Diagnosis?
Discussion in 'Motorcycle Technical Discussion' started by Mike, Mar 12, 2005.
  1. Mike
    Mike Guest
    I have an 84 virago 700, got it about 2 years ago very cheap. The bike
    has aftermarket pipes on it, (which i understand will increase airflow
    due to reduced backpressure, and i'm not sure if the original owner
    rejetted the carbs to compensate for this, or if it would be neccesary
    in this case), but other than that i think it's stock. Anyway, in the
    past i've had trouble running the bike at 60+ miles per hour for an
    extended period of time. Generally after running at a higher rate of
    speed for a while the bike pops and fizzles it's way down to nothing
    and i end up sitting on the edge of the freeway for ten minutes before
    it will start again. Lately it's also been extremely hard to start, it
    has to turn over about 8 times before it will finally purr to life.
    Any ideas what could cause behavior like this. Any input is much
    appreciated.
    -Mike
    Mike, Mar 12, 2005
  2. What he said.
    The Older Gentleman, Mar 12, 2005
  3. Mike
    Bill Walker Guest
    Kinda hard to diagnose without actually seeing what it is doing.. Could be
    that running the motorcycle for a while produces a kind of vapor lock ..
    Check the gas tank vent hole.. If that puppy gets clogged, you might be
    experiencing a vacuum build up in the tank which would cause the gas to not
    flow from it.. Damned near drove me nuts, one time.. Sheesh.. I was ready to
    commence a carb rebuild..
    Bill Walker
    Irving, Tx..
    Bill Walker, Mar 12, 2005
  4. Mike
    Ken Abrams Guest
    This sounds like a plugged fuel tank vent OR a restricted fuel line (i.e.
    plugged filter or screen).
    OTOH, it could be running WAY lean causing it to overheat on long runs.
    That could be a factor in hard starting too.
    If you got it real cheap, maybe it's time to invest a little $$$ in a good
    mechanic.
    Ken Abrams, Mar 12, 2005
  5. That was my first thought....fuel starvation due to blocked tank vent.
    Stephen Robinson, Mar 14, 2005
  6. Mike
    lubecki Guest
    Do your problems happen mostly in colder weather? If so, it could be
    carb icing. Cold, humid air enters the carb, condenses and freezes
    (this can happen quite a bit above freezing, too, because fuel
    evaporation cools down the walls of the carb to below freezing). This
    buildup of ice blocks fuel from getting to your engine. When you pull
    over and wait for ten minutes, engine heat eventually melts the ice and
    the bike will start again.
    Unfortunately there is no easy fix for this, but improperly set up
    carbs can certainly make the problem worse.
    -Gniewko
    lubecki, Mar 14, 2005
  7. That and the fuel filters.
    If you can loosen the cap and it gets better it's the vent.
    You can also disconnect a fuel line, put a quart bottle under
    it, turn on the tap and measure how long it takes to fill the
    bottle. You ought to be able to fill a quart bottle in maybe
    5 minutes or quicker.
    Rob Kleinschmidt, Mar 14, 2005
  8. Mike
    Mike Guest
    Thanks to you all for your input so far, this usually happens
    midsummer, or after the bike has warmed up a lot. It could be a
    problem in the fuel line as you have suggested, or possibly in the
    venting, i went ahead and changed the fuel filter, and we'll see what
    that does, i'll take a look at the fuel cap for proper ventalation this
    afternoon too. As far as the hard starting goes, that may have
    improved with new plugs torqued to the correct specs. That was a new
    issue just this spring, hadn't had any trouble in the past. Thanks
    again. Any more advice is appreciated.
    Mike, Mar 14, 2005
  9. Mike
    Bownse Guest
    depending on the age of the bike, your fuel feed lines might be old
    enough to collapse some when under pressure.
    Mark Johnson, Ft. Worth, TX
    http://www.bikes-n-spikes.org
    "Some people will tell you that slow is good - and it may be, on some
    days - but I am here to tell you that fast is better. I've always
    believed this, in spite of the trouble it's caused me." - Hunter S. Thompson
    Bownse, Mar 14, 2005
  10. Besides any in-lin filters, there's probably a screen inside the
    tank that ought to be looked at.
  11. It's an ancient Virago with a gravity fuel feed, so this can be ruled
    out.
    The Older Gentleman, Mar 14, 2005
  12. I'm *still* with you on this one.
  13. Mike
    Calgary Guest
    out.[/QUOTE]
    I am not so sure about that O.G. The Virago 1000 has a fuel pump and
    although the tank for a 700 is different than the 1000 I thought both
    of them had fuel pumps.
    Of course I could be wrong.
    Don Binns
    2000 - Yamaha Venture Millennium Edition
    84 - Virago 1000
    You start with a bag full of luck and an empty bag of experience.
    The trick is to fill the bag of experience before you empty the
    bag of luck
    http://www3.telus.net/public/dbinns/reeky.htm
    http://www3.telus.net/public/dbinns/banff.htm
    http://www3.telus.net/public/dbinns/kananaskis.htm
    http://www3.telus.net/public/dbinns/walkercalgary.htm
    http://www3.telus.net/public/dbinns/calgarybrowning.htm
    Calgary, Mar 14, 2005
  14. Mike
    Mike Guest
    If it's valve clearence that's causing the problem why doesn't it
    happen anytime the bike is hot, why only when i'm traveling at higher
    speeds? I do probably need to check them, but i'm curious why the
    specific speed is causing the issue. For instance i can drive 55
    forever without the bike taking an issue, but when i top 65, thats when
    it starts acting funny. Thanks again for your input.
    Brune
    Mike, Mar 15, 2005
  15. I agree that it sounds like a fuel flow/venting problem. Here's a
    couple of things to try.
    Start off with the gas tank almost full, and disconnect the fuel line
    from the petcock to the carbs. Run this line into a gas can or other
    suitable container, and turn the petcock to the "PRIME" position, or
    the "ON" position if your petcock doesn't have a "PRIME" position.
    At this point, the gas should flow freely out of the fuel line. This
    is a *much* higher flow rate than your carbs could ever draw with the
    engine running, so if you have a flow problem or a venting problem, it
    should show up now.
    If the fuel isn't flowing out as fast as you think it should, try
    opening up the gas cap and seeing if the flow rate speeds up. If it
    does, you definitely have a venting problem. If the flow rate stays
    slow even with the gas cap opened, you might have a partial blockage
    in the fuel filter, fuel hoses, or the petcock itself.
    Hope this helps,
    Scott Gardner, Mar 15, 2005
  16. I had a 750 Virago - same bike, 1982 model - and that was definitely
    gravity feed.
    The Older Gentleman, Mar 15, 2005
