Danger
Discussion in 'UK Motorcycles' started by Dentist, Apr 13, 2007.
  1. Dentist
    Dentist Guest
    I think it only fair to warn those who may use the A548 and A470 out of
    Abergele on the 24th of this fair month, that I shall be bringing home
    the new Sprint ST [1].
    There will be wobbling, bimbling, occasional blatting, but definitely no
    hooning.
    I shall be shitting myself, so keep clear.
    [1] Black, with added black bits.
    That is all.
  2. Dentist
    Catman Guest
    It's actually a beautifully easy bike to ride IME. The power so
    smoooooooth you will be hooning without even realising it
    Good chap.
    Suzuki Bandit 600
    www.cuore-sportivo.co.uk
    Catman, Apr 13, 2007
  3. Dentist
    Good luck, and let us know how you get on. The Sprint ST is now back
    at the top of my "potential buy" list so am interested in any reviews.
    I fancy a red one.
    CT, Apr 13, 2007
  4. Dentist
    Catman Guest
    Apparently my review was crap, but any questions, I'll try to answer
    Suzuki Bandit 600
  5. Dentist
    I guess if you spot any "real world" niggles then they would be good to
    know, but apart from that it's get a test ride and sort out the dosh.
    There appear to be a few unregistered '06 models around for ukp6.5
    which are probably better value then paying full list for an '07 where
    I think the only differences are colours and the "free" panniers.
    CT, Apr 13, 2007
  6. Dentist
    Catman Guest
    Hmmm
    The change up from first can be a smidge clunky. The FI is a bit sharp
    from closed throttle, but that may be me just being ham fisted. I need
    to point my lights down quite a bit as I am dazzling oncoming traffic.
    You have (apparently) to remove the entire headlamp assembly to change
    the main bulb.
    Could be. The panniers are pretty good IMHO. Not cheap though.
    Suzuki Bandit 600
  7. Dentist
    antonye Guest
    This could be a combination of things like a brand new
    gearbox, sloppy gear lever, over-tight chain, misaligned
    rear wheel, etc.
    I would expect it to get better with age as the gear
    wear in and as the maintenance picks up on the minor
    points.
    May be, but I remember Triumph putting out quite a
    few revisions of the fuel map on the TT600, so you
    may get lucky as yet. Besides, it's nothing that a
    Power Commander and a dyno run couldn't sort.
    Heh. Eat Fewer Pies.
    This is pretty common. I have to do the same on the
    748 as it's all pretty compact in there and getting
    enough fingerage in to connect things up is almost
    impossible.
    antonye, Apr 13, 2007
  8. Dentist
    Catman Guest
    Indeed. Apart from the first one. It's also entirely possibly me being
    ham footted. It's OK, but it's quite a long way IYSWIM. The rest are fine
    Well, it's gonna need servicing every 10 weeks and the next one is due
    in about a month.
    Stop you bad man :)
    I did for a long time. I am now well into the healthy weight range for
    my height. Of course, the weight of the panniers doesn't help a lot.
    Nasty. Never owned a faired bike, before. Still, never had to replace
    a main beam bulb, either.
    Suzuki Bandit 600
  9. Dentist
    antonye Guest
    The only time I had to was when I had to
    replace the glass as well :-(
  10. Dentist
    Catman Guest
    Ouch
    still, better than a visor
    Suzuki Bandit 600
