drill exhaust question
Discussion in 'Motorcycle Technical Discussion' started by jcharth, Sep 12, 2006.
  1. jcharth
    jcharth Guest
    Hello I found some instruction on how to modify the exhaust on my bike
    fj1200. I removed the inner tube and left the tube around it. I believe
    the bike is running lea and i am having problems starting the bike. I
    was able to dirve for a couple of miles with the choke on. I will leave
    the bike off for today, i am thinking may be the carbs overflow or
    something. But my best beat is that i have to open up the mixture
    screws just a little bet. Any suggestions?
    thanks.
  2. jcharth
    Don Fearn Guest
    I think it was who stated:
    Find another stock system and install that.
    -Don
    Don Fearn, Sep 12, 2006
  3. Or if you decide to drill out the carb jets to match the exhaust,
    be sure to start at least a couple drill sizes smaller. :)
    Rob Kleinschmidt, Sep 12, 2006
  4. jcharth
    MadDogR75 Guest
    Lets pretend you're serious:
    Those tubes were there for a reason.
    You will probably start to see 'burn` on the headers.
    If you did it to decrease back-pressure and the bike is now
    running lean, congratulations, you've succeeded. So now
    you do need to richen the mixture.
    Do try the mixture screws before rejetting, - it might even work.
    MadDog
    MadDogR75, Sep 12, 2006
  5. jcharth
    jcharth Guest
    Thanks I was worried about air flow but i guess it is all in the mix.
    yes i got dynos, i might have to go to the next size in the kit but i
    will try the mix today.
  6. A manufacturer spends a sizeable sum of money in matching the exhaust
    to the engine, and then some dork comes along with an electric drill
    and reckons a quick whizz or two will turn the bike into a
    rocketship.....
    chateau.murray, Sep 12, 2006
  7. jcharth
    B-12 Guest
    I don't think that modifying your exhaust would have much effect on
    starting the engine. You might notice a big flat spot in the midrange,
    from 5000 RPM to 7000 RPM, but your starter doesn't turn the engine
    that fast to start it, so how would less back pressure affect starting?
    A well-tuned and properly adjusted engine starts up in only half a
    dozen turns of the crankshaft, so there's just NO TIME for any back
    pressure to build up in the exhaust system.
    Actually, I suspect that your carburetors are dirty, the idle jets and
    passages are all plugged up with gum and varnish.
    I recommend that you mix some Berryman B-12 Choke and Carburetor
    Cleaner with an equal amount of gasoline.
    You need about a pint of the mixture in some kind of plastic squeeze
    bottle that doesn't melt when you put the B-12 in it. B-12 is composed
    of xylene, acetone, and methyl alcohol which will attack plastics after
    an hour or.
    Then, find the float bowl drain screws on your carburetors and drain
    them into an old rag if there are no carburetor drain hoses. Then close
    the drain screws and squirt the B-12/gasoline mix into the fuel hose
    going to the carbs to fill up the float bowls.
    Let the mixture sit in the float bowls half an hour or so and then
    start the engine, using the choke. The exhaust will stink and burn your
    eyes, so do this in a well-ventilated area.
    The engine may start up and idle much too fast, so you need to know
    where the master idle knob is at. It may be between the #3 and #4
    carbs, or it may be a cable operated master idle knob on the left hand
    side of the motorcycle, near your thigh when you're riding.
    You want to be able to turn the idle RPM down as you reduce the amount
    of choke applied, and, when the idle jets and passages are cleaned out
    you can adjust the master idle knob so the engine idles at the
    specified RPM.
    For a more thorough carb cleaning, mix about 4 or 5 ounces of B-12 with
    a full tank of fresh gasoline and go for a slow ride to get the
    B-12/gasoline mix to go through the idle jets and passages.
    It's not a good idea to use high RPM while the B-12 is in your
    gasoline, washing lubricant off the cylinder walls.
    Opening the idle mixture screws about 1/2 to 1 full turn may help the
    throttle response.
    You will know you've opened the idle mixture screws too far when the
    idle RPM hangs up after you close the throttle.
    B-12, Sep 12, 2006
  8. Did you perhaps also read any disclaimer that this may not work to your
    satisfaction? On what engineering basis did you determine that modifying
    the exhaust in such a way would improve performance rather than just make
    noise? How is it that a modern 1200cc bike is not powerful enough for you?
    It's one thing to install a properly engineered after market "performance"
    exhaust system that possibly includes tuning advice, but to simply start
    chopping things willy-nilly is foolish at best and could cause damage to
    your engine at worst. If you live in one of those locales that enforces
    sound and emissions levels, you may be elligible for buying a replacement
    exhaust system.
    The best advice I can give is to restore the exhaust system to stock form.
    - Nate >>
    Nate Bargmann, Sep 12, 2006
  9. jcharth
    jcharth Guest
    well seems to be up and running now. I was not able to start it so I
    wasted no time and got a new set of spark plugs. then I rich the
    mixture and drove the bike for a mile but i seem like it overheated a
    little bet. So i drove back and let it cool, then i cover the holes
    left from removing the front cover off the exhaust with exaust repair
    epoxy. Sand it to make it look nice and painted with high temp paint. I
    drove around again after adjusting the mix and it seems to be ok for
    now, starts right up. I guess i will have to drive around for a little
    bet longer to make sure it is running ok. Thanks for the help!
  10. <Holds head in hands>
    You drilled holes in an exhaust that cost tens, if not hundreds, of
    thousands of dollars to develop, then bunged them up with glue, and then
    disguised the blodge.
    You're going to sell this abortion now, right?
    The Older Gentleman, Sep 12, 2006
  11. <Scuffs point of boot in dust>
    Yeah, all right, OK.
  12. jcharth
    jcharth Guest
    I guess you are right, the best thing to do is to get a louder exhaust
    design for my bike.
    jcharth, Sep 13, 2006
  13. Mark, give it up. He's never going to admit in a public forum now that his
    bike is running slower, even though I would bet $10 that it is. If he
    actually
    did something like dynoing before bashing holes in the exhaust, then dynoing
    it afterwards, he would see that he has less power now.
    Ted
    Ted Mittelstaedt, Sep 15, 2006
  14. jcharth
    oldgeezer Guest
    Ted Mittelstaedt schreef:
    But why did nobody tell him how to overcome slower running?
    I always drilled my exhausts for every bike I had.
    And then I clipped off 7 (seven) links from the finai drive chain.
    I even have had bikes that ran faster than they did before.
    Rob.
    oldgeezer, Sep 16, 2006
  15. What?
    The Older Gentleman, Sep 17, 2006
  16. jcharth
    oldgeezer Guest
    The Older Gentleman schreef:
    A newbie may want to drill holes in his exhaust.
    A newbie would say: 'Thank you' when people
    advise not to tamper with the pipes, because the
    bike will loose power.
    But when that newbie complains that the answers
    are not nice, and still drills holes, then that newbie
    is a moron.
    A moron might be stupid enough to shorten his chain
    an odd(!) number of links.
    Rob.
    oldgeezer, Sep 17, 2006
  17. jcharth
    Ian Singer Guest
    And this old geezer moron says why as sprockets are not square or have
    an even number of teeth.
    Ian Singer
    See my homepage at http://www.iansinger.com
    hosted on http://www.1and1.com/?k_id=10623894
    All genealogy is stored in TMG from http://www.whollygenes.com
    Charts and searching using TNG from http://www.tngsitebuilding.com
    I am near Toronto Canada, can I tell where you are from your reply?
    Ian Singer, Sep 17, 2006
