Dead K1200s
Discussion in 'UK Motorcycles' started by Jeremy, May 12, 2010.
  1. Jeremy
    Jeremy Guest
    Not been used for 10 days. Plugged in the optimate today and none of the
    lights on it, er, lit.
    Strange I thought.
    Popped the key in the ignition. Nothing. No bleep, no lights, er, lit.
    The famed BMW reliability... anyone any [1] suggestions?
    [1] angle grinder, shit in the carbs and gixxer thou' not permitted
  2. Jeremy
    zymurgy Guest
    It's fucked, give you £100 for it ..
    Paul.
    zymurgy, May 12, 2010
  3. Jeremy
    Nige Guest
    Totally fucked battery & i reckon you must have left parking light on.
    Odd
    Nige,
    Land Rover 90
    Yamaha R1
    Range Rover Vogue
    Nige, May 12, 2010
  4. Jeremy
    The Odyssey battery in my RS seems to have died. I have it on the Optimate
    but I'm not hopeful. Which is a ****. Expensive and meant to last forever.
    It did 6 months in the IoM airport carpark without complaining.
    Hog, May 12, 2010
  5. Jeremy
    Hook some jump leads up for a minute or two then try the optimate again.
    Krusty, May 12, 2010
  6. Jeremy
    Nige Guest
    I remember, they did have a problem with a batch of earlyish batteries
    going dead for no reason.
    My battery went tits, i took it back, they fit a new one & it survived 6
    months outdoors in shitty winter weather without a charge & started
    first time.
    Jump it, bung a new battery on it
    Nige, May 12, 2010
  7. Jeremy
    Jeremy Guest
    Hmm... got out my multi-meter. That was dead too! So replacement battery
    for the multi-meter and popped off the battery cover.
    3.8v
    I will assume that I did leave the parking lights on though am amazed
    that I didn't notice as we're in and out of the garage several times a
    day. I *hope* it was the lights anyway....
    I have the BMW "optimate" which plugs straight into the accessory
    socket. Bizarre thing is that it wouldn't register *anything* yet when I
    put my original Optimate directly on the battery terminals, it
    immediately set off the alarm and started charging.
  8. Jeremy
    Salad Dodger Guest
    Same thing on the Wing a while back - stuck it on a normal charger,
    and it's been fine ever since.
    Salad Dodger, May 12, 2010
  9. Jeremy
    if the odyssey is totally flat then an Optimate[1] won't recover it as the
    power output is too low to overcome the initial internal resisitance. If
    you look here http://www.odysseybattery.com/chargers.html you will see the
    minimum output is 6A
    This is one of the recommended chargers for AGM batteries
    http://www.mdsbattery.co.uk/shop/productprofile.asp?ProductGroupID=2655
    an alternative CTEK here http://www.tayna.co.uk/ODYSSEY-PC680-P3107.html
    FWIW, I've never used anything other than a mk1 Optimate, but I've never
    let the battery go totally flat: one top up after the usual 3 month lay off
    to replace what the LCD clock has used and away it goes. Been the same for
    5 winters now.
    [1] although the latest mk4 version claims to work with all 12V batteries
    inc AGM. possibly so as it claims 33% more output. I'd still get the CTEK
    if you are going to go the deep discharge route.
    wessie, May 12, 2010
  10. Jeremy
    Kevin Weller Guest
    OTOH our FJ, which has been on an Optimate all Winter, wouldn't turn
    over despite the lights on said Optimate saying everything was fine.
    I then plugged in a Oxford Maximiser which, after a while, told me the
    battery was 'weak'. I think the fact that the battery was dry may have
    had something to do with it...
    I have to say I'm not at all impressed by the Optimate 3SPs we have as
    none of them seem particularly reliable and they are gradually being
    replaced.
    Kevin
    Kevin Weller, May 12, 2010
  11. Jeremy
    ian field Guest
    Now you've got the battery charging it might be worth checking if the first
    charger now starts - could be a dud.
    ian field, May 12, 2010
  12. Jeremy
    I have one of those and I'm also less than impressed with it. My
    housemate's cheapie C-Tek charger, that he got free with a magazine
    subscription, has recovered three previously dead batteries that my
    Optimate 3SP wouldn't touch. I'm buying a C-Tek and changing the plugs
    for Optimate ones.
    Lozzo, May 12, 2010
  13. Jeremy
    Jeremy Guest
    Good thought - just disconnected the optimate and connected the BMW-
    specific one - it is now charging on the BMW one...
    So whoever said that perhaps with a completely dead batery, the BMW one
    could't "see anything" maybe was true.
  14. Jeremy
    ian field Guest
    AFAIK most/all electronic chargers sense a small voltage to confirm correct
    polarity before energising a relay to connect the charger circuit to the
    output leads.
    It compares the battery terminal voltage with a small reference voltage to
    verify the positive lead is connected to the positive terminal, there
    probably isn't any particular standard for the reference voltage but most
    chargers I've seen its somewhere close to 2V - 3.8V seems a bit high IMO but
    the manufacturer may have their reasons for specifying that.
  15. Jeremy
    ian field Guest
    Most of the time my optimate chargers do what is expected of them, but a
    while back someone gave me a UPS for my PC that contained a pair of 12V/12Ah
    SLAs, I decided to give both batteries a refresher charge on the optimate
    before trying out the UPS.
    Both batteries charged and both batteries reached the green LED "battery
    good" indication, but the UPS refused to start, one of the batteries
    couldn't even light an indicator bulb.
  16. Jeremy
    A cheers, Bee wants her Opti back anyway
    Hog, May 13, 2010
  17. Jeremy
    in a simple logic gate circuit you need a voltage >3.5V to give you a
    definite high. Similarly, only a voltage <1.5V will give a definite low.
    Anything in that 2V range in the middle will be floating and the output is
    indeterminate, depending on the total impedance of the components in the
    circuit.
    Of course, the manfacturer could design a more sophisticated circuit but
    probaly won't bother on grounds of cost.
    wessie, May 13, 2010
  18. Jeremy
    Jeremy Guest
    Dead last night, barely alive this morning. Had it on the BMW
    "optimate" overnight and this morning it didn't have enough to turn the
    engine more than once.
    BMW wants £100.71 for the replacement. It is apparently "glass mat"
    technology.
    My local place can supply a Dynavolt 12ah for £59.98 - YTX14BS
    I care about the £40 difference in price, should I care about the
    difference between "maintenance free with lead acid pack" and "glass
    mat"?
    Jeremy, May 13, 2010
  19. Jeremy
    Dunno. WTF is "glass mat"?
    CT, May 13, 2010
  20. Jeremy
    Jeremy Guest
    Well I thought it prevented those circles from appearing on your coffee
    table.
