Drying out saddle sponge
Discussion in 'UK Motorcycles' started by T i m, Sep 13, 2008.
  1. T i m
    Beav Guest
    No probs.
    Leave it another two hours. Rain is forecast to arrive in one :)
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Sep 14, 2008
  2. T i m
    T i m Guest
    Quite possibly.
    Check and when I applied the 'slight pressure'. Enough to push the
    fluid out but not enough to squirt it across the garden (I couldn't be
    bother with the drain hose etc).
    Check and exactly what I did.
    What normally happens is it farts and burps and eventually (depending
    on the pipe length and height changes) flows cleanly, which is what it
    did pretty quickly on this 550.
    I recently replaced all the pipes (copper-nickel) and hoses
    (stainless braided) on the kitcar and my mate had one of the pressure
    bleeders that he suggested we used first. It didn't work very well
    (spongy pedal) so I did it the old fashioned way (as outlined above)
    and it was fine. ;-)
    Anyway, as you may of since read the 'hold the caliper above the
    reservoir' trick worked so all's well (ta again).
    A/D units now stripped, cleaned, lubed and re-fitted (they were just
    gunged up with mainly ally corrosion. One hex bolt on the a/d top cap
    needed the stud extractor to get out. I now need a 17mm hex driver to
    undo the top fork tube caps (ordered from eBay tonight) to re-fill the
    forks.
    I showed my mate the partly rusty Motad box the other day (partial
    rusting away along the '4's' where the 4 goes into 1 and something I
    guessed he's seen a few times before). He said to leave it with him
    and dropped it back the next day all nicely welded up and painted!
    Hopefully, weather permitting I'll re-hang the exhaust tomorrow and
    this time not under any tension!
    Then it's probably just a new chain. The existing one is supposed to
    be new (Iris, ~150 miles) but there is summat wrong with it (one very
    loose / slack link?) and I'm not sure it should have a spring link
    either (but be riveted)?
    Any other stuff will have to wait till I've got it on the road
    (hopefully soon if I can book the MOT next week).
    T i m, Sep 14, 2008
  3. T i m
    T i m Guest
    Now it's in the airing cupboard.
    T i m, Sep 14, 2008
  4. T i m
    Beav Guest
    I (eventuall) saw that :)
    Ahhh, mates. Wonderful things.
    I fitted a spring link to a pal's SV, as the included rivet link was the
    wrong one but before I got a replacement the spring link and gone, causing a
    ball ache of a job getting it out from beng wrapped around the front
    sprocket. Last time I'll ever use a spring link even as a temporary measure.
    Well it sounds like you're getting on with whatever's necessary.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Sep 15, 2008
  5. T i m
    T i m Guest
    This one is particularly Beav. Part of why I didn't start the job
    myself is that I have leant him my PortaPak and Sapphire kit (as his
    bottles at work were too big to take home for a job) and there aren't
    many people I would do such with.
    Not good. Maybe it's because I've only had low powered bikes then (or
    shafties [1]) but I have only ever used spring links and never had one
    come off, ever? I will rivet the link on this 550 though.
    I am and am pleased to say it's mostly going well (and partly with
    thanks to some here Beav <g>). I've done far more than I ever intended
    and there is still much I would like to do but really shouldn't
    because I'm supposed to be doing other things. Maybe because I'm quite
    conscientious and much of this 550 is new to me (Uni0trak, Anti Dive,
    Air assisted, hydraulic rear brake, endless chain, adjustable mono
    shock, auto fuel tap etc etc) I take a bit more time than I might.
    ie, the second a/d unit tool much less time than the first (even with
    a seized screw).
    I'm quite looking forward to having a ride on the thing and really
    hope I like it.
    Cheers, T i m
    [1] Inc Lambretta LD150 and a T80 Townmate (and R100RT and her XV750)
    T i m, Sep 15, 2008
  6. T i m
    Just buy a Mityvac. Makes all this effort a thing of the past. Has
    many uses too, not all of them brake-related.
    "have", ffs, not "of".
    Obviates this, too. The caliper/reservoir thing, not the chavvy word
    choice issue.
    17mm hex driver? Get a set of sump plug keys - you'll find all sorts
    of weird, wonderful and useful big hexes, squares and all sorts in
    there, all operable with a large (17mm/11/16" usually) socket or
    spanner. Damned useful for all sorts of odd jobs.
