Helping a neighbour get her '74 Vespa 150 started, she left it in the damp winter weather and I think a little corrosion caused it to stall the other day and not start afterwards. This is an import from India with a home-made starting switch, the simple toggle kind, attached in the lockable left-storage compartment. By checking continuity I was able to determine that the switch allows the bike to start when the switch is off. When the switch is 'on', one of three wires from the stator is shorted to one of the other two. (The third stator wire goes to the lights.) The thing is, the switch isn't inline, ie., in series, with the high tension coil. (Have tested resistance on the HT coil and I see about 1 ohm on the primary and about 13,000 ohms on the secondary so I'm guessing for now that the HT coil is okay. At the moment, can't get at the stator since I don't have the right flywheel puller, am trying to source one. Suspecting corrosion or old age has ruined the igntion winding or maybe the condenser or points.) My question is a more general one, whether it is a dumb idea to put the ignition 'switch' in parallel with the HT coil? Eg., while the starting 'off' position of the toggle doesn't seem wrong, could the 'on'/stop/short-to-groound position allow some small transient current that would harm the ignition winding or the HT coil or condenser/capacitor/points? (I can think of two reasons for wiring it this way: 1) ignorance and 2) a desire not to lengthen the wires from the stator to HT coil which are on the right-hand side of the scoot while the storage compartment is on the left-hand side. Maybe there are others I haven't thought of but I think if I were jury-rigging a more secure, ie., less easy to steal, switch, I would have mounted a keyed ignition switch from some scrap bike on the right-hand side. Comments appreciated in advance.
