Email problem
Discussion in 'UK Motorcycles' started by Lozzo, Mar 31, 2006.
  1. Lozzo
    I can't send emails. When I try I'm getting this message back from
    "System Administrator"
    <start>
    Your message did not reach some or all of the intended recipients.
    Subject: test
    Sent: 31/03/2006 12:27
    The following recipient(s) could not be reached:
    '' on 31/03/2006 12:27
    503 Valid RCPT TO <recipient> must precede DATA
    <end>
    Wtf is that all about?
    Lozzo, Mar 31, 2006
  2. Your ISP has utterly borked their mailserver..
    Phil
    Phil Launchbury, Mar 31, 2006
  3. Lozzo
    Cab Guest
    "lozo" is spelt incorrectly, as a guess.
    Cab, Mar 31, 2006
  4. Lozzo
    Cab said...
    Nah, that's a wild address so it will accept anything to the speedyspic
    address. It's also happening when I reply to emails from others.
    Lozzo, Mar 31, 2006
  5. Lozzo
    Cab Guest
    The "RCPT TO" is the part where it looks for an email address
    (destination) and it obviously needs the email addy, before it can send
    the body of the email (DATA).
    FYI, it works when I send email to you, through your mail server.
    Try the following to see if it works (assuming you're using windows)
    Click Start then run
    Type "cmd"
    Hit enter
    Type "telnet uk2mxarray4.uk2.net 25" (This is your email server)
    Hit enter
    Type "HELO speedyspic.co.uk"
    Hit enter
    Type "MAIL FROM:<insert your email address here>"
    Hit enter
    Type "RCPT TO:<insert your email address here>"
    Hit enter
    Type "DATA"
    Hit enter
    Type "Any old garbage"
    Hit enterType "." (That's right, a full stop by itself)
    Hit enter
    Type "QUIT"
    Hit enter
    Tell me what happens. This should work. If it does, then I think your
    email program is playing silly buggers.
    Cab, Mar 31, 2006
  6. Lozzo
    Cab said...
    Just tried to reply to your test mail, no dice. Ta for trying.
    Lozzo, Mar 31, 2006
  7. Lozzo
    Cab Guest
    Bad form...
    Or as Phil said, your ISP has screwed things up...
    Cab, Mar 31, 2006
  8. Lozzo
    Cab said...
    I went through all that, and it's still giving the same message when I
    try to mail out
    Lozzo, Mar 31, 2006
  9. Lozzo
    Cab Guest
    So it failed after the "RCPT TO" part?
    Cab, Mar 31, 2006
  10. Lozzo
    Cab said...> > Try the following to see if it works (assuming you're
    using windows)
    I just did this again but using the lozzo.org address as it's the
    primary one. I got a lijne on the screen with a '550 could not find the
    server' message, or summat like that.
    Lozzo, Mar 31, 2006
  11. Lozzo
    Cab said...
    Yes. I got a 550 could not find server message
    Lozzo, Mar 31, 2006
  12. Lozzo
    Cab Guest
    That's probably correct, as lozzo.org doesn't exist (I've just tried
    it). Did you add .uk to the end of the addy?
    Cab, Mar 31, 2006
  13. Lozzo
    Cab Guest
    It looks like Phil was right. It appears that your ISP has screwed up.
    Cab, Mar 31, 2006
  14. Lozzo
    Catman Guest
    What he said. It's nothign you can do apart form phone them up and tell
    them. Unless you ahve your own smtp server, in which case you should fix
    it ;)
    www.cuore-sportivo.co.uk
    Catman, Mar 31, 2006
  15. ^^^^^^^^^^^^^^^^^^^^^^^^^
    <Waves[2]>
    Phil
    [2] In fact - several. 2 at home and one here..
  16. Lozzo
    Cab said...
    OK, thanks muchly to yourself and Phil. I'll have to wait for Elly to
    return from US though, cos she's the one who deals with the ISP and has
    all the passwords etc.
    Lozzo, Mar 31, 2006
  17. Lozzo
    Dr Zoidberg Guest
    DNS report shows that it's working so they may have fixed whatever the
    problem was now
    http://www.dnsreport.com/tools/mail.ch?domain=
    Dr Zoidberg, Mar 31, 2006
  18. Lozzo
    Cab Guest
    Cab, Mar 31, 2006
  19. Lozzo
    Dr Zoidberg said...
    I can receive email fine, I've been getting enough of that, but I can't
    reply.
    Lozzo, Mar 31, 2006
  20. Lozzo
    wessie said...
    UK2 is Elly's domain host. The speedyspic domain is hosted by someone
    else with a redirect to my lozzo.org.uk address. I have lozzo.org.uk on
    Elly's account, if that makes any sense.
    Lozzo, Mar 31, 2006
