Something I finally admitted to myself I can't figure out... ....how do the kit dry clutches they used to retrofit to SBK inline-4's come together? Try as I might, I can't figure out how the outer clutch basket couples to the primary drive gear on the crank while keeping oil from pissing out everywhere. The way I can fathom it, there still has to be a big gear attached to the outer clutch basket, and this has to be in an oil bath, so is it a case of, moving outwards from the gearbox, the construction being: Primary driven gear attached to a relatively thin, hollow (to accommodate the gearbox input shaft) "transfer" shaft which passes through a hole, which accommodates an oil seal, in the dry clutch outer housing and in turn attaches to the outer clutch basket. The transfer shaft would need to be thin to give the oil seal any hope of working, but this would make it none-too-suited to handling the torsional loads between the primary drive and the clutch... Anyone ever see one in pieces? Daron?