    Pip, Sep 17, 2008
  7. T i m
    T i m Guest
    <Googles> Hmm, ~ 40 quid, I'll see. It may not actually be a problem
    in actual use but I'm not sure about anything that relies on the seal
    at the nipple. i.e., If this unit is sucking fluid through the system,
    what stops it sucking air in at the open nipple? At least with the
    positive pressure press, open, bleed, close method there is little
    chance of getting air back in (even if it doesn't always get it out)?
    I can see how it might be good for priming a fresh system though etc.
    I know, a grammatical inexactitude, sue me!
    Meh, took 30 seconds and I didn't have to buy / clean / put anything
    (much) away anything afterwards.
    alt.you.pedant >>>
    Well, 14/17mm. I notice that the front brake master cylinder is right
    in the way of the r/h stanchion cap. Ok, only a couple of bolts to
    remove it but still. Also, I'm confused re what fork oil to use, some
    places say SAW 10 and others 5W20 (I've not seen a multi grade used
    in forks before)?
    Hmm, where were you before I clicked on buy-it-now eh Pip? :-(
    However, I see such sets typically contain:
    "3/8" + 11mm square
    8mm + 13 mm square"
    I believe I have these + some on a sump plug 'wrench' + 3/8" sq on std
    ratchet set etc
    "10mm + 12mm Hex"
    3/8 + 1/2" sq drive - Allen / Torx / Spline key set.
    "14mm + 17mm Hex"
    Ordered from eBay and the same as you see in the Laser kits.
    The kit would have been better vfm though (and comes in a box so less
    chance of mislaying a bit).
    T i m, Sep 17, 2008
  8. T i m
    Beav Guest
    Great tool, but probably not worth buying if it's going to sit in a corner
    gathering dust.
    They do, but the removal thing works just s well and it's free.
    Absoluwtely.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Sep 17, 2008
  9. T i m
    T i m Guest
    And the same good mate gave me a new, long , 520 O ring chain today.
    He said it is quite old, a leftover from when his lads were riding
    crosser's in their teens They are both in their 30's now! ;-)
    Oh well, beggars etc ...
    T i m, Sep 17, 2008
  10. T i m
    Open nipple? There isn't an open nipple: the plastic flexi-tube fits
    tightly over the open end of the nipple (via one of the selection of
    the supplied rubber adaptors if required (and there's a really handy
    90 degree one in there)) thence to the fluid collection pot which is
    connected to the vacuum pump. One simply pumps a couple of times to
    induce a vacuum, then opens the nipple a little, then watches the
    fluid gracefully exit the caliper and trickle into the collection pot.
    The only real exercise required is to regularly check and refill as
    neccessary the reservoir.
    Having said that, it will always suck air in past the nipple threads.
    However, this matters not a jot generally, it still pulls the fluid
    through and obviously as the fluid nips outwards towards the vacuum
    pump then atmospheric air isn't going back in to the caliper. In
    extreme cases, or when I've particularly wanted to see the bubbles of
    air in the fluid coming out of the caliper, I've whipped the nipple
    out before starting and greased the threads ... which is a nice bit of
    maintenance on the side, as it ensures the nipple will open next time
    you need it.
    On the odd occasion when the nipple/caliper thread has been shagged, a
    bit of PTFE tape has worked very well - and yes, I left it on
    afterwards and no, nobody died.
    Really, once you've used a Mityvac you won't ever want to go back to
    the old ways. A couple of (non-bike but large fluid volume examples,
    which in neither case did I grease the threads, just pumped like
    buggery):
    1. I fucked up with a Volvo Estate car - while replacing the front
    flexible hoses for MoT, twisted the (rusty) steel lines from the
    reservoir. Even with clingfilm under the res. cap, all the fluid had
    gone by the time I returned with new Kunifer pipes. By the time I'd
    rebuilt the fluid system, it was dark, cold and raining so I gave up.
    Test booked at 09:00 the next day, I slipped under the car at 07:30
    and starting from the nipple nearest to the master cylinder, pulled
    new fluid through into the Mityvac catch pot. Six nipples and fifteen
    minutes later and the fluid was changed, there was no air in the
    system and there was a lovely firm pedal. All on my own, under time
    and weather pressure, no wheels off or jacking up. Try that with a
    bit of hose and a jam jar.
    2. Ford Transit with apparent brake failure, required to transport
    His Champness to the IoM. In the back of beyond, out the back of some
    Ixiot's house in darkest Glos, with little time and fewer facilities.
