting for me to use any 110v power tools that happen to be
    lying around in our site stores at work.
    The only 'tool' I use these days that requires a 240v supply is a nice
    little welding set that will burn 6mm rods all day long.
  11. eric the brave
    antonye Guest
    Dunno about yours, but the centre nut on the 748 is done up to 190Nm,
    which is quite a few grunts.
    I bought a 12v impact gun thing from the Argos sale for 9.99,
    especially
    for such occasions.
    antonye, Nov 6, 2005
  12. By law, all site tools have to be 110V, but that's commonly achieved by
    use of a 240/110 transformer. You're perfectly free to use 240V tools in
    the home or when you're doing work in domestic premises. Quite when a
    job in a house turns into a site job and requires 110V, I'm not sure.
    Whatever; it means bargains can be found. I picked up a stonking SDS-max
    breaker a couple of years back for peanuts because it was 240V and none
    of the site guys were allowed it on site anymore. It's great for me, for
    one-off jobs like flue holes and the like.
    GS850 x2 XS650SE / SE 6a
    Grimly Curmudgeon, Nov 6, 2005
  13. eric the brave
    muddy Guest
    Why can't you use 240V power tools? Don't you use a GFI on the power
    cords?
    muddy, Nov 6, 2005
  14. I've got a sip 1/2" hydraulic one. It removed the sprocket not no problem.
    But the clutch is a different matter.
  15. It says I have to replace some stuff when I remove the nut. So that's
    another reason to leave it alone.
  16. eric the brave
    You can use whatever you like at home and indoors in some factory
    units but the majority of places insist on 110v equipment and a valid
    PAT certificate before you can use any power tools.
    Popular opinion over here seems to be that the 55v hit you'll get
    from a 110v tool is safer than the slight chance your RCD might ****
    up and dish up 240v.
  17. Opinion is divided on this. The 110V range of tools and transformers was
    around long before reliable RCDs (Residual Current Device) [1] and have
    persisted because they're predictable and pretty safe.
    I've come across a few failed RCDs, so they're not failsafe.
    [1] An RCD detects any imbalance between the live and neutral currents
    and clicks off, usually at 30mA.
  18. eric the brave
    muddy Guest
    Isn't it the current that gets you though?
    muddy, Nov 6, 2005
  19. eric the brave
    muddy Guest
    The ones I have found failed after they tripped i.e. could not be reset.
    Yes, the Ground Fault Interrupt thingy does the same thing but at >5mA.
    muddy, Nov 6, 2005
  20. eric the brave
    Eiron Guest
    Eiron, Nov 6, 2005
