Dynojetting...
Discussion in 'UK Motorcycles' started by JackH, Nov 22, 2009.
  1. JackH
    JackH Guest
    ....worthwhile or not?
    I've seen a new Dynojet kit for the GSX on eBay - £40, assuming no one
    else bids.
    The bike has a full Gazelle stainless exhaust but nothing to suggest
    it's been jetted to match (1) so was wondering if this would be worth
    doing.
    I take it the fuel consumption would go to shit if this was fitted as
    well - at the mo I'm getting rather more to the gallon out of it than
    I expected, as it's doing between 35 to 38mpg.
    (1) And yes, appreciate this might not necessarily match either
    JackH, Nov 22, 2009
  2. JackH
    Simon Wilson Guest
    IWHT you'd be better off doing a bit of measurement first, rolling
    road/mixture measurement etc. Then you know where you are starting from
    rather than re-jetting by guesswork.
    Simon Wilson, Nov 22, 2009
  3. JackH
    JackH Guest
    Ok - shame the local rolling road is out of action at the mo.
    The kit on eBay is being sold as a 'Stage One' kit - IIRC, they're
    normally sold as a 'bolt this onto your stock bike and see
    improvements' kind of thing, aren't they?
    If so, just wondered what others had experienced with these.
    JackH, Nov 22, 2009
  4. Does it normally *need* rejetting?
    Not necessarily. It might run more efficiently. But that's only if it's
    needed, of course.
    Stick it on a dyno first. It'll cost £60-70. Then decide.
    The Older Gentleman, Nov 22, 2009
  5. JackH
    JackH Guest
    Most bikes they recommend rejetting if you go down the aftermarket
    pipe route, don't they?
    JackH, Nov 22, 2009
  6. JackH
    Simon Wilson Guest
    Not afaik. "It depends"
  7. JackH
    JackH Guest
    Ok, well... I suspect newer stuff with injection (and therefore more
    sensors etc to help the ECU to determine any changes to fuelling which
    are necessary as a result of a different pipe etc), it's less likely
    you'll need to modify the system - before anyone starts guffawing and
    saying 'hey stoopid, they don't have jets in injected system', I mean
    you don't need to change the fuelling in terms of mapping.
    Older stuff... jets are what regulate the fuelling... and are set in
    stone - something changes elsewhere in the system, the jets are
    ensuring the carbs are still only fuelling for the old set up,
    regardless of the needs of the new one.
    *All* the carb fed 600s I've had... if they've had a aftermarket can
    or whatever, they've benefitted from rejetting in terms of power
    delivery etc.
    The VFRs, of which there have been many, none have really felt like
    they needed jetting when I've fitted an aftermarket can etc.
    JackH, Nov 22, 2009
  8. JackH
    antonye Guest
    A DynoJet kit is not just jets, but new needles and springs as well.
    The whole point of the kit is that it is making the fuel richer by
    giving you bigger jets at the size they have found makes a power
    difference to the stock bike.
    However, what's good for one stock bike might not be good for
    another. The only real way to tell is to put it on a dyno and
    see what the power curve is like, then decide on any adjustments
    if necessary.
    Personally, I'd spend my money putting it through a dyno run and
    get some guidance from the technician there. A few jets won't
    cost you much but will give a much better seat-of-the-pants result
    with the dyno run than just fitting the kit alone. It'll probably
    work out about the same money anyway.
    Is it snake oil? Well no, but you're giving the bike a tune-up
    without measuring the affects that it's having, so you've no
    idea whether it's working or not.
    antonye, Nov 22, 2009
  9. JackH
    Pete Fisher Guest
    In communiqué <1j9lmh8.1fnb7oy18g0a9cN%>,
    Indeed. You can get close by guesswork and plug chops, but if going
    beyond the normal envelope of exhaust system and carb setup a dyno is
    the only way to get jetting spot on, particularly mid-range.
    Had the 604 Nordwest on a dyno and found it was pretty near perfect
    (though asking other nordie owners with Keihin smooth bore conversions
    helped). Just needed a tad bigger mains.
    The 375 Morini with race cam and 28mm carbs was tricky to get right.
    Just couldn't get clean mid-range despite trying different needles,
    atomisers and even slides. Got it much better after a rolling road
    session. Never perfect though - the L5 cam is renowned for giving a flat
    spot around 5000 rpm. Not a problem unless riding on the road though ;-)
    | Pete Fisher at Home: |
    Pete Fisher, Nov 22, 2009
  10. JackH
    JackH Guest
    Best answer so far.
    Cheers. :)
    Think I'll buy it.
