Economical bike for a tall person
Discussion in 'UK Motorcycles' started by BGN On Tour, Aug 27, 2008.
  1. BGN On Tour
    BGN On Tour Guest
    As pretty much all of my trips are now commuting I'm getting fed up of
    paying for 20 littes of fuel to cover 150 miles. Expensive.
    So I am looking at either buying another, more wallet friendly bike or
    getting rid of my Triumph Tiger 955i and just using said replacement.
    So there will be an '04 Tiger for sale soon.
    Do we have a collective idea on what a reasonable reliable bike 1)
    would be and 2) how much it cost?
    Thankyee,
    --BGN (bored) at work.
  2. BGN On Tour
    zymurgy Guest
    Did you change the front sprocket to a 19 tooth to drop the revs ?
    This helps the fuel economy, not much, but it mounts up.
    P.
    zymurgy, Aug 27, 2008
  3. I bought my 28 year old GS650 for hardly any cash and that averages
    50-60mpg and doesn't need silly things like chains either, it's also a
    real hoot at anything over 90mph as (I'm sure I've said before) the
    frame could be made from liquorice and the brakes from wooden blocks and
    dustbin lids.
    Whinging Courier, Aug 27, 2008
  4. BGN On Tour
    1) CG125 2) Not very much.
    And if a 125 isn't "big enough" then you're not nearly as driven by
    the petrol price as you make out.
    _______
    Ace, Aug 27, 2008
  5. I reckon he's ready to come out.
  6. BGN On Tour
    BGN On Tour Guest
    When I said 'big enough' I meant my physical size, not engine size.
    I'm 6'6" tall with a bad back so being hunched over a CG125 isn't my
    idea of fun.
  7. BGN On Tour
    I know.
    Fussy. There's absolutely no reason a 125, perhaps the XLV125
    mentioned elsewhere, shouldn't be physically large enough. If
    cost/fuel economy is really the prime rationale then you'd put up with
    it.
    The point I'm making, in a somewhat roundabaout way, is that although
    you say you want "better" you don't give any idea of what's
    acceptable, or how much better it needs to be for you.
    In practise, how much cost saving do you need to make a new purchase
    worthwhile?
    _______
    Ace, Aug 27, 2008
  8. BGN On Tour
    If you're only getting 34mpg, either your Tiger's fucked or you're
    ragging the arse off it. I get over 55mpg from my '03 when in
    'commuting' mode.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Aug 27, 2008
  9. BGN On Tour
    Wingedcat Guest
    Yep, I honestly can't see it would be worth selling your Tiger if fuel
    economy is the motivating factor. Like Krusty, if you really are only
    getting 34 mpg, or 150 miles per tank, my experience says something
    must be amiss. I get 200 miles a tank from my Sprint 955, and although
    I'm not a complete lunatic I certainly don't hang around on it.
    Is money really that tight? My girlfriend has a YBR 125 - nothing like
    my Sprint obviously but will proudly return about 80mpg. Is it worth
    it?
    I would have thought that if you downgrade to something like a ER-5 or
    Bandit you will see very little in terms of improved fuel economy and
    end up with a disappointing compromise bike.
    Luke
    Wingedcat, Aug 27, 2008
  10. TBH though Nick, when I've seen you riding anything you tend to be
    hunched over.
  11. BGN On Tour
    TOG@Toil Guest
    What he said. New Yamaha Ténéré is worth a look, too, though it may be
    a bit slow for you.
    TOG@Toil, Aug 27, 2008
  12. BGN On Tour
    Derek Turner Guest
    1) Deauville [1] and 2) Dunno, how are values holding up?
    [1] I know, dull as ditch-water but for a reliable, reasonably dry,
    economical commuter it really does take some beating. <dons flame-proof
    suit>
    Derek Turner, Aug 27, 2008
  13. BGN On Tour
    Tim Guest
    My earlier 855 injected model (1999) managed 206 miles from full to very
    empty. How it managed the last 5 miles I don't know. I have never had to
    put that much petrol in since.
    Tim, Aug 27, 2008
  14. BGN On Tour
    HTH, HAND etc.
    Krusty
  15. BGN On Tour
    It's not normal - far from it. 240+ is normal, based on the several
    hundred Tiger owners on the Yahoo groups I run/moderate. There's
    something wrong with your bike - duff sensor or faulty tune at a guess
    (assuming you'd notice if one of the dodgy tank connectors was cracked).
    Krusty
  16. BGN On Tour
    Tim Guest
    Typo ;-)
    Tim, Aug 27, 2008
  17. BGN On Tour
    What colour is your Tigger?
    Lozzo, Aug 27, 2008
  18. BGN On Tour
    Tim Guest
    It was a recall for several models.
    Tim, Aug 27, 2008
  19. BGN On Tour
    I once managed to screw 220 miles out of my '04 Daytona tank by riding
    like a gurl. The light had been on for about 20 miles when I filled up
    IIRC, and I knew I could get 35 miles at least after the light came on,
    because I did that too another time.
    Lozzo, Aug 27, 2008
  20. BGN On Tour
    Ben Guest
    Buy a GSXR1000. It suits someone of 6 foot 3 and will do 160 miles on
    14 litres.
    Ben, Aug 27, 2008
