Diesel in the tank
Discussion in 'UK Motorcycles' started by Ian White, Feb 12, 2007.
  1. Ian White
    Ian White Guest
    Hypothetically speaking ...
    If someone was daft enough to put diesel in their tank (full tank from
    empty) and try to start their bike this morning (until the battery was
    almost drained) before they sniffed the tank and checked, what would
    be the best case scenario/best course of action for getting it fixed?
    <fx: whistles innocently>
  2. Ian White
    It is better this way than putting petrol in a diesel.
    Drain your tank and charge your battery. Don't cause an explosion.
    Drain the carb float bowls with the drain screws. Replace any fuel
    filters.
    Refill the tank with clean petrol and run it through the carb bowl
    drains until clear. If you're keen you could take the plugs out and
    spin it on an open throttle, but I'd leave the choke off and open the
    throttle, then spin it over to get rid of most of the diesel.
    Let it all calm down a bit and the battery get fully charged, then try
    to start it as normal.
    Pip, Feb 12, 2007
  3. Ian White
    antonye Guest
    FFS put a rag or similar absorbing material over
    the plug hole when you do this, as playing "catch
    the flying liquid" is not really a game I'd
    recommend...
    antonye, Feb 12, 2007
  4. I can't remember seeing an "it runs!" post, did you finish it?
    mike. buckley, Feb 12, 2007
  5. Ian White
    Paul - xxx Guest
    I don't think they're meant to be that colour ... or was it [1] a
    Kawasaki Triple? ... feckin' oiled plugs almost every trip out ;)
    [1] Rhetorical.
    Paul - xxx, Feb 12, 2007
  6. Ian White
    Ian White Guest
    I won't ask you how you know.
  7. Ian White
    Ian White Guest
    Cheers for that (all) ... but I appear to be a fuckwit's fuckwit. ...
    I sniffed it this morning, after it wouldn't start, and didn't get
    that petrol head-rush, so I just presumed it was diesel, hence the
    post. In my defense I was jet-lagged on Friday when I filled up at a
    different station to usual. I'd filled up my little bro's car at the
    same station the day before[1] and he pulled up to the diesel pump and
    had to change. I appear to have put 2 and 2 together and come up with
    22.
    I got SWMBO to sniff my hole(*) when she got back after lunch and she
    thought it was petrol. So I dripped some onto the drive and managed to
    set fire to it easily enough, so it appears it *is* petrol.
    I can therefore only presume it's an electrical fault (bike was fine
    on Friday). I've tried it again since determining fuel and the bike's
    turning over but not firing. There was occasional backfires so I know
    fuel's getting into the pipes. Possibly main distributor lead(?) as
    all fuses are intact (including immobilliser fuse) and there was no
    hint of it firing up, not even on one cylinder. The backfires were a
    good second or so after I'd stopped turning it over - dunno if that
    indicates anything.
    Perhaps I should point out here that it's a Suzuki GSX750F ... and
    various sorts of cheese have *definitely* been used in its
    manufacture.
    [1] Long story involving snow and Newark -> Brum via Glasgow.
  8. Ian White
    JB Guest
    Were the guides that shot? How many miles on it?
    Have you spoken to 'The Doc' at FJOC yet? He may have a s/h set of barrells
    and pistons.
    You won't need a 1300 kit if the rest of the bike is standard. FJ1100 carbs
    and inlet rubbers and a decent pair of race cans will help. The FJ1200 was a
    bit 'gelded' in the induction department compared with the 1100.
    JB
    JB, Feb 12, 2007
  9. Ian White
    Monkey Guest
    Why so, out of interest? I know diesel in a petrol engine will pretty much
    instantly kill a catalytic converter, if it's got one.
    Monkey, Feb 12, 2007
  10. Ian White
    Granted - anything but finest unleaded will **** the guts out of a
    cat. Let's assume this is a bike and it doesn't have a cat, though -
    and if it had, tbh the first time that'll be a problem is when it
    fails the MoT test.
    Assuming a diesel car or similar - the pump that meters the diesel and
    distributes it to the injectors, the funny-shaped bit of metal with
    all the pipes coming out of it that lives under the bonnet - well that
    is finely calibrated and it runs at high rpm to produce a high fuel
    pressure. It is lubricated by the oily component of diesel. Petrol
    doesn't have an oily component.
    If the metering pump doesn't go **** immediately then it will, in
    short order. Replacement <sucks teeth> somewhere between a grand and
    a couple? I dunno any more, I don't keep up with prices.
    Let alone the damage caused to the engine itself by suddenly getting a
    big charge of highly combustible fuel, that will likely go bang just
    on the heat in the cylinder let alone the compression. Pre-ignition
    or detonation fucks everything. Top end and bottom, could well be
    cheaper to fit a new engiine.
    A fucked cat is chickenfeed in comparison.
    Pip, Feb 12, 2007
  11. Actually, LRP is OK, in smallish doses.
    During the fuel blockades, five or six years ago, my employer's fleet
    was all Vauxhalls. There was no unleaded around, but plenty of LRP[1].
    We asked Shell if LRP would poison a cat. The answer, from their
    chemists (who we asked): yes, but i'll take 50,000 miles.
    So we asked Vauxhall. They prevaricated, but eventually said that cars
    run on LRP wouldn't be covered by warranty.
    The Older Gentleman, Feb 12, 2007
  12. I've got a cat on my diesel.
    They do some wicked things to clean it while you're driving. It involves
    hooooge[1] temperatures coming out your exhaust.
    [1] Narf*ck accent.
    Mick Whittingham, Feb 12, 2007
  13. Ian White
    Dentist Guest
    Pip wrote;
    This is a myth, somewhat encouraged by suppliers of new cats. A cat that
    was originally in good condition will recover to 85-95 percent of it's
    original efficiency after eating a gallon of diesel.
    It'll take a week or three with average driving, but a tankful of
    petrol will do it, and with greater efficiency, at constant motorway
    speeds.
    You may need to replace the Oxygen sensor, but even these recover in the
    majority of cases.
    I have been lucky enough to be allowed to test the above at other
    peoples expense.
    Dentist, Feb 12, 2007
  14. Ian White
    antonye Guest
    It was all Champ's fault anyway.
    antonye, Feb 13, 2007
  15. Ian White
    antonye says...
    I don't think we need to hear about Champ's flying liquid.
    Lozzo
    Suzuki Bandit 600S (Green with added shit bits)
    Yamaha SR250 Delusion (It's "Special")
    I'm a modern man, I don't mind buying tampons, but apparently they're
    not a proper Valentine's present
    Lozzo, Feb 13, 2007
  16. Ian White
    run on LRP wouldn't be covered by warranty.[/QUOTE]
    I do wonder how much leaded fuel it actually takes to poison a cat
    enough to render a vehicle an MOT failure. Admittedly that's not much
    of an issue nowadays.
    I remember the fuel shortages and the local petrol station attendant
    saying mournfoully "sorry, all we've got is leaded".
    "No worries" I replied, before filling my elderly pre-cat car up with
    the stuff.
    Pip Luscher, Feb 13, 2007
  17. Ian White
    MikeH Guest
    Is the cat ok if you don't check it?
    MikeH, Feb 13, 2007
  18. Ian White
    Providing it was manufactured by Schrodinger Industries it will be
    fine.
    Pip, Feb 13, 2007
  19. Ian White
    Roger Hunt Guest
    I use Schrodinger valve caps myself.
    Roger Hunt, Feb 13, 2007
