Ow. Went to pop the bike off it's center stand today. As I started to take the weight something went pop in my left forearm. Bike dropped away and I couldn't do a thing. Neither could I pick it up again. A chap nearby came running over and helped me raise the bike back to vertical. Luckily no apparent damage to the bike! But my arm is really hurting. Anything the more experienced of you think I should check might have broken that isn't obvious? Brakes okay (well, no obvious leaks; still working 5 hours later ...), mirrors and indicators okay, foot pegs okay, rear brake lever okay, fairing okay, screen okay, exhaust scratched on the same scratches as before, no obvious oil leaks - level still okay 5 hours later, chain on the wrong side to have been damaged, tyres look okay - no bulges, scuffs etc. and pressures okay, bars and levers are okay, switchgear haven't checked it all but I think it's alright. Anything else you can think I should check? Only problem was that it wouldn't turn over after being dropped. Took about 5 attempts to start. But I suspect that was just the fuel draining out the carb? Thanks for any advice!
