Engine oil
Discussion in 'Australian Motorcycles' started by JustBiggus, Nov 10, 2010.
  1. JustBiggus
    JustBiggus Guest
    Whats the good oil these days... This is for XTZ750 Yamaha..
    Most shops seem to stock Motul and Shell... But are they the good oil,
    or what they make most $ on?
    I may have been drunk, but Im sure the owner said he used Shell Tellus
    in it, but thats hydraulic oil ?
  2. JustBiggus
    Lars Chance Guest
    I use Penrite HPR from Supercheap.
    Lars Chance, Nov 10, 2010
  3. In aus.motorcycles on Wed, 10 Nov 2010 22:20:27 +1000
    Ditto in the old bike, the new one takes 10W60 full synthetic which is
    a Castrol got from the same place and is eye wateringly expensive...
    Zebee
    Zebee Johnstone, Nov 10, 2010
  4. JustBiggus
    Lars Chance Guest
    Penrite have a model-checker thingie website if you're unsure what to use:
    http://www.datateck.com.au/Lube/PenriteAus/default.asp
    (Sin15 is their recommendation for the Norge and just 20w-50 or Sin15
    for the XTZ750)
  5. In aus.motorcycles on Thu, 11 Nov 2010 11:58:24 +1030
    Dunno, I left the first few services to the dealer. Was on full syn
    when I started doing changes.
    Zebee
    Zebee Johnstone, Nov 11, 2010
  6. JustBiggus
    atec77 Guest
    I just use the full synth Fuches from the 44 gal (10w40) out back in
    everything we drive including the jag and the bimmers
    atec77, Nov 11, 2010
  7. JustBiggus
    Marty H Guest
    Delo 400
    Diesel oil, about $90 for 20lt
    google it and the word bike or motorcycle
    mh
    Marty H, Nov 11, 2010
  8. JustBiggus
    GWD Guest
    No not Tellus.
    Delo was OK on the old 650 single but I would be chary about using
    high detergent oil in an old high performance engine. The old caution
    about the removal of gap filling carbon deposits through the use of
    diesel specific engine oil is a bit more than an old wives tale.
    Any oil that conforms to the specified viscosity standards is OK
    regardless of price. Manufacturers specifications consider dry/wet
    sumps, dry/wet clutches, bearing clearances, rev ranges,
    contamination, seal compositions etc. Whether or not a particular
    suitable brand or type is more economical than another depends on
    change frequency versus price and whether manufacturers
    recommendations can be tampered with. Of course, you do that at your
    own risk so research is essential.
    Economy due to extended engine life due to use of a particular oil is
    a bit hard to prove.
    I stick with the cheapest brand that meets all of the recommended
    criteria, and change at periods recommended by the manufacturer
    GWD, Nov 11, 2010
  9. JustBiggus
    Deevo Guest
    Are Shell still doing the Sport 4? I used to use it in the GT750 (Kwak) and
    the Goldwing without any problems but that was a few years back.
    Deevo, Nov 11, 2010
  10. JustBiggus
    schroda Guest
    I'm using Castrol RX and will probably change to Rimula-X
    Worth doing a bit of reading on the use of alternate oils.
    Much cheaper and excellent oils.
    Would like to use Rotella-T synthetic 5w 40w, but not available in
    Australia
    schroda, Nov 24, 2010
