I've found distribution board ones failed in the 'on' position. Dodgy as ****, given that they were protecting sockets [1] and in one case an electrick shower. [1]One of those houses had a diy-installed downstairs shower that had never worked; the idiot had installed a mains-pressure shower and fed it from a tank in the loft. The low-pressure switch had prevented the shower from operating. Just as well, really, since the clown who installed it had used 2.5mm cable to carry 40 Amps. Lovely. A house fire just waiting to happen. -- Dave GS850 x2 XS650SE / SE 6a I demand nothing of you except that you amuse me.
Bugger. We don't use those too often here, they are usually built into the plugs. The code now requires an Arc Fault Interrupt protect all bedroom plugs. These are able to detect an arc either in the wiring or plugs and trip the circuit. It's more for fire than sticking a finger in the socket. We do wire size by gage here, 40 amps would be 8 AWG copper. But as you said 'clown' I take it the wire was too small by more than one size. I should post some of my pictures of 'things we have found'. Frightening it is sometimes. Yep, seen that too.
I know that. 20,000 volts an a few uA will give you a start. 20,000 volts at 100 A and you'll be a burnt cinder.
Yes, but since the current would flow according to the voltage applied and the resistance of the body (assuming plenty of supply) there would be less current flowing with 110v than there would be with 240v.
Probably a tab washer and the bolts holding the drum in place, if it's anything like the Ducati. I've never bothered replacing the drum nuts, just made sure they were cleaned, checked and Loctite'd back in place. It hasn't fallen apart ... yet.
It was an 8.5kW shower which nominally would draw 36A - normally 6 sq mm csa would do that, but given the length of run, 10 sq mm csa cable would have ideally been the thing. 2.5 sq mm csa was taking the piss. -- Dave GS850 x2 XS650SE / SE 6a I demand nothing of you except that you amuse me.
Cool. Oh, may I veer? -- Dave GS850 x2 XS650SE / SE 6a I demand nothing of you except that you amuse me.
Understood (now anyway). I simply cannot do maths in my head, I have to get pencil and paper and work it out.
Oops, eh? I do know a 1" spanner dropped across phases will pop the fuses on the pole thus taking out an entire neighborhood. It also makes lots of sparks. And, no it wasn't me, it was my boss.
Apparently so but I think a lower voltage must aid your chances. Obviously I know next to **** all about electrickery but I had to do a 'basic' course covering safety in the workplace a few years ago and it included small bits about power tools.
A 3/4"AF spanner dropped across the terminals of a truck battery makes sparks ... and a whooshing noise as the spanner makes a rapid vertical escape ... then a significant clanging noise as it lands on the car across the road, still glowing with the heat of re-entry. No further use as a spanner, more as a model for pretzels.
I was uncomfortably adjacent, playing a bit part as a temporary stand-in casual cab prop ... and spanner holder. Rumbled!
