Don't, just don't, OK?
Discussion in 'UK Motorcycles' started by WorkTOG, Dec 5, 2003.
  1. WorkTOG
    WorkTOG Guest
  2. WorkTOG
    Ginge Guest
    Ginge, Dec 5, 2003
  3. Ginge () wrote:
    : I'm tempted to send an e-mail asking where the camchain is on a VF. :)
    The VF has cam-chains. It's the VFR that has gear driven cams.
    Blair.
    '97 CBR600
    B.G. Finlay IT Services, Dec 5, 2003
  4. WorkTOG
    YTC.
    darsy, Dec 5, 2003
  5. WorkTOG
    Steve Parry Guest
    Steve Parry, Dec 5, 2003
  6. WorkTOG
    *snort*
    In addition to their made-of-Japanese cheese camchains and tensioners,
    the VFs were afflicted with massive camshaft and cam lubrication
    problems, coining the term "chocolate cam". Honda were still giving
    away, FOC, replacement cams to VF owners up until 1999 or thereabouts.
    The engine is just a shitter - it was very powerful for its time, and
    there are some clever bits of "innovative" design all around the bike
    - but some absolutely doggish qualities that make the whole thing a
    poor proposition.
    Pip, Hairy Gfedcker.
    RF 900RR, Ruff and Rattly. Honda VF750FA under the apple trees ...
    WS* DFWAG#0 IbW#27* DIAABTCOD#15 GP#0 EKP FUB#4 MKA+E#3
    ANORAK#8 MIRTTH#15 BOTAFOT/F#47/34a BONY#13 KotMIB# <space>
    UKRMRM#14 TWA#2
    Pip, Dec 5, 2003
  7. WorkTOG
    Timo Geusch, Dec 5, 2003
  8. WorkTOG
    Klaatu Guest
    I had one of these. It was quick quick. They crash well.
    Klaatu, Dec 5, 2003
  9. WorkTOG
    [VF750]
    I loved mine - until it went wrong. It had obviously been
    well-crashed by previous owners and still wanted more. I dunno if the
    anti-dive worked, but nothing seemed fucked. The brakes were good, as
    was the suspension - and as you say, it was quick. And comfy. I was
    well happy with it, even with the 16" front wheel being a bit tucky -
    It started to overheat and spit coolant out of the expansion tank
    overflow if I exceeded 65 mph for more than a couple of minutes. So I
    went through all the pain of carrying out hot, cold, wet and dry
    compression tests and leakdown tests. Twice. Nary a problem showed.
    I flushed the cooling system, checked the water pump - everything I
    could think of, to no avail.
    That's why it is still parked under the apple trees and looks set to
    remain there ... until I cut it, shut it and squeeze a Bandit 1200
    motor in it ....
    Pip, Dec 5, 2003
  10. **** me; I thought all those shitheaps had gone in the skip by now.
    GS 850 x2 / SE 6a
    SbS#6 DIAABTCOD#16 APOSTLE#16? FUB#3
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Dec 5, 2003
  11. Did anyone ever resolve the issue of whether a B12 engine would fit in
    the RF900 frame? It seems a logical thing to do...
    Darren Robinson, Dec 5, 2003
  12. WorkTOG
    Ginge said....
    That model has 4 camchains IIRC
    Lozzo, Dec 5, 2003
  13. WorkTOG
    Klaatu said....
    I had two. If you're thinking about buying a VF, then read this link
    first, then remember that bikes get worse as they get older :
    http://ww.google.com/groups?q=VF750
    +group:uk.rec.motorcycles+author:lozzo&hl=en&lr=&ie=UTF-8&selm=a78apu%
    24j2dv8%241%40ID-54668.news.dfncis.de&rnum=2
    Lozzo, Dec 5, 2003
  14. WorkTOG
    deadmail Guest
    Oddly enough I was wondering when you'd crop up in this thread.
    deadmail, Dec 5, 2003
  15. WorkTOG
    What, fit an engine that is heavier and produces less power?
    I take your point though - but a 'Busa engine would be a better bet, I
    reckon.
    Pip, Dec 5, 2003
  16. whaa?
    The B12 engine produces less than a RF900 engine?
    Didn't know that. How about a tuned B12 engine in a RF900 frame?
    William Grainger, Dec 5, 2003
  17. WorkTOG
    With a bit of work, the 12 will yield a solid 115bhp and ~85lb/ft of
    torque, all very useable and friendly.
    According to the dyno charts that came with the RF, it puts out 125bhp
    and the 75lb/ft of torque is achieved at ~2,500rpm and runs flat right
    up to 11.5k rpm. Not as grunty or friendly, but more poke.
    I wouldn't have imagined that either ;-)
    The 1200 will yield impressive figures if reworked (so I understand)
    but ultimately will lose the reliability, friendliness and "stomp" for
    which it is famed. To tune it with GSXR cams, full Akrapovic,
    individual K&N filters, dispensing with the airbox and
    jetting/needling to suit - and a bit of headwork - can produce
    (according to charts wot I hav seen on the web, like) 150bhp and
    100lb/ft of torque. In a narrow band towards the top of the rev
    range. For a grand or so.
    The watercooled GSXR motors will allow more tuning without losing
    reliability. 'Busa lumps will yield figures in excess of those of the
    1200, for the same sort of cash.
    I've seen spectacular figures claimed by an Aussie who is doing stupid
    things to GSX14 motors, watched with interest by Suzuki, apparently.
    TBH, I'd rather have a less-stressed, friendly, torquey motor with a
    hope of longevity even with abuse - than a highly-tuned, peaky,
    potentially fragile engine that goes like ****, needs 4Krpm to pull
    away and then goes bang. Or a turbo 'Busa. Natch.
    Pip, Dec 6, 2003
  18. Pip wrote:
    Why not use a 1986 Gixxer engine with 140bhp?
    Old Fart at Play, Dec 6, 2003
  19. WorkTOG
    Why not, indeed. Probably because that was not the question that Will
    asked, see.
    Pip, Dec 6, 2003
  20. I'd have thought a helluva lot could be done with a 1400 lump merely by
    re-chipping, and maybe a can and airbox mod.
    The Older Gentleman, Dec 6, 2003
