ECUs - engine brains
Discussion in 'UK Motorcycles' started by fragmented, Nov 22, 2008.
  1. fragmented
    ginge Guest
    I'd put money on it being a bit of an old wives tale from a mechanic,
    however starting it up without checkign the needle stops in an error
    position could lead to problems.
    ginge, Nov 22, 2008
  2. fragmented
    fragmented Guest
    'ginge' wrote...>
    Starting it without giving it time to do anything definitely leads to
    temporary problems.
  3. Cheryls dad used to remove the distributor cap from his old car when
    leaving it in a strange place..
    Phil
    Phil Launchbury, Nov 24, 2008
  4. fragmented
    fragmented Guest
    'Champ' wrote...>
    Which part are you referring to?
    The fact that if you try to start it too quickly the ECU gets confused
    and the engine doesn't run? (happened with three different manufacturers
    engines, don't believe me I'll gladly demonstrate on your 10R the next
    time we meet)
    Or the fact the ECU then goes into diagnostic mode? (after the manager
    of one of the UKs top 3 independant Porsche garage, Henry from
    911Virgin, told me to keep cranking it, starting the boxster I heard it
    first spin the engine, then start firing one cylinder, then another
    (making two firing), then the third, etc, etc, perfectly even gaps
    between each pot starting to work. Don't believe me, you get a 986 S
    Boxster, bring it round here and I'll happily demonstrate)
    Or do you believe that anything you've never experienced does not and
    cannot exist?
    fragmented, Nov 24, 2008
  5. fragmented
    fragmented Guest
    'Champ' wrote...>
    <shrug>
    Your closed mind isn't my problem.