    Dicking about with calipers, pads and drums yielded nothing, so we set
    to with a litre of Gyp's brake fluid and my Mityvac. Didn't seem to
    be doing anything except pulling loads of bubbles past the nipple
    threads, but when we dropped the fluid out of the final nipple, the
    brake pedal suddenly firmed up.
    Testing by revving the nuts off the thing and dropping the clutch,
    running forward as fast as poss for twenty feet and slapping the
    anchors on revealed skid marks from all tyres. Sorted. Initially,
    the pedal travel was such that I wouldn't have fancied trying to pump
    fluid through with it, such was the apparent volume of air in the
    system (I reckon matey had let the level drop past the bottom of the
    reservoir and then used the van).
    As to being forty quid - I bought mine through eBay from a US supplier
    and got the 4000 model that retails for close to a ton here, for forty
    quid including delivery. The plastic model with a guage, so not the
    boggo model, is available from the US for less than 25 sheets, here:
    http://cgi.ebay.co.uk/Lincoln-Mityvac-Hand-Vacuum-Mity-Vac-Model-06203_W0QQitemZ310083593446
    And the pukka die-cast 4000 for fifty currently:
    http://cgi.ebay.com/ebaymotors/Mity...177QQhashZitem180287980278QQitemZ180287980278
    (Apols for the long urls, they didn't want to shorten)
    Pip, Sep 17, 2008
  11. T i m
    Pip, nothing is ever simple.
    Andy Bonwick, Sep 17, 2008
  12. T i m
    Pip has given you a much longer and more detailed explanation, but I'm
    intrigued as to why you think it would matter if the pump sucked air
    in at the nipple?
    Champ, Sep 17, 2008
  13. T i m
    Higgins Guest
    I can answer this one. If it sucks sufficient air at the nipple then it
    doesn't draw fluid, nor air, from the system very well.
    DAMHIK,IJK, but PTFE tape came in very handy.
    Higgins, Sep 17, 2008
  14. T i m
    As if.
  15. T i m
    Are you including the OP in this generalisation, Andy?
    Pip, Sep 17, 2008
  16. T i m
    If one cracks the nipple a mere crackage, just sufficient to allow the
    hose between the collection pot and the nipple to become a little less
    flat, then, err ... <looks over shoulder toward squeaking noise,
    observes Champ wheeling around corner> ... err ... fewer airs should
    be sucked through.
    It does, too. And still, nobody has died. Yet.
    Pip, Sep 17, 2008
  17. T i m
    T i m Guest
    T i m, Sep 17, 2008
  18. T i m
    T i m Guest
    Thanks. ;-)
    Is the right answer.
    The same effect as when using the traditional 'clear pipe > rubber bit
    the OWV). Air can be drawn back in via the threads.
    Yep, or some Coppaslip (also handy when you want to open the nipple
    again in say 18 years [1]) as mentioned, will also help seal the
    threads if working single handed. I nearly finished the GPz the old
    fashioned way single handed but as daughter was about she helped me on
    the ns front.
    The front brake system on the GPz is nearly vertical and looks like
    it's designed for air to bubble back up the hoses / pipes naturally.
    The bleed nipples on the caliper, a/d unit and union are provided to
    bleed air from the high side of each individual unit?
    I might get a Mityvac to play with though, always keen to try new toys
    (but have managed without for 35 years so far ... luckily I have
    friends who are happy to help if needed) ;-)
    [1] I recently re-did the entire braking system on the kitcar and all
    but two of the joints came undone cleanly. The two that didn't were
    particularly rusty (steel fittings, now brass) and were the reason I
    was doing the re-furb in the first place (MOT advise).
    T i m, Sep 17, 2008
  19. T i m
    T i m Guest
    Sfunny, I wouldn't think of looking at a BMW site for things chain
    related Steve. ;-)
    FWIW the chain my mate gave me today, still in it's greasy packet and
    box, complete with spring and rivet links is a .. <reads box>
    "RK Excel Co Ltd, RK Takasago Chain, O-Ring, 520SO, 120 Links".
    Were / are they any good?
    I'm keen to get the new (150 miles ago apparently) old chain off and
    see if I can find out why a couple of the links feel real shagged. I
    *think* there is some question about the abilities of the guy who
    worked on this last for the PO and the potential of him using a couple
    of links from the old chain? ... ;-(
    T i m, Sep 17, 2008
  20. T i m
    RK is good chain. EK is shite though.
    Why do you need to find out exactly why the old chain stiffened up,
    some chains just do that through lack of use or bad maintenance. Just
    stick the new one on and bin the old one.
    Lozzo, Sep 17, 2008
