Daytona 955i instrument panel
Discussion in 'UK Motorcycles' started by Chris Sharp, Apr 13, 2011.
  1. Chris Sharp
    Chris Sharp Guest
    The clocks on my Daytona have always been a bit dodgy - missing bars
    from the LCD, unreadable temperature gauge, malfunctioning trip meter -
    but until last week they did at least tell me the speed.
    They don't any more.
    After picking it up from its MOT I went for a celebratory spin around
    Essex, and at some point en route the speedo went completely tits up. It
    now just displays a series of random numbers.
    I suspect it may not have passed the MOT if this had happened on the way
    there...
    Several questions arise from this state of affairs :
    - would any kind soul out there care to tell me what the rev reading at
    30 and 40 in 2nd gear is ?
    - is this likely to be a development of the existing problem or a new
    failure ? What else should I check ?
    - replacement units from Triumph are £700, which is non-starter. I've
    thought about fitting an aftermarket unit (like the Trail-Tech Vapor
    which would cost around £140 with the idiot light surround) but I
    suspect that this will be a technical challenge (wiring / mounting
    bracket etc) - anyone done it or something similar ?
    - I spoke to Triumph-ant who specialise in breaking Triumphs. He reckons
    these are quite rare in undamaged condition, which sounds plausible. He
    thinks he gets a functioning instrument panel in every six months or so
    and that they go for £200. He hasn't got one at the moment but does have
    the unit from a Daytona 600 which he says would plug straight in - the
    only differences would be where the redline is printed and the absence
    of a specific 955i graphic. I'm sceptical - would anyone care to comment
  2. Chris Sharp
    Mark Olson Guest
    I've fitted a couple of Sigma bicycle speedometers to motorbikes,
    they work very well up to 186mph or 300km/hr[1], have large enough
    digits to be easily readable, with a trip meter, odometer, max speed,
    average speed, and clock function. Piece of piss to fit, but of
    course have no lighting. But I've heard tell there are such things
    as LED lamps that work off 12V and if you're determined, or have a
    friend with some electrical nous, it should be the work of only a
    couple of hours to molish some sort of bracket and wire it up to a
    switched power source on the bike.
    [1] claimed on the specs, never tested by me
    Mark Olson, Apr 13, 2011
  3. Chris Sharp
    It would, speedo's not part of the MOT.
    Given my experience with that lot, I'd avoid like the plague. Give
    Trevor at http://www.triumphparts.gbr.cc/ a call.
    Krusty, Apr 13, 2011
  4. Chris Sharp
    Simon Wilson Guest
    Why not? Speedo's not tested in the MOT afaik.
    Simon Wilson, Apr 13, 2011
  5. Chris Sharp
    TOG@Toil Guest
    Construction & Use regs demand a functioning one, though.
    TOG@Toil, Apr 13, 2011
  6. Chris Sharp
    Simon Wilson Guest
    For mopeds/under 50cc they had to function "if fitted" IIRC. When the
    speedo cable broke on my Fizzie, I removed the entire speedo so as to
    (cleverly, I thought) stay within the law.
    I was the only one in my peer group to take a moped test and so could
    carry a pillion which at least once resulted in a pull by local plod. He
    wasn't too impressed by the lack of speedo and threatened to do me for
    it. Never did though.
  7. Chris Sharp
    TOG@Toil Guest
    <snip>
    Buy a used Daytona, transplant the clocks, and flog the rest of it as
    spares.
  8. Do tell.
    The Older Gentleman, Apr 13, 2011
  9. Chris Sharp
    Catman Guest
    If it's showing random (whole)numbers, doesn't that indicate the
    sender's fucked. My Triple did the whole 'numbers totally unrelated to
    actual speed thing' when the optical encoder wheel (IIRC) broke up.
    #www.cuore-sportivo.co.uk
    Catman, Apr 13, 2011
  10. Chris Sharp
    They're the bunch who were trying to fit one of the 147bhp Daytona
    engines to the Tiger. Weeks turned into months, lots of excuses, then
    when I told them I was going to do a chargeback through the card
    company to get my 500 quid deposit back (because the 6 month cut-off
    was looming), they said the mechanic had been badly burnt in a workshop
    fire, & they couldn't do the conversion after all as the airbox
    wouldn't fit.
    Krusty, Apr 14, 2011
  11. Chris Sharp
    Chris Sharp Guest
    I did wonder if that was the case - but I wasn't sure of the terminology.
    It might be a lot cheaper to fix that and at least get back to where I
    was before than try to replace the whole dash...
    Ta !
    Chris Sharp, Apr 14, 2011
  12. Chris Sharp
    Catman Guest
    If that's what it is, it will be *much* cheaper.
    De nada. I could be very well wrong, given that no one else has
    mentioned it, but if the symptoms fit....
    Catman, Apr 14, 2011
