Duc threating to leave AMA Superbike
Discussion in 'Motorcycle Racing' started by Andrew, Aug 10, 2006.
  1. Andrew
    Andrew Guest
  2. Andrew
    Saddlebag Guest
    Saddlebag, Aug 11, 2006
  3. Andrew
    _Bob_Nixon Guest
    Don't know but that's too much of a handicap. Maybe not for a pushrod
    two valve Harley but they can rarely even finish a race.
    Hell, Ducati' is finally getting their come-up's. After 10 years of
    that 250cc Handicap, they finally have to play on a level playing
    field (I4 intake restrictors not withstanding). It's no longer a Euro
    only Ducati cup race, which BTW, nearly ruined WSB racing.
    I hate Hondas but when the RC-51 stole the crown for a year or two I
    was elated. Needless to say, I don't care for elitist Ducati's and
    their snotty Desmo ilk (in this day and age). Why can't they compete
    with their V4's in MGP racing?
    Bob Nixon, Chandler AZ
    01 Sprint ST "RED" 54K miles
    http://bigrex.net/pictures
    _Bob_Nixon, Aug 11, 2006
  4. Andrew
    S Frank Guest
    level playing field? what about the 2 cylinder handicap? It is common
    knowledge that more cylinders with the same level of tuning will yield
    more power than fewer cylinders. In club level racing there is usually
    a different displacement allowed in each class for depending on the
    # of cylinders and if it is air or water cooled. Even in GP bikes with
    fewer cylinders are allowed to weigh less.
    I just do not understand how someone can be happy when a small
    motorcycle company that is dedicated to racing first and foremost
    is beaten by an enormous 800lb gorilla of a company with infinite
    amount money and resources. Were you always for the bully in
    school when they were beating up on the helpless skinny nerd? :)
    shane
    S Frank, Aug 11, 2006
  5. Andrew
    Andrew Guest
    Duc is still developing the Bike (as are all the other teams.) It is
    known as the fastest straightline bike out there, but so was the Aprilia
    Cube. At least Duc has had some wins from Capirossi.
    Next year will be completely different with the 800cc formula. Sit
    back, let's see what happens.
    In WSBK Suzuki\Corser won last year, prior to that it was
    Toseland\Hodgson both on Ducs. This year Bayliss looks good very good
    on the 999 and is leading the championship.
    Andrew
    00 Daytona
    00 Speed Triple
    71 Kawi H1
    05 Infant
    Andrew, Aug 11, 2006
  6. Andrew
    Saddlebag Guest
    Now hold on a minute there Bob, I resemble that remark!
  7. Andrew
    bram stolk Guest
    bram stolk, Aug 11, 2006
  8. You obviously know nothing about history and engines so why bother punching
    that crap on the keybord at all?
    Morten Becker-Eriksen, Aug 12, 2006
  9. Andrew
    Saddlebag Guest
    Yeah, then we can rid our dealer showrooms of anything but inline 4s
    once and for all!
    Saddlebag, Aug 12, 2006
  10. Andrew
    Andrew Guest
    Speak of the devil - New Formula eXtreme rules.
    http://www.superbikeplanet.com/2006/Aug/060811a.htm
    The Daytona 675 will be legal for it!
    Andrew
    00 Daytona
    00 Speed Triple
    71 Kawi H1
    05 Infant
    Andrew, Aug 12, 2006
  11. Andrew
    js1 Guest
    Making sense... which means the AMA won't do it. Supposedly, they're
    going to the WSB or MotoGP points system.
    The Desmosedici RR should make a competitive superbike.
    js1, Aug 12, 2006
  12. Andrew
    Saddlebag Guest
    Because you've ridden how many?
    Got the $70k for a prototype? After you purchase it are you still going
    to be sad when Ducs smoke your ass on track day?
  13. Andrew
    _Bob_Nixon Guest
    You haven't been around here long, eh dipshit?
    Explain Desmodomic valve actualtion and it's advantage (in this day
    and age of metalurgy) in detail...please;)
    _Bob_Nixon, Aug 12, 2006
  14. Andrew
    Saddlebag Guest
    And then make the same argument for springs and camshafts when the
    thought of an electronically actuated pneumatic system is so much
    sexier.
    Fact is that the Desmo thing works and it's different. Different ways
    of doing things is what titilates engineering dweebs no?
