Entertain me
Discussion in 'UK Motorcycles' started by Eddie, Sep 26, 2009.
  1. Eddie
    Eddie Guest
    I've got an hour and a half to wait for recovery, and all I've got to
    pass the time is my mobile phone. Somebody post something interesting
    for me to read, please.
    Damned Italian electrics.
    Mind, it could be worse: at least there's no pool of oil underneath
    it, so it looks like the liquid gasket worked.
    Eddie, Sep 26, 2009
  2. Eddie
    Look a few yards back down the road - is that the tail-end of a tapering
    slick, down there? Does it lead to a bigger line? Have you checked the
    oil level?
    Pip, Sep 26, 2009
  3. It was all nice and dry underneath, last time I looked. I'd check the
    oil level, but I've only just got comfy and I can't be arsed to move.
    Eddie Deguello, Sep 26, 2009
  4. Eddie
    Pete Fisher Guest
    It would still be dripping shirley?
    Was it the alternator cover that got put back on with goo ? No
    connection with the electrical problem I'm sure ;-)
    | Pete Fisher at Home: |
    Pete Fisher, Sep 26, 2009
  5. I think he's trying to be funny. Very trying.
    That had me worried for a moment. But it's been running fine up till
    last night, headlights and everything, except I don't think the
    battery's been getting charged.
    It could just be that the battery's duff: after being charged
    overnight, it wouldn't turn over the bike today, so I had to bump
    start it. The charge warning light came on after about 5 miles or so,
    then it started misfiring, then eventually died completely.
  6. Eddie
    Nige Guest
    My Ducati did that, the reg/rect wire broke so not charging the battery.
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Sep 26, 2009
  7. I gave that wire a bit of a wiggle before putting the tank back on
    last week, thinking that I should really sort out the dodgy-looking
    connections on it at some point. Wish I'd done it while I thought of
    it.
  8. Eddie
    Pete Fisher Guest
    Sounds a likely culprit. My Guzzi used to suffer from intermittent lack
    of charging with a flickering warning light, until I traced it to a bad
    connection under the tank somewhere, nowhere near the reg/rect.
    The Voxan, however, whilst it charges perfectly, eats batteries. They
    get too hot because of the location down low by the rear pot pipe and
    the oil tank. I put a new Varta AGM one on before the Manx. Must
    remember to Optimate it from time to time over the winter. I recovered
    the Westco on the MX5 OK. It did take 5 days on the Optimate, but this
    is normal for this type of battery apparently. Must find a local
    Clifford alarm agent and have the pesky thing ripped out.
    | Visit my Home Page : http://www.flarefox.com/Lesbordes |
    | "Do not adjust your mind - there is a fault in the reality" |
  9. Eddie
    Nige Guest
    The recovery man just removed the shitty connector & crimped them through,
    gave the bettery a quick chaqrge, started the bike & I was off to meet Beav,
    Chris & Monz :)
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Sep 26, 2009
  10. Eddie
    Nige Guest
    I fucked my optimate last week, the lead end snapped off. Fucking the
    plastic bit, anyone got a fucked optimate they can cut one off for me?
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Sep 26, 2009
  11. Eddie
    Pete Fisher Guest
    The charger end, or a permanent harness on to a bike end ? I bodged up a
    connector for mine using a speaker plug and socket from Maplins. One
    round and one flat pin, so you can't get the polarity wrong (if you wire
    it correctly).
  12. Eddie
    zymurgy Guest
    Google/Ebay up 'Tamiya connectors'
    They're a standard battery hookup.
    Cheers,
    Paul.
    zymurgy, Sep 26, 2009
  13. Eddie
    Nige Guest
    Mnay thanks matey :)
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Sep 26, 2009
  14. Eddie
    boots Guest
    You could probably sell that idea to TOG.
    boots, Sep 26, 2009
  15. Eddie
    Beav Guest
    ICBW Nige, but the ends look remarkably like Tamiya connectors, available at
    all good mogel shops for mere pennies.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Sep 26, 2009
  16. Eddie
    Beav Guest
    Oh fuckity **** fucking bollocks!
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Sep 26, 2009
  17. Eddie
    Nige Guest
    Yep, got that matey :)
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Sep 26, 2009
  18. (I thought I'd posted this yesterday, but using Google Groups on my
    mobile is a bit of a hit-and-miss affair...)
    The man in the orange van eventually turned up, agreed with my
    diagnosis of a very knackered battery, and confirmed it with various
    tests which all said the same thing: *that* is an ex-battery.
    He trundled off to Halfords to get me a new battery (*how* much?),
    refitted it, and all was well. But by that time it was gone 4 o'clock,
    and as I hadn't even made it to the M1, I decided to give up on my
    plan of visiting Bletchley Park. Some other time, I guess.
    Oh, and still no oil leak. <fx: flicks Vs at Beav, Lozzo, and all the
    other gasket fetishists>
    Eddie Deguello, Sep 27, 2009
  19. Oops. I wonder if the dud battery took out the reg/rec. Not unknown.
    Grimly Curmudgeon, Sep 27, 2009
  20. Eddie
    <reads thread>
    Wasn't very entertaining, was it.
    Champ, Sep 27, 2009
Similar Threads
Loading...
