Ducati ST2
Discussion in 'UK Motorcycles' started by SteveH, Jul 8, 2007.
  1. SteveH
    ISTR that was posted on here, sometime back.
    CT, Jul 9, 2007
  2. SteveH
    Well lets look at the specifics. I used a 996 to commute to London from
    Oxford. Note the ST4 is the 916, the ST4S is the 996. The latter is a much
    better unit.
    Look at the actual service prices for starters, not as great a difference as
    one might think.
    www.ducati-john.co.uk/routine-ducati-servicing.htm
    Belts, of which much is made. For peace of mind change every 6000 miles if
    you will, I think factory is 12000 though. Buy a little tool perhaps
    http://cgi.ebay.com/ebaymotors/Duca...-SHIPPING_W0QQitemZ290136019770QQcmdZViewItem
    and do it yourself. Belts are only £26 each or thereabouts.
    Oil changes, filters etc. you would do yourself.
    What does that leave? valve clearances. Get a man to do it every 12000
    miles, checking the rocker faces at the same time.
    Hog, Jul 9, 2007
  3. SteveH
    SteveH Guest
    That's assuming that, if I got a 2-valve engine, I'd actually pay for
    servicing on it.
    Yeah, I see what you mean. I'm just not all that confident in my
    abilities to look after the 4-valve engines, but I'm convinced I could
    look after a 2-valve engine.
    Maybe it's just a confidence thing, but I've never liked doing belts on
    twin-cam engines.
    SteveH, Jul 9, 2007
  4. Embarrassment can do terrible things to you.
    steve auvache, Jul 9, 2007
  5. I rode a GPZ550 into the ground commuting 206 miles a day on a return
    trip to Norwich and back plus weekend mileage. It had been couriered
    before I got it, I was quite impressed that it lasted me nearly 4 months
    before the top end finally gave out.
  6. SteveH
    Hog, Jul 9, 2007
  7. It wouldn't be the maintenance costs that would worry me: it would be
    the nagging doubt that the 916/996 lump simply isn't as solid as some of
    the old two-valvers, and that any repair work will come into the
    'ferociously expensive' category.
    The Older Gentleman, Jul 9, 2007
  8. This is the expensive bit, mind - especially if the rocker faces have
    worn out (though I thought that was an issue reserved for the 748?)
  9. SteveH
    snip>
    It's less than I spend on stuff for a packed lunch and that's without
    the added cost of toasted bacon sandwiches.
    Andy Bonwick, Jul 9, 2007
  10. SteveH
    snip>
    I had kevlar belts put in my 748 because they're supposed to be
    capable of doing the 10k miles without any need for concern and they
    certainly weren't double the price of standard ones.
  11. SteveH
    SD Guest
    You wanna fit GL1500 cambelts, you do - 100,000 mile service item.
    £38 the pair.
    | ___ Salad Dodger
    |_\_____/_| ..90668../..24701.../..31928.
    '^' RBR Clues: 26 Pts:0500 Miles:1739
    SD, Jul 9, 2007
  12. SteveH
    exactly - 500 quid/ year is peanuts[1]
    [1] less than that, if you can be fed on this sort of money.
    darsy, Jul 9, 2007
  13. SteveH
    Uh? the 996 engine is unburstable AFAIK. THe original 916 might have had a
    few niggles but TBF that was mostly on the electrics.
    Hog, Jul 10, 2007