    The local rolling road isn't at the mo, as they're looking for new
    premises - given I'm pally with them and tend to trade the odd favour
    with them, it'll be worth waiting til that's back up and running
    before I start fecking around the carbs on this.
    JackH, Nov 22, 2009
  11. I dynojetted my Blackbird a decade ago. There was a flat spot around
    4-5k before it then took off aound 7k. I was told that they had
    designed it that way to meet noise requirements, whether that is true
    or not I don't know. But the bike definitely went better after the
    dynojet kit was installed. I had no access to a dyno, but it certainly
    felt better. The bike still had stock pipes.
    Next bike was a Hayabusa with Yoshis on it and the only way I could
    get that to run properly was to Power Commander it. The pipes made a
    hell of a difference that the standard ECU could not handle.
    Kevin Gleeson, Nov 22, 2009
  12. JackH
    Actually, many FI systems, well, certainly open-loop ones, don't
    measure the air mass flow; they infer it from the map and other
    sensors. They rely on the pumping efficiency of the engine being the
    same as it left the factory (I imagine they allow for wear).
    Closed-loop stuff with an exhaust sensor might have enough adjustment
    to compensate but that's generally limited to engines with a cat.
    I can only recall one FI vehicle I've ever owned that had an air flow
    sensor and that wasn't even a mass flow sensor, it was an air speed
    sensor.
    Pip Luscher, Nov 22, 2009
  13. JackH
    boots Guest
    As a counter POV. After fitting a K&N and a Skorpion endcan to my
    fazer 600 I figured it should really need rejetting. A dyno run with a
    probe inserted <fnar> showed the carburation was pretty well spot on.
    Guess it must have been running rich as standard.
    boots, Nov 22, 2009
  14. JackH
    JackH Guest
    First Fazer I had came with a Wolf can and was dynojetted to suit
    before I owned it.
    Seemed to have more top end than the second one I had which was
    standard... and it also seemed to drink a lot more fuel.
    I had a Micron 'not for road use' can for the second one - when I
    tried it with that, it seemed to make a lot more noise at the expense
    of power, so the conclusion was it would have almost certainly have
    benefitted from being rejetted.
    JackH, Nov 22, 2009
  15. JackH
    JackH Guest
    My 106 GTi relied on a MAP sensor.
    Most VAG / BMW stuff relies on AFMs, as do Pug HDIs.
    And a lot more stuff come to think of it.. but those are the ones I'm
    more familar with.
    *spit*
    Never again - Mk1 Vectra, that is.
    JackH, Nov 22, 2009
  16. Not necessarily, no.
  17. JackH
    JackH Guest
    Conversely, I'd have another Mk3 Cavalier - even a late one saddled
    with the Ecotec lump.
    JackH, Nov 22, 2009
  18. JackH
    £40 at Banjax.
    £10 at Bob Farnham's place in Hildenborough, though that was kinda
    mate's rates in 1994.
    ogden, Nov 22, 2009
  19. JackH
    Deep ends, dunnit? If there's a flat spot, or the bike isn't pulling
    properly at any point, then possibly. If your plugs (or encan exit) are
    very pale or sooty black, then probably. If none of the above, then
    probably not.
    About the going rate - that's what I paid for a Bandit kit a couple of
    years ago.
    Not necc: AIUI, most Jap bikes (and carbed Suzukis in particular) are
    set up from the factory to run richer rather than leaner. This means
    that you can fit either a race can OR an aftermarket filter (K&N, eg)
    without taking the mixture out of the optimal range. Fit both and
    you're looking at leaning out at higher rpm.
    Never heard of a Gazelle exhaust - is it a freeflow/race type? A
    properly set up Dynojet wouldn't neccessarily lead to high fuel
    consumption, it should produce optimum mixture throughout the rev range.
    The fuel consumption may increase as a result of the rider using the fun
    handle more vigorously as the response has been improved.
    Having said all that, my B12 was the thirstiest bike I'd ever want to
    ride: enormous fun at anything over 3k rpm, huge flat spot below 3k, big
    hole in wallet due to tank range dropping to less than 60 miles on
    occasion. That was after having it "set up" with a Stage Two/Three
    Dynojet kit, race can and K&N. Previous performance was poor, with
    lackadaisical grunt and poor starting - no go, no poke and 25mpg, that's
    why I thought a jet and setup was called for.
    Pip, Nov 23, 2009
  20. JackH
    'Hog Guest
    There is something "odd" about that B12 though. The fuel consumption was
    insane.
    I don't really see the point in having carbs 'jetted without a dyno session,
    for all it costs. It's only a stab in the dark otherwise and may just
    complicate matters.
    'Hog, Nov 23, 2009
Similar Threads
Loading...
