Electrics... side light wiring for the techies...
Discussion in 'UK Motorcycles' started by Owen, Aug 5, 2004.
  1. Owen
    Owen Guest
    I have salvaged from a Renault Megane rear spoiler stop light, the LED
    circuit board. Having taken off the damaged red light cover, I am left
    with a strip circuit board that holds 12 LED's, approximate output 40
    watts (I think...). I want to use this to replace the pathetic 5 watt
    bulb that currently ressides in the R80RT. Asside from the challenges
    of making this device fit in the confined space allowed, what else do
    I need to take into account? An in-line fuse (5 watts to start off
    with?) anything else?
    All help appreciated...
    O
    1 Black, shortly to undergo extensive surgery.
    1 Red, undergoing lightweight surgery. -----
    1 Blue, for Power-Ranger baiting. | o |
    Numbers ... | o |
    Stuff ... | ooo |
    Life ... -----
    Owen, Aug 5, 2004
  2. Owen
    Greybeard Guest
    12 Led's is prolly less than 1 watt.
    Just wire it in parallel with the other and don't worry.
    Greybeard, Aug 5, 2004
  3. Owen
    Andy Hewitt Guest
    You should be able to just plug it straight in. The wattage rating of
    the LEDs is most like a 'rating' of the brightness of the lamp.
    Now then, apart from that, you will be making your bike somewhat
    illegal. The side light has to be 5w legally, but the brake light has to
    be 21w [1], which is what you should be replacing.
    Andy Hewitt, Aug 5, 2004
  4. Owen brought next idea :
    I've never looked at the LED lighting systems as used on vehicles, so
    if anyone knows better please feel free to correct me...
    I don't think it will be 40w, as that is rather a lot in LED terms. I
    think 40w would also breach the construction and use regulations or
    their modern equivalent. I would also be a little wary of damaging the
    brake light switches with such a large load.
    Fuses are not rated in watts, they are rated in amps. Your system
    should already be adequately fused, so just connect it in addition to
    your existing brake light or replace your existing brake light with the
    LED's. I think you will find the LED's will consume much less than your
    conventional lamps for the same light output.
    FYI 40watts would be 40w / 12v = approx 3.5amps (did you mean amps?)
    If you lack a suitable meter a rough easy way to check the consumption
    of the LED's, would be to try them in series with various wattages of
    conventional bulbs. If the LED's light up, but not the bulb, the bulb
    is a much higher wattage than the lamp. If the bulb lights up, but not
    the LED's then the LED's draw more. You will probably need to watch
    that the polarity is correct for the LED's..... I suspect they might
    not have any built in reverse polarity protection.
    Harry Bloomfield, Aug 6, 2004
  5. Owen
    About the same wattage as a top-poster's brain at the redline, then.
    Pip, Aug 6, 2004
  6. Owen
    Greybeard Guest
    I don't remember posting at the top, and apologise for doing so.
    I didn't think that the message had even been posted as my poxy news service
    supplier is really giving me shit.
    Changed news servers now, and seems much better.
    Greybeard, Aug 6, 2004
  7. Owen
    Owen Guest
    I intend using the LED's to replace the front side-light... I think
    the brightness might be 49 watts equivilent...
    Yes, I meant amps...
    I didn't even think about using my multi-meter... doh! I'll have a
    little play around tomorrow...
    Thankyou to all who posted... :)
    O
    Numbers ... | o |
    Stuff ... | ooo |
    Life ... -----
    Owen, Aug 7, 2004
