Gather round brothers, for I must rant. I bought a 91 SOJawa 350, in "running order". Now for 200 quid I realise that some fettling will be required and any bike will showing signs of its age after 17 years. It actually scrubbed up quite well, the dud battery was sort of expected and one duff condenser was not unreasonable. Still difficult to start until I rescued the oily rag from inside the airbox. This is getting omninous. Out for a quick test ride and the brakes and handling are shite. 45 psi in both tyres and the TLS front brake is so badly adjusted that only one shoe is doing any work - Idiots but simple fettling. Try again, handles and brakes better but poor performance and tinny clatters from the left cylinder. Some clown has fitted a japanese carb with a smaller bore. Ignition timing should be 3mm BTDC not bloody 15. Off with the left head and barrel, the small end feels a bit slack. Stuff rags around the crankcase opening and out with the circlips and pin. Out come 22 - count them - needle rollers. There should be 28 in there so someone has opened it up before. Big question - where are the missing 6 needles ?. Now I will have to split the crankcase which means a complete engine strip because it is obvious where the little blighters have gone. AAAAARRRRGGGGHHHHHH. Does anyone want a shite old Jawa ?.
