DT175 runs rough
Discussion in 'Motorcycle Technical Discussion' started by Andras Nolsøe, Jun 17, 2006.
  1. Hey
    I don't know what is wrong with my motorcycle.
    It runs rough, it must be something with the electrical system, because if
    im taking my plug of and i kickstart it then i sometime can see no spark.
    But one thing that is strange is that if i drive it for a long time and it
    gets hot then if i turn the engine off and try to start it again then i
    fail. and if i then start it then it runs very roughly. But if ill wait a
    few minnutes then i have no problem starting it. What could it be??
    I know almost certainly that it has nothing to do with the carb. i cleaned
    it and the problems i experience only occour sometimes. if i try to take the
    spark plug wire off and put it firmly back on then it sometimes solves the
    problem.
  2. Andras Nolsøe
    FB Guest
    Motorcycle ignition systems often don't use very much voltage, maybe
    only 12,000 volts. Or less. The most incredibly weak ignition system I
    ever heard of was piezoelectric. Some Whizzer motorbikes had a crystal
    instead of ignition points. When a pushrod compressed the crystal it
    emitted a few thousand volts at most, but that ran the engine.
    Sometimes it's hard to see the weak spark put out by a low voltage coil
    if you're in the bright sunlight. I remember how I was amazed at the
    weak spark my CR-250M Honda's coil produced. It was a skinny and enemic
    white spark.
    But it doesn't take much voltage to light off a mixture that is within
    the range of explosibility. So carburetor engineers make sure the idle
    jet is big enough and there is enough idle mixture screw opening to
    start the engine.
    You might try adjusting the idle mixture screw 1/4 or 1/2 a turn richer
    to help the engine start when cold and to keep it a little cooler when
    it has warmed up. You'd be amazed at how much 1/4 of a turn richer
    affects operating temperature.
    If you have a slide valve carburetor, richening the mixture usually
    involves turning the idle mixture screw clockwise, because you're
    adjusting the idle air.
    If you have a CV carburetor, richening the mixture involves turning the
    idle mixture screw counterclockwise because you're actually adjusting
    the fuel/air mixture.
    Then there is the possibility that your engine is running lean because
    of piston ring sticking or exhaust system plugging somewhere. A power
    valve that is stuck in the closed or parlly closed position would make
    the engine run hot and lean.
    Then the spark plug overheats and quits firing until it cools down. The
    spark likes to jump from the coolest point on the center electrode to
    the ground electrode.
    I was really embarassed on time when I had a piston ring sticking
    problem. I was talking to the Husqvarna factory motocross team about
    riding a long defunct motocross course at Saddleback Park in
    California, but I couldn't show the guys any
    tricks on the course because my piston ring was stuck and the 250cc
    engine was running like a 125cc engine.
    Or, maybe your coil wire (or the cap is old) and degrading internally.
    Is the coil wire replaceable or is it molded into the coil? If you
    could replace the wire and cap separately, that might be the key. Cars
    had carbonized threads inside the ignition wires and that suppressed
    radio static. But motorcycles sometimes have copper or steel conductors
    inside the ignition wire.
    If you can't replace the spark plug wire, maybe you can find a coil
    assembly somewhere and swap it into your bike to see what happens.
    Some spark plug caps have a brass screw inside and that goes over the
    spark plug tip to hold the cap in space. I unscrewed those brass things
    and found there was a
    bluish ceramic-covered resistor inside that kept the coil from firing
    the spark plug until the voltage reached a certain level.
    I replaced those resistors with brass screws. I think the engine ran a
    little better.
    Another thing to consider is whether you are using the exact correct
    part number spark plug. Some spark plugs have built in static
    suppressing resistors, but others don't. That would affect voltage rise
    at the spark plug gap.
    FB, Jun 17, 2006
  3. This is a DT175.
    The Older Gentleman, Jun 17, 2006
  4. Andras Nolsøe
    FB Guest
    Cheezus H. Crustaceans. Let Andras remind me of that. I'm volunterring
    to help HIM by giving up my time to talk about general troubleshooting
    procedures, I'm not trying to be a target of your criticism and debate
    endlessly with you.
    If everybody who needs technical advice has to wade through your
    kibitzing, it's no wonder you see so many people asking a question and
    never returning to say, "Hey, thanks to all that answered, I found the
    problem with your help."
    Will this simple thread have to run to 150 responses as the UK debating
    team kicks around all aspects of quantum tunneling as it relates to
    Scheurle loop scavenging?
    If you want to have a circle jerk, couldn't you keep it on the UK NG?
    FB, Jun 17, 2006
  5. Andras Nolsøe
    FB Guest
    Why not? Andras might learn something.
    If I told everything I know, TOG might learn something (or he might go
    nuts trying to find an exception to everything I say).
    Anyway, as I recall, I was mentioning exhaust system restrictions that
    might cause overheating. A power valve, whether the motorcycle in
    question actually has one or not may be a source of exhaust sytem
    restriction. Another problem might be exhaust pipe and exhaust port
    deposits.
    FB, Jun 17, 2006
  6. As a Yamaha power-valve is not connected to the exhaust *at all*, how
    could this be?
    As Mark says - you're knowledgeable. Stickjto what you know.
    The Older Gentleman, Jun 18, 2006
  7. So why are you offering utterly useless and irrelevant information?
    It is, in fact, off topic. he's asking about a DT175 - you're waffling
    on about power valves.
    A poster asks about a carb problem on a CG125 - you waffle on about CV
    carbs...
  8. Hey
    I'll try to collect everything i can and try diffrent things that seem
    logical and i got some reasonable suggestion from FD about the mixture that
    i can handle!!
    It is a DT175 yes. It has a air/fuel mixture screw that FD also talked
    about!!!
    I don't recall that FD said that it had my bike HAD a power valve.
    Ive ordered a new ignition coil. Im gonna get a new spark plug and wire. And
    ill try the things that were talked about. and hopefully it'll fix it.
    I plan to drive 400 km through denmark and take a ferry to Faroe Islands so
    it better not fail through those 400 km's.
    Thank you.
    "The Older Gentleman" <> skrev i en
    meddelelse
    Andras Nolsøe, Jun 18, 2006
  9. It was arguably implied in the response, but I'm sure he knows it
    doesn't, which was my point - why bang on about it?
    It could be something as simple as a duff plug cap.
    Indeed
