Double decker bus
Discussion in 'UK Motorcycles' started by platypus, Mar 28, 2007.
  1. platypus
    I was queueing up at the coffee stand at work this afternoon, when one of
    those aeroplane things went past the window. The window in question is four
    storeys high, and overlooks the approach to the main runway at Filton. So,
    when a huge white aeroplane slips noiselessly by, there's a fair chance of
    spotting it.
    By christ it's a big bugger. I had a closer look on the way home, riding
    slowly past the airfield. With all those rows of windows, it looks like a
    cigar-shaped cruise liner.
    platypus
    "Merely corroborative detail, intended to
    give artistic verisimilitude to an otherwise
    bald and unconvincing narrative."
  2. platypus
    TOG Guest
    Saw a few parked at Toulouse Airport in February. From a distance, it
    looks 'normal'. It's only when you get close you realise how bloody
    massive it is.
    And the assembly building there is *vast*.
    TOG, Mar 29, 2007
  3. platypus
    HVB Guest
    On 29 Mar 2007 03:57:49 -0700, TOG@toil,
    I've seen it twice in the last two weeks - once at very high and once
    at very low altitude. I'd never seen it 'in the flesh' before, and
    didn't really have any preconception about comparitive size. To me,
    it looked huge even at high alt cruise - noticeably bigger than a 747.
    One of the fleet did a touch and go at Broughton on Monday - at least,
    I assume it touched down, I wasn't close enough to see the runway. So
    that's two UK visits in a week... sounds like activity is ramping up.
    HVB
    HVB, Mar 29, 2007
  4. platypus
    Blippie Guest
    So, when a huge white aeroplane slips noiselessly
    Fairly quiet in the air, though. Saw it flying over Keynsham to/from Filton
    and it was no noiser than the little holiday charter gnats that buzz over
    every five minutes en route to Lulsgate.
    Cheers
    Blippie
    Blippie, Mar 29, 2007
  5. platypus
    It was over for a flying visit to Filton a few months ago, cutting to and
    fro over Bristol. Significantly vast it was.
    Hopefully. I'm getting the impression that the Boeing posture of "smaller
    planes are the future" is starting to sound a bit hollow, even to them.
    platypus
    platypus, Mar 29, 2007
  6. platypus
    HVB Guest
    I suspect that there's room for both, but I think Airbus deserves to
    succeed with the behemoth.
    More and more people want to fly and the popular routes will benefit
    from the increased capacity of the A380. Meanwhile, more destinations
    could become profitable, and therefore available, with longer range,
    smaller aircraft.
    Personally, I find airports frustrating and flying incredibly tedious,
    so I avoid flying if I can - unless by private jet. :) If I have to
    fly, I prefer to fly from the airport nearest where I'm starting from
    to the airport nearest my destination.
    I don't want to stop at a transit point, unless it just can't be
    avoided. The 787 and A350 might make more destinations available as
    direct flights.
    HVB
    HVB, Mar 30, 2007
