"Cubic Litres"
Discussion in 'UK Motorcycles' started by WavyDavy, Oct 18, 2005.
  1. Think density. The air in the car would be pushed to the outside of the
    curve thus increasing the density. The helium (being of lower density)
    would therefore be pushed towards the zone of lower pressure (ie
    inwards of the curve).
    Maybe.
    Phil
    Phil Launchbury, Oct 19, 2005
    #61
  2. I rather liked this ... "Insiders described the filming process as
    particularly messy from a technical and logistical standpoint."
    Véritable Rosbif, Oct 19, 2005
    #62
  3. WavyDavy
    MikeH Guest
    "I was driving round and round the roundabout watching a bubble in the
    fishtank on the passenger seat, so I don't know where the lorry came from."
    MikeH, Oct 19, 2005
    #63
  4. WavyDavy
    Catman Guest
    Not been as many for a while IME. Still, it's nearly time for the
    Hogfather.....
    Wouldn't bother.
    Nah. NP
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 156 TS S2
    www.cuore-sportivo.co.uk
    Catman, Oct 19, 2005
    #64
  5. Wrong. A helium balloon inside a car moves forward upon
    acceleration, backwards on deceleration, and inwards on turns.
    This is because its buoyance against the heavier air always forces
    it _opposite_ to the (pseudo-)gravitational field. IOW it will always move
    opposite to a weight suspended on a string -- 'coz it's a negative weight
    suspended on a string.
    GSX600F, RG250WD, DT175MX-MIA "You Porsche. Me pass!" DoD #484 JKLO#003, 005
    Dr Ivan D. Reid, Oct 19, 2005
    #65
  6. --
    #66
  7. Ur-myth -- Ur being the German for "original" and often used in
    this context. Due to the vagaries of German hyphenation you might see Urin-
    sekt -- meaning a very primitive insect, not some dodgy wine!
    #67
  8. WavyDavy
    Zanziba Guest
    A litre (or liter in USA) is a measure of volume. Therefore cubing it is
    bollocks. You can only cube a measure of length to make a measure of volume.
    Zanziba, Oct 19, 2005
    #68
  9. WavyDavy
    Zanziba Guest
    Ermm, its 1000 cm^3.
    Root cubed of 1000 = 10
    Ergo it is 10x10x10 cm
    #69
  10. WavyDavy
    TimP Guest
    Heh, I guess there may be an element of truth in that.
    TimP, Oct 19, 2005
    #70
  11. WavyDavy
    Snowleopard Guest
    I goofed up and referred to myself as a mong this morning.
    Unfortunately the real mong-deal was right behind me...
    Snowleopard, Oct 19, 2005
    #71
  12. WavyDavy
    Splatter movie...
    platypus, Oct 19, 2005
    #72
  13. WavyDavy
    Eiron Guest
    What subject do you teach? I guess it's not English, Maths or Physics.
    Eiron, Oct 19, 2005
    #73
  14. WavyDavy
    TMack Guest
    Weightless is not the same as massless. If the ballon is *in* the car then
    it will be moving at the same velocity as the car. When the car turns the
    inertia of the balloon will mean that it will tend to keep travelling in a
    straight line. This will mean that the balloon will tend to move *outside*
    the circle described by the centre of the car - in just the same way as
    loose objects tend to roll across a car towards the outer side when turning
    sharply at speed. If you postulate a *massless* balloon then you are in the
    realms of fantasy, not physics.
    Tony
    TMack, Oct 19, 2005
    #74
  15. WavyDavy
    Eiron Guest
    You've not been following this thread too closely, have you?
    Rather than spouting bollocks, get a helium filled balloon and try the
    experiment.
    Eiron, Oct 19, 2005
    #75
  16. WavyDavy
    Zanziba Guest
    Wake up. Join the real world.
    #76
  17. WavyDavy
    Zanziba Guest
    Sniffs bait, swims off...
    Zanziba, Oct 20, 2005
    #77
  18. WavyDavy
    It's the other way, you fool.
    Krusty, Oct 20, 2005
    #78
  19. WavyDavy
    Zanziba Guest
    They're baiting me... Can't you see that???
    #79
  20. WavyDavy
    Zanziba Guest
    #80
Similar Threads
Loading...