    Please explain in detail the disadvantage of Desmodomic valve
    actuation. Why is it exactly that an extra rocker arm lever is so
    inferior to a spring? Please spare me the valve adjustment thing as
    I've ridden these things many tens of thousands of miles without the
    valves running out of spec. And if Duc would add proper collets to the
    build process we could probably get by without ever even checking the
    damn clearances:
    http://www.mbpducati.com/4v/photosvideos.htm
  15. Andrew
    S Frank Guest
    I was confused at first about Ducati wanting 1200cc because
    they seem to be doing fine right now in WSB with their current
    bike. But I think the problem is cost. Ducati is able to compete
    but at a very high level of tuning that requires constant, expensive
    rebuilds. They would rather be more limited in what they can
    do (like the 4s) but have more displacement. Also, I think they
    want to have a 1200cc bike for the street since the 999 has muc
    less power than the inline 4 liter bikes.
    Shane
    S Frank, Aug 12, 2006
  16. Andrew
    Saddlebag Guest
    To market to the dummies anyway. As if anyone really utilizes 150 hp
    riding down to Hooters.
    I don't get all the righteous indignation about racing. Who gives a
    rat's ass if one engine configuration requires more displacement to
    make equal power? If the configuration isn't a competetive design it
    will suffer from growing too large or too heavy. I say give the mfgs HP
    and weight parameters and let'em run what they brung baby.
  17. Andrew
    _Bob_Nixon Guest
    I'd love it if bikes started using pneumatic valve actuation.
    Currently, it's the ONLY [1] cam driven solution better than springs.
    You'd thing with all the bucks they charge for Ducati's that they
    would have had pneumatic valve actuation shortly after the F1 cars.
    After all their customers deserve something better than a 1930's
    Duesenberg cage design, back when metallurgy was shit.
    [1] Cam-less or solenoid operated valve gear is still in its infancy.
    That's the future of piston engine breathing or some ported variation
    of said rather than conventional reciprocating poppet valves
    Not anymore Saddle. Like I said, this ain't the 1930's anymore.
    You did most of it for me. Mostly very tiny light valve spring to give
    the engine starting compression as any valve lash on the closing
    rocker would leak compression. Then, instead of having a conventional
    valve spring Desmo uses a closing rocker arm instead of a valve
    spring. The bad thing is that they have to use a weighty rocker at
    all. I defeats the purpose of trying to keep the valve train weight
    light (low reciprocating mass) as springed and pneumatic actuation
    directly push the valve stem with the cam via small bucket.
    Demodromic' is old tech, Saddle. It's definitely better than a
    flathead, OHV or SOHC pushing both intake and exhaust valves but still
    out of date technology.
    Extra weight (reciprocating mass).
    We haven't even discussed that aspect but why is it that Ducs require
    6000-mile valve checks when ALL the other mfg's are nearly twice that
    many miles. Also, those toothed rubber cam belts are a major joke on a
    $20,000+ MC.
    I like it. Saddle & with all the extra bucks you're shelling out for a
    Ducati, the above technology should be standard equipment.
    Bottom line: Italians are spoiled in their exotic autos and bikes
    (Aprilia not withstanding) and think they can charge the customer
    anything they want. A good example is the current vaporware V4 pseudo
    GP bike at $60K plus.
  18. Andrew
    BryanUT Guest
    Ain't that the truth. I can barely use my 80hp on my morning commute, with
    all the darn school zones, redlights, light rail crossing, joggers,
    bicyclists, and other traffic.
    Bryan
    BryanUT, Aug 12, 2006
  19. Andrew
    js1 Guest
    How about minimum weight for each configuration?
    js1, Aug 12, 2006
  20. Andrew
    Saddlebag Guest
    And with that small amount of reciprocating mass comes durability.
    Springs, just like the aluminum frames on Jap bikes fatigue over use.
    That rocker arm will last forever.
    IMO, it's to bring $$$ to the service dept's of dealerships who risk
    carrying such a low volume product. I've been having the full service
    once a year or every 12k miles without any problems for quite some
    time. Valves are always in spec too.
    That wasn't part of the subject, but I'll agree with you here. BTW,
    I've never spent $20k on a Duc in my life.
    I agree. Perhaps I should learn some Italian and email the guys in
    Bologna.
    They can't make it up in volume like the Japs, that's just a fact of
    bidness. They still make a tremendous product that is completely
    different from Japanese machinery, and I think that's pretty friggin
    kewl...
