Dear Santa
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Dec 13, 2009.
  1. Wicked Uncle Nigel
    That's like doing a Max Biaggi in a jet fighter... amazing
    Lozzo, Dec 14, 2009
    #41
  2. Wicked Uncle Nigel
    certainly is, and I don't normally get impressed by aircraft gubbins.
    darsy, Dec 14, 2009
    #42
  3. Wicked Uncle Nigel
    Are they all between the pilot's legs these days?
    At least some used to be at either side of the pilot's head - they
    were the handles to a sort of protective hood that the pilot pulled
    over his head which also activated the eject mechanism.
    Pip Luscher, Dec 14, 2009
    #43
  4. I think the airframe must be made out of whatever material the pilot's
    balls are made of.
    Kevin Gleeson, Dec 14, 2009
    #44
  5. Wicked Uncle Nigel
    jgh Guest
    It wasn't when I bought it.
    And the version of that story in the book is far less flowery.
    jgh, Dec 14, 2009
    #45
  6. Wicked Uncle Nigel
    Catman Guest
    There used to be options, above and below. ISTR some either side of the
    seat as well. This is partly due (I was told) to there being no way of
    knowing what the aircraft's attitude would be, and thus whether the
    pilot would be able to resist the g to get to a single handle, IYSWIM
    116 Giulietta 3.0l Sprint 1.7 GTV TS 156 V6 2.5 S2 GT 3.2 V6
    www.cuore-sportivo.co.uk
    Catman, Dec 15, 2009
    #46
  7. I wonder whether someone has come up with a zero/zero when the
    aircraft is inverted. I think you'd just have a second or so to
    realise your time was up.
    Kevin Gleeson, Dec 15, 2009
    #47
  8. Wicked Uncle Nigel
    Catman Guest
    Martin-Baker have come close ISTR.
    #48
  9. M-B experimented with downward ejection for helicopters with a squirt
    you sideways and then up.
    Lockheed and Boeing tried explosive retaining bolts on the rotor head
    before ejection.
    Mick Whittingham, Dec 15, 2009
    #49
  10. On Tue, 15 Dec 2009 16:10:02 +0100, Mick Whittingham
    And Kamov has implemented it in a production machine, Ka-50 (Hokum/Black
    Shark).
    Leszek Karlik, Dec 15, 2009
    #50
  11. Wicked Uncle Nigel
    I've seen a film clip of an ejector seat fired upside down: it had a
    vectored thrust motor and righted itself and flew above the launch
    point in a remarkably short distance.
    Pip Luscher, Dec 15, 2009
    #51
  12. Wicked Uncle Nigel
    Some early Russian ones at least had a loop between the legs. There
    was an incident where a side-by-side two seater had two sticks: one
    for the pilot and a shorter one for the copilot/navigator/whatever.
    At rest, powered down, the control surfaces drooped to full climb,
    i.e. sticks fully back.
    Unfortunately, on one occasion, the copilot's ejector handle got
    looped over the stick and as the hydraulics powered up, the stick
    pulled forward....
    There's also the effect of the supersonic slipstream, but modern seats
    are designed to produce a shockwave in front of the occupant. They
    have aerodynamic devices to keep the seat facing the right way too.
    For details about what the force of the airflow can do to an
    unprotected human, read about George F. Smith's ejection in 1955 at
    Mach 1.05.
    #52
  13. Except 'drooped' elevators would be in the full nose-down position,
    stick forward...
    If they were canards it may be different.
    Sean Hamerton, Dec 15, 2009
    #53
  14. Wicked Uncle Nigel
    Or all-moving tailplanes, which all remotely modern jets use. Note I
    said 'control surfaces' not 'elevators'
    #54
  15. Wicked Uncle Nigel
    antonye Guest
    I was thinking Skunkworks, but might have to get a copy of that too.
    antonye, Dec 15, 2009
    #55
  16. Wicked Uncle Nigel
    Beav Guest
    Or even tailererons, which , like an all moving taill. tend to have slightly
    more weight in advance of the pivot point to aid tailplane stability and
    reduce the forces needed to move it in flight. This has the knock-on effect
    of making them droop nose down (back stick) when the plane is unpowered and
    in its flaccid state.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Dec 16, 2009
    #56
