Disc Skimming
Discussion in 'UK Motorcycles' started by Hog, Mar 16, 2011.
  1. Hog
    Hog, Mar 16, 2011
  2. Hog
    Catman Guest
    Indeed
    Very cunning
    Wonder how it deals with fucked bearings
    #www.cuore-sportivo.co.uk
    Catman, Mar 17, 2011
  3. Hog
    <slap>
    Hog, Mar 17, 2011
  4. Hog
    SIRPip Guest
    "Cages, not cars"?
    I wonder how it deals with discs fitted with splashplates on the back,
    that cover the rear face of the disc and can take some time to remove
    as you'd have to remove the disc first, at least.
    Aren't discs generally refaced by surface grinding, which is held to be
    more accurate than skimming?
    SIRPip, Mar 17, 2011
  5. Hog
    Adrian Guest
    Aren't car discs normally just lobbed away, since there's rarely much
    permissible wear (2mm for the vented fronts on mine) anyway, and they
    tend to be dirt cheap (£45/pr, pattern)?
    Adrian, Mar 17, 2011
  6. Hog
    Simon Wilson Guest
    Would be my take on it also. Despite all the electronic
    lining-up-gizmotry, seemed to be nearly as much faff as lobbing on a new
    set of discs. You'd have to sell the service at a fair bit cheaper than
    a new set of discs, or why would anyone bother. I'll bet it takes rather
    a lot of discs before you've got your money back. There might be a
    market for refurbing ceramic discs, I bet it can't do those.
    Simon Wilson, Mar 17, 2011
