Electrics
Discussion in 'UK Motorcycles' started by YTC#1, Dec 10, 2009.
  1. YTC#1
    YTC#1 Guest
    Or lack of them
    Went to start the XJ900 yesterday morning (after getting all my gear
    on), and nowt, not even a click. Even the digital clock went off.
    I checked the battery out and the multi-meter reported about 3Vs.
    Thought I had maybe left the parking lights on.
    Undid battery, bunged on optimate.
    Tonight checked battery, 13V, attached , turned on ignition and clock
    died again.
    Tested battery, 2Vs.
    Disconnect battery 13Vs.
    Tried various conbos of removed fuses isolate which circuit the issue is
    on, but looks to be the main.
    Can/t see any obvious loose connections, so deeper search needed.
    However, with it being total loss, as in not a peep when ignition on, is
    there any major item I could/should start at ?
    Ignition switch ?
    Coils ?
    Starter ?
    Scrapheap ? :-(
    YTC#1, Dec 10, 2009
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, YTC#1
    Battery.
    Wicked Uncle Nigel, Dec 10, 2009
  3. YTC#1
    Dave Emerson Guest
    Undo -ve connection from battery and brush cable-end against battery
    terminal.
    If a circuit is taking sufficient current to pull a good battery down to 3V
    then there should be an arc.
    - If no arc, then it's time for a new battery.
    - If arc, report back here.
    Dave Emerson, Dec 10, 2009
  4. YTC#1
    are you sure the battery isn't fucked? It's possible for a battery voltage
    to be fine without a load and then die once a current is drawn.
    If it's not the battery then my first check would be the starter solenoid.
    wessie, Dec 10, 2009
  5. YTC#1
    'Hog Guest
    I was driving behind a Land Rover tonight with the reg R1 YTC
    'Hog, Dec 10, 2009
  6. YTC#1
    YTC#1 Guest
    Even though the optimate reports ok and I can get 13V before connecting ?
    YTC#1, Dec 10, 2009
  7. YTC#1
    YTC#1 Guest
    I'm tired... ok !
    YTC#1, Dec 10, 2009
  8. YTC#1
    ts Guest
    You didn't notice whether the light switch was on, or not :))
    How old is the battery?
    ts, Dec 10, 2009
  9. YTC#1
    ian field Guest
    You did check that none of the cells need topping up?
    ian field, Dec 10, 2009
  10. YTC#1
    malc Guest
    Yup. If one or more cells go duff they can go high resistance. So the
    battery registers a full voltage, but as soon as any load is put on it the
    high internal resistance drops the output voltage down. Seen it several
    times on the equipment we service.
    Malc
    Rusted and ropy.
    Dog-eared old copy.
    Vintage and classic,
    or just plain Jurassic:
    all words to describe me.
    malc, Dec 10, 2009
  11. YTC#1
    frag Guest
    took a blunt brush and painted...
    If it's drawing enough current to pull a good battery down to 3V then I would
    imagine the fuze would explode, and if that didn't happen (due to 6" nailery)
    the battery wires would get fucking warm, rapidly.
    frag, Dec 10, 2009
  12. YTC#1
    frag Guest
    Yes.
    I bet if you get a little 21W 12V bulb and connect it across the battery
    you'll get a dim glow.
    Optimates are good but not god.
    frag, Dec 10, 2009
  13. YTC#1
    crn Guest
    Most likely a fucked battery unless you see a splash when you connect it.
    What happens if you jumplead it to a decent battery.
    crn, Dec 11, 2009
  14. YTC#1
    TOG@Toil Guest
    Or you could just connect a terminal to each of Bruce's ears and watch
    his eyes for the same effect.
    TOG@Toil, Dec 11, 2009
  15. YTC#1
    boots Guest
    The glow would be so dim you'd need WISE to see it.
    boots, Dec 11, 2009
  16. YTC#1
    Beav Guest
    Or hook up a decent battery to the bike and see what happens.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Dec 11, 2009
  17. YTC#1
    YTC#1 Guest
    The way it sits in the garage, very easy to do
    About 4 years, but age (IMO) has little to do with it. The XJR battery
    is 8 years old
    YTC#1, Dec 11, 2009
  18. YTC#1
    YTC#1 Guest
    Which it was.
    Went back in the garage last night, after remembering I still had the
    old battery I use for airbeds etc ( always kept topped up). Spent a good
    half hour struggling to get battery out (I remember now why I must have
    blanked the battery as an option, I need to undo the engine bars to get
    it shifted). Connect old battery up, and she fired up 1st time :)
    New one sourced and ordered, so I can get my tyres changd on Sat am now
    as planned.
    YTC#1, Dec 11, 2009
  19. YTC#1
    YTC#1 Guest
    *ding* ;-)
    YTC#1, Dec 11, 2009
  20. YTC#1
    YTC#1 Guest
    See other post about what an arse it is to get in and out
    YTC#1, Dec 11, 2009
