Dodgy 125 headlights
Discussion in 'UK Motorcycles' started by Milo Thurston, Sep 19, 2005.
  1. I finally obtained a 125 ('99 Suzuki GS125) for the SO, and took her out
    to practice night riding last night. I thought the headlights looked a
    bit feeble, but oncoming cars kept flashing despite her insistence she'd
    dipped them.
    I checked later, and it seems that all that the dip switch does is turn
    the blue light on the control panel on and off - it has no effect on the
    brightness (which appears to be permanent main beam).
    Is this likely to be a dodgy bulb, or something else?
    Also, does anyone know of a good second-hand parts supplier for these
    bikes?
  2. Milo Thurston
    Most likely some fuckwit's wired it on all the time to save buying a
    new bulb. Remove the bulb and check for fusewire or similar wrapped
    around the connectors. If not, check it's the correct bulb.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Sep 19, 2005
  3. Thanks - I'll have a fiddle with it tonight.
    Other than that (and the broken trip-counter reset knob) it seems
    OK, and she likes it because it is red.
