Electric motorcycles
Discussion in 'UK Motorcycles' started by Sean Hamerton, Dec 15, 2008.
  1. Sean Hamerton
    When you're chatting down the pub google is not always to hand.
    Lozzo, Dec 18, 2008
    #61
  2. Sean Hamerton
    des Guest
    It is if you have an iPhone..
    D.
    des | 'what does it matter what he posts?'
    http://www.jr.co.il/terror/israel/index.html
    end the 'occupation': http://minilien.fr/a0k8xe
    ukrm: 'where it's "cool" to be stupid!'
    myths of islam: http://minilien.fr/a0j5qo
    des, Dec 18, 2008
    #62
  3. Sean Hamerton
    I can think of a couple of possible reasons. Front crumple zone, for
    one. Admittedly an engine block would fill a lot of that, but I
    suppose it also provides a nice heavy mass to barge its way through
    whatever you've run into.
    Somewhere to put the fromt wheel arches for another: they need to be
    moderately wide to accomodate the steering lock. That or the driver
    has to sit skewed or all alone out front.
    Another guess is concern about conservative buyers.
    Pip Luscher, Dec 18, 2008
    #63
  4. Sean Hamerton
    I have heard of it before but it didn't ring any bells until it was
    described, at which point I had an "oh *that*" moment.
    #64
  5. Sean Hamerton
    Gah. It helps to read the whole thread, doesn't it?
    #65
  6. Crumple zone. Arseholes going through heads is not a pretty sight.
    Grimly Curmudgeon, Dec 19, 2008
    #66
  7. Sean Hamerton
    DR Guest
    Grimly Curmudgeon posted:
    Every time I read ukrm I get that.
    DR, Dec 19, 2008
    #67
  8. Sean Hamerton
    :) 'only' like it.
    Muck, Dec 19, 2008
    #68
  9. Sean Hamerton
    For a high performance vehicle motors in wheels is too much unsprung
    weight
    Hog, Dec 19, 2008
    #69
  10. Sean Hamerton
    Why do people think that having a pressure vessel in the boot is a
    problem? it really isn't. Easy to make one you could crash a train into.
    And it should have a fusible release valve so that in the event of fire
    the hydrogen will burn out in a controlled manner.
    Better than a plastic tank full of petrol as in most cars now.
    Hog, Dec 19, 2008
    #70
  11. Sean Hamerton
    No and I don't care, it's still a compromise.
    Hog, Dec 19, 2008
    #71
  12. Kids setting them off in car parks... jumpers for gaolposts.
    #72
  13. Sean Hamerton
    dog Guest
    what the **** is it with friday afternoons?
    dog, Dec 19, 2008
    #73
  14. Sean Hamerton
    you're Reading too much into it.
    darsy, Dec 19, 2008
    #74
  15. Sean Hamerton
    They tried a motor in wheel setup for that 640 hp? parallel hybrid BMW
    Mini. Apparently, the unsprung weight of the electric setup was a tiny
    bit heavier. I'd have thought if they used motors smaller than 160 hp
    per wheel.. that would have come down to equal or under the petrol setup.
    Muck, Dec 19, 2008
    #75
  16. Sean Hamerton
    I'd prefer a plastic tank full of diesel to petrol any day. There's
    something about having a volatile pressurised tank in a car that's not
    right. I cite the example of that CNG bus going pop in India. That was
    due to sub standard pressure vessels being used. Where as a sub standard
    liquid diesel tank would have just leaked.
    Muck, Dec 19, 2008
    #76
  17. Sean Hamerton
    Well, I was answering specifically "why a bonnet"; I'd ignored the bit
    about motors in wheels, but yes, you're right.
    Pip Luscher, Dec 19, 2008
    #77
  18. Well, ffs.
    "Here's 2000rupees, Welder Inspector, Sahib."
    #78
